--- ray/doc/man/man1/ra_xyze.1 2006/08/22 21:38:21 1.3 +++ ray/doc/man/man1/ra_xyze.1 2010/12/16 21:34:41 1.6 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: ra_xyze.1,v 1.3 2006/08/22 21:38:21 greg Exp $" +.\" RCSid "$Id: ra_xyze.1,v 1.6 2010/12/16 21:34:41 greg Exp $" .TH RA_XYZE 1 5/30/96 RADIANCE .SH NAME ra_xyze - convert between RADIANCE RGBE and XYZE formats @@ -64,7 +64,7 @@ CIE (x,y) chromaticity coordinates of the three RGB pr plus the white point, in that order. The new primaries will be recorded in the header of the output file, so that the original information may be fully recovered later. -It is not necessary that the input file by in XYZE format. +It is not necessary that the input file be in XYZE format. Th .I \-r option may therefore be used to convert from one RGB primary @@ -101,11 +101,11 @@ To convert RGBE output from .I rpict(1) into run-length encoded XYZE format: .IP "" .2i -rpict [options] scene.oct | ra_xyze -c > scene_xyz.pic +rpict [options] scene.oct | ra_xyze \-c > scene_xyz.hdr .PP To prepare a RADIANCE picture for display on a calibrated NTSC monitor: .IP "" .2i -ra_xyze -r -p .670 .330 .210 .710 .140 .080 .333 .333 stand.pic ntsc.pic +ra_xyze \-r \-p .670 .330 .210 .710 .140 .080 .333 .333 stand.hdr ntsc.hdr .SH AUTHOR Greg Ward .SH BUGS @@ -126,4 +126,4 @@ options first. COLORCORR= lines multiplied together.) Better still, get the picture before color correction is applied. .SH "SEE ALSO" -pfilt(1), ra_rgbe(1), rpict(1) +pfilt(1), pvalue(1), ra_rgbe(1), rpict(1)
