root/radiance/ray/doc/man/man1/rad.1
Fri Jan 1 19:14:43 2021 UTC (4 years, 5 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.11: +5 -3 lines
Diff to previous 1.11
docs(rad): Added note about bias compensation in PCMAP and PGMAP settings
Tue May 26 10:00:46 2015 UTC (10 years ago) by greg
CVS Tags: rad5R0, rad5R1, rad5R2, rad5R3
Changes since 1.10: +30 -2 lines
Diff to previous 1.10
Thu Jun 16 14:22:08 2011 UTC (13 years, 11 months ago) by greg
Diff to previous 1.9
Added space between alternate options
Tue May 18 00:32:23 2010 UTC (15 years ago) by greg
Changes since 1.8: +18 -2 lines
Diff to previous 1.8
Added ability to call rpiece with -N >1 on a single view
Thu Dec 18 23:26:57 2008 UTC (16 years, 5 months ago) by greg
Changes since 1.7: +25 -1 lines
Diff to previous 1.7
Mon Nov 10 19:08:17 2008 UTC (16 years, 7 months ago) by greg
Diff to previous 1.6
Tue Mar 11 02:21:45 2008 UTC (17 years, 3 months ago) by greg
Diff to previous 1.5
Tue Sep 4 17:36:40 2007 UTC (17 years, 9 months ago) by greg
Changes since 1.4: +15 -15 lines
Diff to previous 1.4
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Thu Jan 1 19:31:45 2004 UTC (21 years, 5 months ago) by greg
Changes since 1.3: +13 -13 lines
Diff to previous 1.3
Tue Dec 9 15:59:06 2003 UTC (21 years, 6 months ago) by greg
Diff to previous 1.2
Fixed RCSid specification
Thu Jul 3 15:00:19 2003 UTC (21 years, 11 months ago) by greg
Changes since 1.1: +8 -1 lines
Tue Mar 11 19:20:21 2003 UTC (22 years, 3 months ago) by greg
Added documentation to repository
