--- ray/doc/man/man1/ra_xyze.1 2003/12/09 15:59:06 1.2 +++ ray/doc/man/man1/ra_xyze.1 2007/09/04 17:36:40 1.4 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: ra_xyze.1,v 1.2 2003/12/09 15:59:06 greg Exp $" +.\" RCSid "$Id: ra_xyze.1,v 1.4 2007/09/04 17:36:40 greg Exp $" .TH RA_XYZE 1 5/30/96 RADIANCE .SH NAME ra_xyze - convert between RADIANCE RGBE and XYZE formats @@ -9,6 +9,8 @@ ra_xyze - convert between RADIANCE RGBE and XYZE forma ][ .B "\-e exposure" ][ +.B \-o +][ .B \-c | .B \-u @@ -29,6 +31,11 @@ The .I \-e option specifies an exposure compensation, which may be given as a decimal multiplier or in f-stops (powers of two). +The +.I \-o +option may be used to specify original units, to which the exposure +compensation is applied. +Otherwise, the multiplier is in addition to any previous exposure adjustment. By default, .I ra_xyze produces a flat XYZE RADIANCE picture file from any type of RADIANCE @@ -44,7 +51,9 @@ The .I \-r option causes .I ra_xyze -to produce a run-length encoded RGBE file instead. +to produce a run-length encoded RGBE file instead, unless +.I \-u +is given, also, when it will produce a flat RGBE file. The .I \-p option may be used to override the standard RADIANCE RGB primary @@ -92,11 +101,11 @@ To convert RGBE output from .I rpict(1) into run-length encoded XYZE format: .IP "" .2i -rpict [options] scene.oct | ra_xyze -c > scene_xyz.pic +rpict [options] scene.oct | ra_xyze \-c > scene_xyz.pic .PP To prepare a RADIANCE picture for display on a calibrated NTSC monitor: .IP "" .2i -ra_xyze -r -p .670 .330 .210 .710 .140 .080 .333 .333 stand.pic ntsc.pic +ra_xyze \-r \-p .670 .330 .210 .710 .140 .080 .333 .333 stand.pic ntsc.pic .SH AUTHOR Greg Ward .SH BUGS
