1 |
.\" RCSid "$Id$" |
2 |
.TH RAD 1 2/1/99 RADIANCE |
3 |
.SH NAME |
4 |
rad - render a RADIANCE scene |
5 |
.SH SYNOPSIS |
6 |
.B rad |
7 |
8 |
.B \-s |
9 |
10 |
.B "-n|-N npr" |
11 |
12 |
.B \-t |
13 |
14 |
.B \-e |
15 |
16 |
.B \-V |
17 |
18 |
.B \-w |
19 |
20 |
.B "\-v view" |
21 |
22 |
.B "\-o device" |
23 |
24 |
.B rfile |
25 |
26 |
.B "VAR\=value .." |
27 |
28 |
.SH DESCRIPTION |
29 |
.I Rad |
30 |
is an executive program that reads the given |
31 |
.I rfile |
32 |
and makes appropriate calls to |
33 |
.I oconv(1), |
34 |
.I mkillum(1), |
35 |
.I rpict(1), |
36 |
.I pfilt(1), |
37 |
and/or |
38 |
.I rview(1) |
39 |
to render a specific scene. |
40 |
Variables in |
41 |
.I rfile |
42 |
give input files and qualitative information about the rendering(s) |
43 |
desired that together enable |
44 |
.I rad |
45 |
to intelligently set parameter values and control the simulation. |
46 |
.PP |
47 |
Normally, commands are echoed to the standard output as they are |
48 |
executed. |
49 |
The |
50 |
.I \-s |
51 |
option tells |
52 |
.I rad |
53 |
to do its work silently. |
54 |
The |
55 |
.I \-n |
56 |
option tells |
57 |
.I rad |
58 |
not to take any action (ie. not to actually execute any commands). |
59 |
The |
60 |
.I \-N |
61 |
option instructs |
62 |
.I rad |
63 |
to run as many as |
64 |
.I npr |
65 |
rendering processes in parallel. |
66 |
The |
67 |
.I \-t |
68 |
option tells |
69 |
.I rad |
70 |
to bring rendering files up to date relative to the input |
71 |
(scene description) files, without performing any actual |
72 |
calculations. |
73 |
If no octree exists, it is still necessary to run |
74 |
.I oconv(1) |
75 |
to create one, since the |
76 |
.I \-t |
77 |
option will not create invalid (i.e. empty) files, and |
78 |
a valid octree is necessary for the correct operation of |
79 |
.I rad. |
80 |
The |
81 |
.I \-e |
82 |
option tells |
83 |
.I rad |
84 |
to explicate all variables used for the simulation, including |
85 |
default values not specified in the input file, and print them on |
86 |
the standard output. |
87 |
.PP |
88 |
Normally, |
89 |
.I rad |
90 |
will produce one picture for each view given in |
91 |
.I rfile. |
92 |
The |
93 |
.I \-v |
94 |
option may be used to specify a single desired view. |
95 |
The |
96 |
.I view |
97 |
argument may either be a complete view specification |
98 |
(enclosed in quotes and beginning with an optional identifier) |
99 |
or a number or single-word identifier to match a view defined in |
100 |
.I rfile. |
101 |
If the argument is one of the standard view identifiers, |
102 |
it may or may not be further elaborated in |
103 |
.I rfile. |
104 |
(See "view" variable description, below.)\0 |
105 |
If the argument does not match any views in |
106 |
.I rfile |
107 |
and is not one of the standard views, no rendering will take place. |
108 |
This may be convenient when the only action desired of |
109 |
.I rad |
110 |
is the rebuilding of the octree. |
111 |
In particular, the argument "0" will never match a view. |
112 |
.PP |
113 |
If the |
114 |
.I \-V |
115 |
option is given, |
116 |
each view will be printed on the standard output before |
117 |
being applied, in a form suitable for use in a view file or |
118 |
.I rpict |
119 |
rendering sequence. |
120 |
This is helpful as feedback or for accessing the |
121 |
.I rad |
122 |
view assignments without necessarily starting a rendering. |
123 |
.PP |
124 |
By default, |
125 |
.I rad |
126 |
will run |
127 |
.I rpict |
128 |
and |
129 |
.I pfilt |
130 |
to produce a picture for each view. |
131 |
The |
132 |
.I \-o |
133 |
option specifies an output device for |
134 |
.I rview |
135 |
(usually "x11") |
136 |
and runs this interactive program instead, using the first view in |
137 |
.I rfile |
138 |
or the view given with the |
139 |
.I \-v |
140 |
option as the starting point. |
141 |
.PP |
142 |
Additional variable settings may be added or overridden on the |
143 |
command line following |
144 |
.I rfile. |
145 |
Upper case variables specified more than once will result in |
146 |
a warning message (unless the |
147 |
.I \-w |
148 |
option is present), |
149 |
and the last value given will be the one used. |
150 |
.PP |
151 |
The |
152 |
.I \-w |
153 |
option turns off warnings about multiply and misassigned variables. |
154 |
.PP |
155 |
Rendering variable assignments appear one per line in |
156 |
.I rfile. |
157 |
The name of the variable is followed by an equals sign |
158 |
('=') and its value(s). |
159 |
The end of line may be escaped with a backslash ('\\'), though it is |
160 |
not usually necessary since additional variable values may be given |
161 |
in multiple assignments. |
162 |
Variables that should have only one value are given in upper case. |
163 |
Variables that may have multiple values are given in lower case. |
164 |
Variables may be abbreviated by their first three letters. |
165 |
Comments in |
166 |
.I rfile |
167 |
start with a pound sign ('#') and proceed to the end of line. |
168 |
.PP |
169 |
The rendering variables, their interpretations and default values |
170 |
are given below. |
171 |
.TP 10n |
172 |
.BR OCTREE |
173 |
The name of the octree file. |
174 |
The default name is the same as |
175 |
.I rfile |
176 |
but with any suffix replaced by ".oct". |
177 |
(The octree must be a file -- |
178 |
.I rad |
179 |
cannot work with commands that produce octrees.)\0 |
180 |
.TP |
181 |
.BR ZONE |
182 |
This variable specifies the volume of interest for this simulation. |
183 |
The first word is either "Interior" or "Exterior", depending on |
184 |
whether the zone is to be observed from the inside or the outside, |
185 |
respectively. |
186 |
(A single letter may be given, and case does not matter.)\0 |
187 |
The following six numbers are the minimum and maximum |
188 |
X coordinates, minimum and maximum Y, and minimum and maximum Z |
189 |
for the zone perimeter. |
190 |
It is important to give the zone as it is used to determine many of |
191 |
the rendering parameters. |
192 |
The default exterior zone is the bounding cube for the scene as |
193 |
computed by |
194 |
.I oconv. |
195 |
.TP |
196 |
.BR EXPOSURE |
197 |
This variable tells |
198 |
.I rad |
199 |
how to adjust the exposure for display. |
200 |
It is important to set this variable properly as it is used to |
201 |
determine the ambient value. |
202 |
An appropriate setting may be discovered by running |
203 |
.I rview |
204 |
and noting the exposure given by the "exposure =" command. |
205 |
As in |
206 |
.I rview |
207 |
and |
208 |
.I pfilt, |
209 |
the exposure setting may be given either as a multiplier or as a |
210 |
number of f-stop adjustments (eg. +2 or -1.5). |
211 |
There is no default value for this variable. |
212 |
If it is not given, an average level will be computed by |
213 |
.I pfilt |
214 |
and the ambient value will be set to 10 for exterior zones |
215 |
and 0.01 for interior zones. |
216 |
.TP |
217 |
.BR EYESEP |
218 |
The interocular spacing for stereo viewing. |
219 |
I.e., the world distance between the pupils of the left and right eyes. |
220 |
The default value is the sum of the three "ZONE" dimensions divided by 100. |
221 |
.TP |
222 |
.BR scene |
223 |
This variable is used to specify one or more scene input files. |
224 |
These files will be given together with the materials file(s) |
225 |
and any options specified by the "oconv" variable to |
226 |
.I oconv |
227 |
to produce the octree given by the "OCTREE" variable. |
228 |
In-line commands may be specified in quotes instead of a file, |
229 |
beginning with an exclamation mark ('!'). |
230 |
If the "scene" variable is not present, then the octree must already exist |
231 |
in order for |
232 |
.I rad |
233 |
to work. |
234 |
Even if this variable is given, |
235 |
.I oconv |
236 |
will not be run unless the octree is out of date with respect to |
237 |
the input files. |
238 |
Note that the order of files in this variable is important for |
239 |
.I oconv |
240 |
to work properly, and files given in later variable assignments will |
241 |
appear after previous ones on the |
242 |
.I oconv |
243 |
command line. |
244 |
.TP |
245 |
.BR materials |
246 |
This variable is used to specify files that, although they must |
247 |
appear on the |
248 |
.I oconv |
249 |
command line, do not affect the actual octree itself. |
250 |
Keeping the materials in separate files allows them to be modified |
251 |
without requiring the octree to be rebuilt (a sometimes costly |
252 |
procedure). |
253 |
These files should not contain any geometry, and the |
254 |
.I \-f |
255 |
option must not be given in the "oconv" variable for this to work. |
256 |
.TP |
257 |
.BR illum |
258 |
This variable is used to specify files with surfaces to be converted into |
259 |
illum sources by |
260 |
.I mkillum(1). |
261 |
When this variable is given, additional octree files will be created |
262 |
to contain the scene before and after illum source conversion. |
263 |
These files will be named according to the (default) value of the |
264 |
.I OCTREEE |
265 |
variable, with either a '0' or a '1' appearing just before the file |
266 |
type suffix (usually ".oct"). |
267 |
.TP |
268 |
.BR objects |
269 |
This variable is used for files that, although they do not appear |
270 |
on the |
271 |
.I oconv |
272 |
command line, contain geometric information that is referenced |
273 |
indirectly by the scene files. |
274 |
If any of these files is changed, the octree will be rebuilt. |
275 |
(The |
276 |
.I raddepend(1) |
277 |
command may be used to find these dependencies automatically.)\0 |
278 |
.TP |
279 |
.BR view |
280 |
This variable is used to specify a desired view for this zone. |
281 |
Any number of "view" lines may be given, and each will result in a |
282 |
rendered picture (unless the |
283 |
.I \-v |
284 |
or |
285 |
.I \-o |
286 |
option is specified). |
287 |
The value for this variable is an optional identifier followed by |
288 |
any number of view options (see |
289 |
.I rpict(1) |
290 |
for a complete listing). |
291 |
The identifier is used in file naming and associating a desired view |
292 |
with the |
293 |
.I \-v |
294 |
command line option. |
295 |
Also, there are several standard view identifiers defined by |
296 |
.I rad. |
297 |
These standard views are specified by strings of the form |
298 |
"[Xx]?[Yy]?[Zz]?[vlcah]?". |
299 |
(That is, an optional upper or lower case X followed by an optional |
300 |
upper or lower case Y followed by an optional upper or lower case Z |
301 |
followed by an optional lower case V, L, C, A or H.)\0 |
302 |
The letters indicate the desired view position, where upper case X |
303 |
means maximum X, lower case means minimum and so on. |
304 |
The final letter is the view type, where 'v' is perspective (the |
305 |
default), 'l' is parallel, 'c' is a cylindrical panorama, |
306 |
'a' is angular fisheye, and 'h' is hemispherical fisheye. |
307 |
A perspective view from maximum X, minimum Y would be "Xy" or "Xyv". |
308 |
A parallel view from maximum Z would be "Zl". |
309 |
If "ZONE" is an interior zone, the standard views will |
310 |
be inside the perimeter. |
311 |
If it is an exterior zone, the standard views will be outside. |
312 |
Note that the standard views are best used as starting points, |
313 |
and additional arguments may be given after the |
314 |
identifier to modify a standard view to suit a particular model. |
315 |
The default view is "X" if no views are specified. |
316 |
A single specified view of "0" means no views will be automatically |
317 |
generated. |
318 |
.TP |
319 |
.BR UP |
320 |
The vertical axis for this scene. |
321 |
A negative axis may be specified with a minus sign (eg. "-Y"). |
322 |
There is no default value for this variable, although the standard |
323 |
views assume Z is up if no other axis is specified. |
324 |
.TP |
325 |
.BR RESOLUTION |
326 |
This variable specifies the desired final picture resolution. |
327 |
If only a single number is given, this value will be used for both |
328 |
the horizontal and vertical picture dimensions. |
329 |
If two numbers are given, the first is the horizontal resolution and |
330 |
the second is the vertical resolution. |
331 |
If three numbers are given, the third is taken as the pixel aspect |
332 |
ratio for the final picture (a real value). |
333 |
If the pixel aspect ratio is zero, the exact dimensions given will |
334 |
be those produced. |
335 |
Otherwise, they will be used as a frame in which the final image |
336 |
must fit. |
337 |
The default value for this variable is 512. |
338 |
.TP |
339 |
.BR QUALITY |
340 |
This variable sets the overall rendering quality desired. |
341 |
It can have one of three values, "LOW", "MEDIUM" or "HIGH". |
342 |
These may be abbreviated by their first letter, and may be |
343 |
in upper or lower case. |
344 |
Most of the rendering options will be affected by this setting. |
345 |
The default value is "L". |
346 |
.TP |
347 |
.BR PENUMBRAS |
348 |
This is a boolean variable indicating whether or not penumbras are |
349 |
desired. |
350 |
A value of "TRUE" will result in penumbras (soft shadows), and a |
351 |
value of "FALSE" will result in no penumbras (sharp shadows). |
352 |
True and false may be written in upper or lower case, and may be |
353 |
abbreviated by a single letter. |
354 |
Renderings generally proceed much faster without penumbras. |
355 |
The default value is "F". |
356 |
.TP |
357 |
.BR INDIRECT |
358 |
This variable indicates how many diffuse reflections are important in the |
359 |
general lighting of this zone. |
360 |
A direct lighting system (eg. fluorescent troffers recessed in the |
361 |
ceiling) corresponds to an indirect level of 0. |
362 |
An indirect lighting system (eg. hanging fluorescents directed at a |
363 |
reflective ceiling) corresponds to an indirect level of 1. |
364 |
A diffuse light shelf reflecting sunlight onto the ceiling would |
365 |
correspond to an indirect level of 2. |
366 |
The setting of this variable partially determines how many interreflections |
367 |
will be calculated. |
368 |
The default value is 0. |
369 |
.TP |
370 |
.BR PICTURE |
371 |
This is the root name of the output picture file(s). |
372 |
This name will have appended the view identifier (or a number if no |
373 |
id was used) and a ".pic" suffix. |
374 |
If a picture corresponding to a specific view exists and is not out |
375 |
of date with respect to the given octree, it will not be |
376 |
re-rendered. |
377 |
The default value for this variable is the root portion of |
378 |
.I rfile. |
379 |
.TP |
380 |
.BR RAWFILE |
381 |
This is the root name of the finished, raw |
382 |
.I rpict |
383 |
output file. |
384 |
If specified, |
385 |
.I rad |
386 |
will rename the original |
387 |
.I rpict |
388 |
output file once it is finished and filtered |
389 |
rather than removing it, which is the default action. |
390 |
The given root name will be expanded in the same way as the |
391 |
"PICTURE" variable, and if the "RAWFILE" and "PICTURE" variables |
392 |
are identical, then no filtering will take place. |
393 |
.TP |
394 |
.BR ZFILE |
395 |
This is the root name of the raw distance file produced by the |
396 |
.I \-z |
397 |
option of |
398 |
.I rpict. |
399 |
To this root name, an underscore plus the view name plus a ".zbf" |
400 |
suffix will be added. |
401 |
If no "ZFILE" is specified, none will be produced. |
402 |
.TP |
403 |
.BR AMBFILE |
404 |
This is the name of the file where "ambient" or diffuse interreflection |
405 |
values will be stored by |
406 |
.I rpict |
407 |
or |
408 |
.I rview. |
409 |
Although it is not required, an ambient file should be given whenever |
410 |
an interreflection calculation is expected. |
411 |
This will optimize successive runs and minimize artifacts. |
412 |
An interreflection calculation will take place when the |
413 |
"QUALITY" variable is set to HIGH, or when the "QUALITY" |
414 |
variable is set to MEDIUM and "INDIRECT" is positive. |
415 |
416 |
.TP |
417 |
.BR DETAIL |
418 |
This variable specifies the level of visual detail in this zone, |
419 |
and is used to determine image sampling rate, among other things. |
420 |
If there are few surfaces and simple shading, then this should be set |
421 |
to LOW. |
422 |
For a zone with some furniture it might be set to MEDIUM. |
423 |
If the space is very cluttered or contains a lot of geometric detail |
424 |
and textures, then it should be set to HIGH. |
425 |
The default value is "M". |
426 |
.TP |
427 |
.BR VARIABILITY |
428 |
429 |
.I rad |
430 |
how much light varies over the surfaces of this zone, and is |
431 |
used to determine what level of sampling is necessary in the |
432 |
indirect calculation. |
433 |
For an electric lighting system with uniform coverage, the value |
434 |
should be set to LOW. |
435 |
For a space with spot lighting or a window with sky illumination |
436 |
only, it might be set to MEDIUM. |
437 |
For a space with penetrating sunlight casting bright patches in a |
438 |
few places, it should be set to HIGH. |
439 |
440 |
.TP |
441 |
.BR OPTFILE |
442 |
This is the name of a file in which |
443 |
.I rad |
444 |
will place the appropriate rendering options. |
445 |
This file can later be accessed by |
446 |
.I rpict |
447 |
or |
448 |
.I rview |
449 |
in subsequent manual runs using the at-sign ('@') file insert option. |
450 |
(Using an "OPTFILE" also reduces the length of the rendering |
451 |
command, which improves appearance and may even be necessary on some |
452 |
systems.)\0 |
453 |
454 |
.TP |
455 |
.BR REPORT |
456 |
This variable may be used to specify a reporting interval for |
457 |
batch rendering. |
458 |
Given in minutes, this value is multiplied by 60 and passed to |
459 |
.I rpict |
460 |
with the |
461 |
.I \-t |
462 |
option. |
463 |
If a filename is given after the interval, it will be used as the |
464 |
error file for reports and error messages instead of the standard error. |
465 |
(See the |
466 |
.I \-e |
467 |
option of |
468 |
.I rpict(1).\)\0 |
469 |
470 |
.TP |
471 |
.BR oconv |
472 |
This variable may be used to specify special options to |
473 |
.I oconv. |
474 |
See the |
475 |
.I oconv(1) |
476 |
manual page for a list of valid options. |
477 |
.TP |
478 |
.BR mkillum |
479 |
This variable may be used to specify additional options to |
480 |
.I mkillum. |
481 |
See the |
482 |
.I rtrace(1) |
483 |
484 |
.TP |
485 |
.BR render |
486 |
487 |
.I rpict |
488 |
or |
489 |
.I rview. |
490 |
These options will appear after the options set automatically by |
491 |
.I rad, |
492 |
and thus will override the default values. |
493 |
.TP |
494 |
.BR pfilt |
495 |
496 |
.I pfilt. |
497 |
See the |
498 |
.I pfilt(1) |
499 |
manual page for details. |
500 |
.SH EXAMPLES |
501 |
A minimal input file for |
502 |
.I rad |
503 |
might look like this: |
504 |
.IP "" .3i |
505 |
.nf |
506 |
507 |
sample.rif |
508 |
509 |
# The octree we want to use: |
510 |
OCTREE= tutor.oct # w/o this line, name would be "sample.oct" |
511 |
# Our scene input files: |
512 |
scene= sky.rad outside.rad room.rad srcwindow.rad |
513 |
# The interior zone cavity: |
514 |
ZONE= I 0 3 0 2 0 1.75 # default would be scene bounding cube |
515 |
# The z-axis is up: |
516 |
UP= Z # no default - would use view spec. |
517 |
# Our exposure needs one f-stop boost: |
518 |
EXPOSURE= +1 # default is computed ex post facto |
519 |
.fi |
520 |
.PP |
521 |
Note that we have not specified any views in the file above. |
522 |
The standard default view "X" would be used if we were to run |
523 |
.I rad |
524 |
on this file. |
525 |
If we only want to see what default values |
526 |
.I rad |
527 |
would use without actually executing anything, we can invoke it thus: |
528 |
.IP "" .2i |
529 |
rad -n -e sample.rif |
530 |
.PP |
531 |
This will print the variables we have given as well as default |
532 |
values |
533 |
.I rad |
534 |
has assigned for us. |
535 |
Also, we will see the list of commands that |
536 |
.I rad |
537 |
would have executed had the |
538 |
.I \-n |
539 |
option not been present. |
540 |
(Note if the octree, "tutor.oct", is not present, an error will |
541 |
result as it is needed to determine some of the opiton settings.)\0 |
542 |
.PP |
543 |
Different option combinations have specific uses, ie: |
544 |
.IP "" .2i |
545 |
.br |
546 |
rad -v 0 sample.rif OPT=samp.opt # build octree, put options in "sample.opt" |
547 |
.br |
548 |
rad -n -e -s sample.rif > full.rif # make a complete rad file |
549 |
.br |
550 |
rad -n sample.rif > script.sh # make a script of commands |
551 |
.br |
552 |
rad -V -v Zl -n -s sample.rif > plan.vf # make a plan view file |
553 |
.br |
554 |
rad -t sample.rif # update files after minor change to input |
555 |
.br |
556 |
rad -s sample.rif & # execute silently in the background |
557 |
.PP |
558 |
If we decide that the default values |
559 |
.I rad |
560 |
has chosen for our variables are not all appropriate, we can add |
561 |
some more assignments to the file: |
562 |
.IP "" .3i |
563 |
.nf |
564 |
QUAL= MED # default was low |
565 |
DET= low # default was medium - our space is almost empty |
566 |
PEN= True # we want to see soft shadows from our window |
567 |
VAR= hi # daylight can result in fairly harsh lighting |
568 |
view= XYa -vv 120 # let's try a fisheye view |
569 |
PICT= tutor # our picture name will be "tutor_XYa.pic" |
570 |
.fi |
571 |
.PP |
572 |
Note the use of abbreviations, and the modification of a standard |
573 |
view. |
574 |
Now we can invoke |
575 |
.I rad |
576 |
to take a look at our scene interactively with |
577 |
.I rview: |
578 |
.IP "" .2i |
579 |
rad -o x11 sample.rif |
580 |
.PP |
581 |
.I Rad |
582 |
will run |
583 |
.I oconv |
584 |
first to create the octree (assuming it doesn't |
585 |
already exist), then |
586 |
.I rview |
587 |
with a long list of options. |
588 |
Let's say that from within |
589 |
.I rview, |
590 |
we wrote out the view files "view1.vp" and "view2.vp". |
591 |
We could add these to "sample.rif" like so: |
592 |
.IP "" .2i |
593 |
.nf |
594 |
view= vw1 -vf view1.vp # Our first view |
595 |
view= vw2 -vf view2.vp # Our second view |
596 |
RESOLUTION= 1024 # Let's go for a higher resolution result |
597 |
.fi |
598 |
.PP |
599 |
To start |
600 |
.I rview |
601 |
again using vw2 instead of the default, we use: |
602 |
.IP "" .2i |
603 |
rad -o x11 -v vw2 sample.rif |
604 |
.PP |
605 |
Once we are happy with the variable settings in our file, we can run |
606 |
.I rad |
607 |
in the background to produce one image for each view: |
608 |
.IP "" .2i |
609 |
rad sample.rif REP=5 >& errfile & |
610 |
.PP |
611 |
This will report progress every five minutes to "errfile". |
612 |
.SH FILES |
613 |
$(PICTURE)_$(view).unf Unfinished output of |
614 |
.I rpict |
615 |
.SH AUTHOR |
616 |
Greg Ward |
617 |
.SH BUGS |
618 |
Incremental building of octrees is not supported as it would add |
619 |
considerable complexity to |
620 |
.I rad. |
621 |
Complicated scene builds should still be left to |
622 |
.I make(1), |
623 |
which has a robust mechanism for handling hierarchical |
624 |
dependencies. |
625 |
If |
626 |
.I make |
627 |
is used in this fashion, then only the |
628 |
"OCTREE" variable of |
629 |
.I rad |
630 |
is needed. |
631 |
.PP |
632 |
The use of some |
633 |
.I pfilt |
634 |
options is awkward, since the "EXPOSURE" variable results in a |
635 |
single pass invocation (the |
636 |
.I \-1 |
637 |
option of |
638 |
.I pfilt\) |
639 |
and two passes are necessary for certain effects, such as star |
640 |
patterns. |
641 |
The way around this problem is to specify |
642 |
a "RAWFILE" that is the same as the "PICTURE" variable so that no |
643 |
filtering takes place, then call |
644 |
.I pfilt |
645 |
manually. |
646 |
This is preferable to leaving out the |
647 |
"EXPOSURE" variable, since the exposure level is needed to |
648 |
accurately determine the ambient value for |
649 |
.I rpict. |
650 |
.PP |
651 |
The use of upper and lower case naming for the standard views may be |
652 |
problematic on systems that don't distinguish case in filenames. |
653 |
.SH "SEE ALSO" |
654 |
glrad(1), make(1), mkillum(1), objview(1), oconv(1), |
655 |
pfilt(1), raddepend(1), ranimate(1), |
656 |
rholo(1), rpict(1), rtrace(1), rview(1), touch(1), vgaimage(1), ximage(1) |
