root/radiance/ray/doc/man/man1/rad.1
Revision: 1.11
Committed: Tue May 26 10:00:46 2015 UTC (9 years, 11 months ago) by greg
CVS Tags: rad5R2, rad5R0, rad5R1, rad5R3
Changes since 1.10: +30 -2 lines
1 .\" RCSid "$Id: rad.1,v 1.10 2011/06/16 14:22:08 greg Exp $"
2 .TH RAD 1 2/1/99 RADIANCE
3 .SH NAME
4 rad - render a RADIANCE scene
5 .SH SYNOPSIS
6 .B rad
7 [
8 .B \-s
9 ][
10 .B "-n | -N npr"
11 ][
12 .B \-t
13 ][
14 .B \-e
15 ][
16 .B \-V
17 ][
18 .B \-w
19 ][
20 .B "\-v view"
21 ][
22 .B "\-o device"
23 ]
24 .B rfile
25 [
26 .B "VAR\=value .."
27 ]
28 .SH DESCRIPTION
29 .I Rad
30 is an executive program that reads the given
31 .I rfile
32 and makes appropriate calls to
33 .I oconv(1),
34 .I mkillum(1),
35 .I rpict(1),
36 .I pfilt(1),
37 and/or
38 .I rvu(1)
39 to render a specific scene.
40 Variables in
41 .I rfile
42 give input files and qualitative information about the rendering(s)
43 desired that together enable
44 .I rad
45 to intelligently set parameter values and control the simulation.
46 .PP
47 Normally, commands are echoed to the standard output as they are
48 executed.
49 The
50 .I \-s
51 option tells
52 .I rad
53 to do its work silently.
54 The
55 .I \-n
56 option tells
57 .I rad
58 not to take any action (ie. not to actually execute any commands).
59 The
60 .I \-N
61 option instructs
62 .I rad
63 to run as many as
64 .I npr
65 rendering processes in parallel.
66 The
67 .I \-t
68 option tells
69 .I rad
70 to bring rendering files up to date relative to the input
71 (scene description) files, without performing any actual
72 calculations.
73 If no octree exists, it is still necessary to run
74 .I oconv(1)
75 to create one, since the
76 .I \-t
77 option will not create invalid (i.e. empty) files, and
78 a valid octree is necessary for the correct operation of
79 .I rad.
80 The
81 .I \-e
82 option tells
83 .I rad
84 to explicate all variables used for the simulation, including
85 default values not specified in the input file, and print them on
86 the standard output.
87 .PP
88 Normally,
89 .I rad
90 will produce one picture for each view given in
91 .I rfile.
92 The
93 .I \-v
94 option may be used to specify a single desired view.
95 The
96 .I view
97 argument may either be a complete view specification
98 (enclosed in quotes and beginning with an optional identifier)
99 or a number or single-word identifier to match a view defined in
100 .I rfile.
101 If the argument is one of the standard view identifiers,
102 it may or may not be further elaborated in
103 .I rfile.
104 (See "view" variable description, below.)\0
105 If the argument does not match any views in
106 .I rfile
107 and is not one of the standard views, no rendering will take place.
108 This may be convenient when the only action desired of
109 .I rad
110 is the rebuilding of the octree.
111 In particular, the argument "0" will never match a view.
112 .PP
113 If the
114 .I \-V
115 option is given,
116 each view will be printed on the standard output before
117 being applied, in a form suitable for use in a view file or
118 .I rpict
119 rendering sequence.
120 This is helpful as feedback or for accessing the
121 .I rad
122 view assignments without necessarily starting a rendering.
123 .PP
124 By default,
125 .I rad
126 will run
127 .I rpict
128 and
129 .I pfilt
130 to produce a picture for each view.
131 The
132 .I \-o
133 option specifies an output device for
134 .I rvu
135 (usually "x11")
136 and runs this interactive program instead, using the first view in
137 .I rfile
138 or the view given with the
139 .I \-v
140 option as the starting point.
141 .PP
142 Additional variable settings may be added or overridden on the
143 command line following
144 .I rfile.
145 Upper case variables specified more than once will result in
146 a warning message (unless the
147 .I \-w
148 option is present),
149 and the last value given will be the one used.
150 .PP
151 The
152 .I \-w
153 option turns off warnings about multiply and misassigned variables.
154 .PP
155 Rendering variable assignments appear one per line in
156 .I rfile.
157 The name of the variable is followed by an equals sign
158 ('=') and its value(s).
159 The end of line may be escaped with a backslash ('\\'), though it is
160 not usually necessary since additional variable values may be given
161 in multiple assignments.
162 Variables that should have only one value are given in upper case.
163 Variables that may have multiple values are given in lower case.
164 Variables may be abbreviated by their first three letters.
165 Comments in
166 .I rfile
167 start with a pound sign ('#') and proceed to the end of line.
168 .PP
169 The rendering variables, their interpretations and default values
170 are given below.
171 .TP 10n
172 .BR OCTREE
173 The name of the octree file.
174 The default name is the same as
175 .I rfile
176 but with any suffix replaced by ".oct".
177 (The octree must be a file --
178 .I rad
179 cannot work with commands that produce octrees.)\0
180 .TP
181 .BR ZONE
182 This variable specifies the volume of interest for this simulation.
183 The first word is either "Interior" or "Exterior", depending on
184 whether the zone is to be observed from the inside or the outside,
185 respectively.
186 (A single letter may be given, and case does not matter.)\0
187 The following six numbers are the minimum and maximum
188 X coordinates, minimum and maximum Y, and minimum and maximum Z
189 for the zone perimeter.
190 It is important to give the zone as it is used to determine many of
191 the rendering parameters.
192 The default exterior zone is the bounding cube for the scene as
193 computed by
194 .I oconv.
195 .TP
196 .BR EXPOSURE
197 This variable tells
198 .I rad
199 how to adjust the exposure for display.
200 It is important to set this variable properly as it is used to
201 determine the ambient value.
202 An appropriate setting may be discovered by running
203 .I rvu
204 and noting the exposure given by the "exposure =" command.
205 As in
206 .I rvu
207 and
208 .I pfilt,
209 the exposure setting may be given either as a multiplier or as a
210 number of f\-stop adjustments (eg. +2 or \-1.5).
211 There is no default value for this variable.
212 If it is not given, an average level will be computed by
213 .I pfilt
214 and the ambient value will be set to 10 for exterior zones
215 and 0.01 for interior zones.
216 .TP
217 .BR EYESEP
218 The interocular spacing for stereo viewing.
219 I.e., the world distance between the pupils of the left and right eyes.
220 The default value is the sum of the three "ZONE" dimensions divided by 100.
221 .TP
222 .BR scene
223 This variable is used to specify one or more scene input files.
224 These files will be given together with the materials file(s)
225 and any options specified by the "oconv" variable to
226 .I oconv
227 to produce the octree given by the "OCTREE" variable.
228 In-line commands may be specified in quotes instead of a file,
229 beginning with an exclamation mark ('!').
230 If the "scene" variable is not present, then the octree must already exist
231 in order for
232 .I rad
233 to work.
234 Even if this variable is given,
235 .I oconv
236 will not be run unless the octree is out of date with respect to
237 the input files.
238 Note that the order of files in this variable is important for
239 .I oconv
240 to work properly, and files given in later variable assignments will
241 appear after previous ones on the
242 .I oconv
243 command line.
244 .TP
245 .BR materials
246 This variable is used to specify files that, although they must
247 appear on the
248 .I oconv
249 command line, do not affect the actual octree itself.
250 Keeping the materials in separate files allows them to be modified
251 without requiring the octree to be rebuilt (a sometimes costly
252 procedure).
253 These files should not contain any geometry, and the
254 .I \-f
255 option must not be given in the "oconv" variable for this to work.
256 .TP
257 .BR illum
258 This variable is used to specify files with surfaces to be converted into
259 illum sources by
260 .I mkillum(1).
261 When this variable is given, additional octree files will be created
262 to contain the scene before and after illum source conversion.
263 These files will be named according to the (default) value of the
264 .I OCTREEE
265 variable, with either a '0' or a '1' appearing just before the file
266 type suffix (usually ".oct").
267 .TP
268 .BR objects
269 This variable is used for files that, although they do not appear
270 on the
271 .I oconv
272 command line, contain geometric information that is referenced
273 indirectly by the scene files.
274 If any of these files is changed, the octree will be rebuilt.
275 (The
276 .I raddepend(1)
277 command may be used to find these dependencies automatically.)\0
278 .TP
279 .BR view
280 This variable is used to specify a desired view for this zone.
281 Any number of "view" lines may be given, and each will result in a
282 rendered picture (unless the
283 .I \-v
284 or
285 .I \-o
286 option is specified).
287 The value for this variable is an optional identifier followed by
288 any number of view options (see
289 .I rpict(1)
290 for a complete listing).
291 The identifier is used in file naming and associating a desired view
292 with the
293 .I \-v
294 command line option.
295 Also, there are several standard view identifiers defined by
296 .I rad.
297 These standard views are specified by strings of the form
298 "[Xx]?[Yy]?[Zz]?[vlcahs]?".
299 (That is, an optional upper or lower case X followed by an optional
300 upper or lower case Y followed by an optional upper or lower case Z
301 followed by an optional lower case V, L, C, A or H.)\0
302 The letters indicate the desired view position, where upper case X
303 means maximum X, lower case means minimum and so on.
304 The final letter is the view type, where 'v' is perspective (the
305 default), 'l' is parallel, 'c' is a cylindrical panorama,
306 'a' is angular fisheye, 'h' is hemispherical fisheye, and 's'
307 is a planisphere (stereographic) fisheye.
308 A perspective view from maximum X, minimum Y would be "Xy" or "Xyv".
309 A parallel view from maximum Z would be "Zl".
310 If "ZONE" is an interior zone, the standard views will
311 be inside the perimeter.
312 If it is an exterior zone, the standard views will be outside.
313 Note that the standard views are best used as starting points,
314 and additional arguments may be given after the
315 identifier to modify a standard view to suit a particular model.
316 The default view is "X" if no views are specified.
317 A single specified view of "0" means no views will be automatically
318 generated.
319 .TP
320 .BR UP
321 The vertical axis for this scene.
322 A negative axis may be specified with a minus sign (eg. "\-Y").
323 There is no default value for this variable, although the standard
324 views assume Z is up if no other axis is specified.
325 .TP
326 .BR RESOLUTION
327 This variable specifies the desired final picture resolution.
328 If only a single number is given, this value will be used for both
329 the horizontal and vertical picture dimensions.
330 If two numbers are given, the first is the horizontal resolution and
331 the second is the vertical resolution.
332 If three numbers are given, the third is taken as the pixel aspect
333 ratio for the final picture (a real value).
334 If the pixel aspect ratio is zero, the exact dimensions given will
335 be those produced.
336 Otherwise, they will be used as a frame in which the final image
337 must fit.
338 The default value for this variable is 512.
339 .TP
340 .BR QUALITY
341 This variable sets the overall rendering quality desired.
342 It can have one of three values, "LOW", "MEDIUM" or "HIGH".
343 These may be abbreviated by their first letter, and may be
344 in upper or lower case.
345 Most of the rendering options will be affected by this setting.
346 The default value is "L".
347 .TP
348 .BR PENUMBRAS
349 This is a boolean variable indicating whether or not penumbras are
350 desired.
351 A value of "TRUE" will result in penumbras (soft shadows), and a
352 value of "FALSE" will result in no penumbras (sharp shadows).
353 True and false may be written in upper or lower case, and may be
354 abbreviated by a single letter.
355 Renderings generally proceed much faster without penumbras.
356 The default value is "F".
357 .TP
358 .BR INDIRECT
359 This variable indicates how many diffuse reflections are important in the
360 general lighting of this zone.
361 A direct lighting system (eg. fluorescent troffers recessed in the
362 ceiling) corresponds to an indirect level of 0.
363 An indirect lighting system (eg. hanging fluorescents directed at a
364 reflective ceiling) corresponds to an indirect level of 1.
365 A diffuse light shelf reflecting sunlight onto the ceiling would
366 correspond to an indirect level of 2.
367 The setting of this variable partially determines how many interreflections
368 will be calculated.
369 The default value is 0.
370 .TP
371 .BR PICTURE
372 This is the root name of the output picture file(s).
373 This name will have appended the view identifier (or a number if no
374 id was used) and a ".hdr" suffix.
375 If a picture corresponding to a specific view exists and is not out
376 of date with respect to the given octree, it will not be
377 re-rendered.
378 The default value for this variable is the root portion of
379 .I rfile.
380 .TP
381 .BR RAWFILE
382 This is the root name of the finished, raw
383 .I rpict
384 output file.
385 If specified,
386 .I rad
387 will rename the original
388 .I rpict
389 output file once it is finished and filtered
390 rather than removing it, which is the default action.
391 The given root name will be expanded in the same way as the
392 "PICTURE" variable, and if the "RAWFILE" and "PICTURE" variables
393 are identical, then no filtering will take place.
394 .TP
395 .BR ZFILE
396 This is the root name of the raw distance file produced by the
397 .I \-z
398 option of
399 .I rpict.
400 To this root name, an underscore plus the view name plus a ".zbf"
401 suffix will be added.
402 If no "ZFILE" is specified, none will be produced.
403 .TP
404 .BR AMBFILE
405 This is the name of the file where "ambient" or diffuse interreflection
406 values will be stored by
407 .I rpict
408 or
409 .I rvu.
410 Although it is not required, an ambient file should be given whenever
411 an interreflection calculation is expected.
412 This will optimize successive runs and minimize artifacts.
413 An interreflection calculation will take place when the
414 "QUALITY" variable is set to HIGH, or when the "QUALITY"
415 variable is set to MEDIUM and "INDIRECT" is positive.
416 There is no default value for this variable.
417 .TP
418 .BR DETAIL
419 This variable specifies the level of visual detail in this zone,
420 and is used to determine image sampling rate, among other things.
421 If there are few surfaces and simple shading, then this should be set
422 to LOW.
423 For a zone with some furniture it might be set to MEDIUM.
424 If the space is very cluttered or contains a lot of geometric detail
425 and textures, then it should be set to HIGH.
426 The default value is "M".
427 .TP
428 .BR VARIABILITY
429 This variable tells
430 .I rad
431 how much light varies over the surfaces of this zone, and is
432 used to determine what level of sampling is necessary in the
433 indirect calculation.
434 For an electric lighting system with uniform coverage, the value
435 should be set to LOW.
436 For a space with spot lighting or a window with sky illumination
437 only, it might be set to MEDIUM.
438 For a space with penetrating sunlight casting bright patches in a
439 few places, it should be set to HIGH.
440 The default value is "L".
441 .TP
442 .BR PGMAP
443 This variable designates a global photon map to be generated by
444 .I mkpmap(1)
445 and used to accelerate rendering.
446 The file name must be followed by the number of photons to be stored
447 in the map, and this number may be followed by a bandwidth for rendering.
448 There is no default value, meaning that a global photon map will not
449 normally be created.
450 .TP
451 .BR PCMAP
452 This variable designates a caustic photon map to be generated by
453 .I mkpmap(1)
454 and used during renderings to model light transmission by reflecting
455 and refracting surfaces.
456 The file name must be followed by the number of photons to be stored
457 in the map, and this number may be followed by a bandwidth for rendering.
458 There is no default value, meaning that a caustic photon map will not
459 normally be created.
460 .TP
461 .BR OPTFILE
462 This is the name of a file in which
463 .I rad
464 will place the appropriate rendering options.
465 This file can later be accessed by
466 .I rpict
467 or
468 .I rvu
469 in subsequent manual runs using the at-sign ('@') file insert option.
470 (Using an "OPTFILE" also reduces the length of the rendering
471 command, which improves appearance and may even be necessary on some
472 systems.)\0
473 There is no default value for this variable.
474 .TP
475 .BR REPORT
476 This variable may be used to specify a reporting interval for
477 batch rendering.
478 Given in minutes, this value is multiplied by 60 and passed to
479 .I rpict
480 with the
481 .I \-t
482 option.
483 If a filename is given after the interval, it will be used as the
484 error file for reports and error messages instead of the standard error.
485 (See the
486 .I \-e
487 option of
488 .I rpict(1).\)\0
489 There is no default value for this variable.
490 .TP
491 .BR oconv
492 This variable may be used to specify special options to
493 .I oconv.
494 If the first word of the first instance of this variable is not an option,
495 it will be used in place of the default command path, "oconv".
496 See the
497 .I oconv(1)
498 manual page for a list of valid options.
499 .TP
500 .BR mkillum
501 This variable may be used to specify additional options to
502 .I mkillum.
503 If the first word of the first instance of this variable is not an option,
504 it will be used in place of the default command path, "mkillum".
505 See the
506 .I rtrace(1)
507 manual page for a list of valid options.
508 .TP
509 .BR mkpmap
510 This variable may be used to specify additional options to
511 .I mkpmap.
512 If the first word of the first instance of this variable is not an option,
513 it will be used in place of the default command path, "mkpmap".
514 See the
515 .I mkpmap(1)
516 manual page for a list of valid options.
517 .TP
518 .BR render
519 This variable may be used to specify additional options to
520 .I rpict
521 or
522 .I rvu.
523 These options will appear after the options set automatically by
524 .I rad,
525 and thus will override the default values.
526 .TP
527 .BR rpict
528 This variable may be used to specify overriding options specific to
529 .I rpict.
530 If the first word of the first instance of this variable is not an option,
531 it will be used in place of the default command path, "rpict".
532 See the
533 .I rpict(1)
534 man page for a list of valid options.
535 .TP
536 .BR rvu
537 This variable may be used to specify overriding options specific to
538 .I rvu.
539 If the first word of the first instance of this variable is not an option,
540 it will be used in place of the default command path, "rvu".
541 See the
542 .I rvu(1)
543 man page for a list of valid options.
544 .TP
545 .BR pfilt
546 This variable may be used to specify additional options to
547 .I pfilt.
548 If the first word of the first instance of this variable is not an option,
549 it will be used in place of the default command path, "pfilt".
550 See the
551 .I pfilt(1)
552 manual page for details.
553 .SH EXAMPLES
554 A minimal input file for
555 .I rad
556 might look like this:
557 .IP "" .3i
558 .nf
559 ::::::::::
560 sample.rif
561 ::::::::::
562 # The octree we want to use:
563 OCTREE= tutor.oct # w/o this line, name would be "sample.oct"
564 # Our scene input files:
565 scene= sky.rad outside.rad room.rad srcwindow.rad
566 # The interior zone cavity:
567 ZONE= I 0 3 0 2 0 1.75 # default would be scene bounding cube
568 # The z-axis is up:
569 UP= Z # no default - would use view spec.
570 # Our exposure needs one f-stop boost:
571 EXPOSURE= +1 # default is computed ex post facto
572 .fi
573 .PP
574 Note that we have not specified any views in the file above.
575 The standard default view "X" would be used if we were to run
576 .I rad
577 on this file.
578 If we only want to see what default values
579 .I rad
580 would use without actually executing anything, we can invoke it thus:
581 .IP "" .2i
582 rad \-n \-e sample.rif
583 .PP
584 This will print the variables we have given as well as default
585 values
586 .I rad
587 has assigned for us.
588 Also, we will see the list of commands that
589 .I rad
590 would have executed had the
591 .I \-n
592 option not been present.
593 (Note if the octree, "tutor.oct", is not present, an error will
594 result as it is needed to determine some of the opiton settings.)\0
595 .PP
596 Different option combinations have specific uses, ie:
597 .IP "" .2i
598 .br
599 rad \-v 0 sample.rif OPT=samp.opt # build octree, put options in "sample.opt"
600 .br
601 rad \-n \-e \-s sample.rif > full.rif # make a complete rad file
602 .br
603 rad \-n sample.rif > script.sh # make a script of commands
604 .br
605 rad \-V \-v Zl \-n \-s sample.rif > plan.vf # make a plan view file
606 .br
607 rad \-t sample.rif # update files after minor change to input
608 .br
609 rad \-s sample.rif & # execute silently in the background
610 .br
611 rad \-N 2 sample.rif # render views using two parallel rpict calls
612 .br
613 rad \-N 4 -v 1 sample.rif # render first view with four rpiece calls
614 .PP
615 If we decide that the default values
616 .I rad
617 has chosen for our variables are not all appropriate, we can add
618 some more assignments to the file:
619 .IP "" .3i
620 .nf
621 QUAL= MED # default was low
622 DET= low # default was medium - our space is almost empty
623 PEN= True # we want to see soft shadows from our window
624 VAR= hi # daylight can result in fairly harsh lighting
625 view= XYa \-vv 120 # let's try a fisheye view
626 PICT= tutor # our picture name will be "tutor_XYa.hdr"
627 .fi
628 .PP
629 Note the use of abbreviations, and the modification of a standard
630 view.
631 Now we can invoke
632 .I rad
633 to take a look at our scene interactively with
634 .I rvu:
635 .IP "" .2i
636 rad \-o x11 sample.rif
637 .PP
638 .I Rad
639 will run
640 .I oconv
641 first to create the octree (assuming it doesn't
642 already exist), then
643 .I rvu
644 with a long list of options.
645 Let's say that from within
646 .I rvu,
647 we wrote out the view files "view1.vp" and "view2.vp".
648 We could add these to "sample.rif" like so:
649 .IP "" .2i
650 .nf
651 view= vw1 \-vf view1.vp # Our first view
652 view= vw2 \-vf view2.vp # Our second view
653 RESOLUTION= 1024 # Let's go for a higher resolution result
654 .fi
655 .PP
656 To start
657 .I rvu
658 again using vw2 instead of the default, we use:
659 .IP "" .2i
660 rad \-o x11 \-v vw2 sample.rif
661 .PP
662 Once we are happy with the variable settings in our file, we can run
663 .I rad
664 in the background to produce one image for each view:
665 .IP "" .2i
666 rad sample.rif REP=5 >& errfile &
667 .PP
668 This will report progress every five minutes to "errfile".
669 .SH FILES
670 $(PICTURE)_$(view).unf Unfinished output of
671 .I rpict
672 .SH AUTHOR
673 Greg Ward
674 .SH BUGS
675 You cannot run more than one
676 .I rad
677 process at a time on the same input file,
678 as the second process will attempt to recover the output files
679 of the first process, damaging the results.
680 The exceptions to this are running interactively via the
681 .I \-o
682 option, or rendering different views using the
683 .I \-v
684 option.
685 .PP
686 Incremental building of octrees is not supported as it would add
687 considerable complexity to
688 .I rad.
689 Complicated scene builds should still be left to
690 .I make(1),
691 which has a robust mechanism for handling hierarchical
692 dependencies.
693 If
694 .I make
695 is used in this fashion, then only the
696 "OCTREE" variable of
697 .I rad
698 is needed.
699 .PP
700 The use of some
701 .I pfilt
702 options is awkward, since the "EXPOSURE" variable results in a
703 single pass invocation (the
704 .I \-1
705 option of
706 .I pfilt\)
707 and two passes are necessary for certain effects, such as star
708 patterns.
709 The way around this problem is to specify
710 a "RAWFILE" that is the same as the "PICTURE" variable so that no
711 filtering takes place, then call
712 .I pfilt
713 manually.
714 This is preferable to leaving out the
715 "EXPOSURE" variable, since the exposure level is needed to
716 accurately determine the ambient value for
717 .I rpict.
718 .PP
719 The use of upper and lower case naming for the standard views may be
720 problematic on systems that don't distinguish case in filenames.
721 .SH "SEE ALSO"
722 glrad(1), make(1), mkillum(1), mkpmap(1), objview(1), oconv(1),
723 pfilt(1), raddepend(1), ranimate(1),
724 rholo(1), rpict(1), rpiece(1), rtrace(1), rvu(1),
725 touch(1), vgaimage(1), ximage(1)
