root/Development/ray/doc/man/man1/ra_xyze.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 7 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH RA_XYZE 1 5/30/96 RADIANCE
3 .SH NAME
4 ra_xyze - convert between RADIANCE RGBE and XYZE formats
5 .SH SYNOPSIS
6 .B ra_xyze
7 [
8 .B \-r
9 ][
10 .B "\-e exposure"
11 ][
12 .B \-c
13 |
14 .B \-u
15 ][
16 .B "\-p xr yr xg yg xb yb xw yw"
17 ]
18 [
19 .B input
20 [
21 .B output
22 ]
23 ]
24 .SH DESCRIPTION
25 .I Ra_xyze
26 converts between RADIANCE RGBE (red,green,blue,exponent) and XYZE
27 (CIE X,Y,Z,exponent) formats.
28 The
29 .I \-e
30 option specifies an exposure compensation, which may be given as
31 a decimal multiplier or in f-stops (powers of two).
32 By default,
33 .I ra_xyze
34 produces a flat XYZE RADIANCE picture file from any type of RADIANCE
35 input picture.
36 To override these defaults, the
37 .I \-c
38 option may be used to specify run-length encoded output,
39 or the
40 .I \-u
41 option may be used to specify a flat output.
42 .PP
43 The
44 .I \-r
45 option causes
46 .I ra_xyze
47 to produce a run-length encoded RGBE file instead.
48 The
49 .I \-p
50 option may be used to override the standard RADIANCE RGB primary
51 colors to tailor the image for a particular output device or
52 representation.
53 The eight floating-point arguments to this option are the 1931
54 CIE (x,y) chromaticity coordinates of the three RGB primaries
55 plus the white point, in that order.
56 The new primaries will be recorded in the header of the output file,
57 so that the original information may be fully recovered later.
58 It is not necessary that the input file by in XYZE format.
59 Th
60 .I \-r
61 option may therefore be used to convert from one RGB primary
62 representation to another using the
63 .I \-p
64 option.
65 .PP
66 If the output file is missing, the standard output is used.
67 If the input file is missing as well, the standard input is used.
68 .SH NOTES
69 The CIE standard used is the 1931 2-degree observer, and the
70 correct output representation relies on the original RADIANCE
71 input description being defined properly in terms of the standard
72 RADIANCE RGB primaries, whose CIE (x,y) chromaticity values are
73 defined in the header file in src/common/color.h.
74 In this same file is a standard for the luminous efficacy of white
75 light (WHTEFFICACY), which is used as a conversion between lumens
76 and watts throughout RADIANCE.
77 This same factor is applied by
78 .I ra_xyze
79 when converting between the radiometric units of the RGBE format
80 and the photometric units of the XYZE format.
81 The purpose of this factor is to ensure that the Y component of
82 the CIE representation is luminance in units of candelas/meter^2.
83 .PP
84 Most of the RADIANCE picture filters should work uniformly on either
85 RGBE or XYZE files, so it is not necessary to convert back to RGBE
86 format except for conversion or display, in which case the correct
87 primaries for the chosen output device should be specified with the
88 .I \-p
89 option if they are known.
90 .SH EXAMPLES
91 To convert RGBE output from
92 .I rpict(1)
93 into run-length encoded XYZE format:
94 .IP "" .2i
95 rpict [options] scene.oct | ra_xyze -c > scene_xyz.pic
96 .PP
97 To prepare a RADIANCE picture for display on a calibrated NTSC monitor:
98 .IP "" .2i
99 ra_xyze -r -p .670 .330 .210 .710 .140 .080 .333 .333 stand.pic ntsc.pic
100 .SH AUTHOR
101 Greg Ward
102 .SH BUGS
103 Any color correction applied to the original image is not removed
104 or translated by
105 .I ra_xyze,
106 and it may result in color shifts in the output.
107 If color preservation is important and the correction is unwanted,
108 it is best to remove it with
109 .I pfilt(1)
110 using the
111 .I \-er,
112 .I \-eg
113 and
114 .I \-eb
115 options first.
116 (Simply look at the header and apply the reciprocal primaries of all
117 COLORCORR= lines multiplied together.)
118 Better still, get the picture before color correction is applied.
119 .SH "SEE ALSO"
120 pfilt(1), ra_rgbe(1), rpict(1)
