1 |
greg |
1.3 |
.\" RCSid "$Id: ra_xyze.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
2 |
greg |
1.1 |
.TH RA_XYZE 1 5/30/96 RADIANCE |
3 |
.SH NAME |
4 |
ra_xyze - convert between RADIANCE RGBE and XYZE formats |
5 |
.SH SYNOPSIS |
6 |
.B ra_xyze |
7 |
8 |
.B \-r |
9 |
10 |
.B "\-e exposure" |
11 |
12 |
greg |
1.3 |
.B \-o |
13 |
14 |
greg |
1.1 |
.B \-c |
15 |
16 |
.B \-u |
17 |
18 |
.B "\-p xr yr xg yg xb yb xw yw" |
19 |
20 |
21 |
.B input |
22 |
23 |
.B output |
24 |
25 |
26 |
.SH DESCRIPTION |
27 |
.I Ra_xyze |
28 |
converts between RADIANCE RGBE (red,green,blue,exponent) and XYZE |
29 |
(CIE X,Y,Z,exponent) formats. |
30 |
The |
31 |
.I \-e |
32 |
option specifies an exposure compensation, which may be given as |
33 |
a decimal multiplier or in f-stops (powers of two). |
34 |
greg |
1.3 |
The |
35 |
.I \-o |
36 |
option may be used to specify original units, to which the exposure |
37 |
compensation is applied. |
38 |
Otherwise, the multiplier is in addition to any previous exposure adjustment. |
39 |
greg |
1.1 |
By default, |
40 |
.I ra_xyze |
41 |
produces a flat XYZE RADIANCE picture file from any type of RADIANCE |
42 |
input picture. |
43 |
To override these defaults, the |
44 |
.I \-c |
45 |
option may be used to specify run-length encoded output, |
46 |
or the |
47 |
.I \-u |
48 |
option may be used to specify a flat output. |
49 |
.PP |
50 |
The |
51 |
.I \-r |
52 |
option causes |
53 |
.I ra_xyze |
54 |
greg |
1.3 |
to produce a run-length encoded RGBE file instead, unless |
55 |
.I \-u |
56 |
is given, also, when it will produce a flat RGBE file. |
57 |
greg |
1.1 |
The |
58 |
.I \-p |
59 |
option may be used to override the standard RADIANCE RGB primary |
60 |
colors to tailor the image for a particular output device or |
61 |
representation. |
62 |
The eight floating-point arguments to this option are the 1931 |
63 |
CIE (x,y) chromaticity coordinates of the three RGB primaries |
64 |
plus the white point, in that order. |
65 |
The new primaries will be recorded in the header of the output file, |
66 |
so that the original information may be fully recovered later. |
67 |
It is not necessary that the input file by in XYZE format. |
68 |
Th |
69 |
.I \-r |
70 |
option may therefore be used to convert from one RGB primary |
71 |
representation to another using the |
72 |
.I \-p |
73 |
option. |
74 |
.PP |
75 |
If the output file is missing, the standard output is used. |
76 |
If the input file is missing as well, the standard input is used. |
77 |
.SH NOTES |
78 |
The CIE standard used is the 1931 2-degree observer, and the |
79 |
correct output representation relies on the original RADIANCE |
80 |
input description being defined properly in terms of the standard |
81 |
RADIANCE RGB primaries, whose CIE (x,y) chromaticity values are |
82 |
defined in the header file in src/common/color.h. |
83 |
In this same file is a standard for the luminous efficacy of white |
84 |
light (WHTEFFICACY), which is used as a conversion between lumens |
85 |
and watts throughout RADIANCE. |
86 |
This same factor is applied by |
87 |
.I ra_xyze |
88 |
when converting between the radiometric units of the RGBE format |
89 |
and the photometric units of the XYZE format. |
90 |
The purpose of this factor is to ensure that the Y component of |
91 |
the CIE representation is luminance in units of candelas/meter^2. |
92 |
.PP |
93 |
Most of the RADIANCE picture filters should work uniformly on either |
94 |
RGBE or XYZE files, so it is not necessary to convert back to RGBE |
95 |
format except for conversion or display, in which case the correct |
96 |
primaries for the chosen output device should be specified with the |
97 |
.I \-p |
98 |
option if they are known. |
99 |
.SH EXAMPLES |
100 |
To convert RGBE output from |
101 |
.I rpict(1) |
102 |
into run-length encoded XYZE format: |
103 |
.IP "" .2i |
104 |
rpict [options] scene.oct | ra_xyze -c > scene_xyz.pic |
105 |
.PP |
106 |
To prepare a RADIANCE picture for display on a calibrated NTSC monitor: |
107 |
.IP "" .2i |
108 |
ra_xyze -r -p .670 .330 .210 .710 .140 .080 .333 .333 stand.pic ntsc.pic |
109 |
.SH AUTHOR |
110 |
Greg Ward |
111 |
.SH BUGS |
112 |
Any color correction applied to the original image is not removed |
113 |
or translated by |
114 |
.I ra_xyze, |
115 |
and it may result in color shifts in the output. |
116 |
If color preservation is important and the correction is unwanted, |
117 |
it is best to remove it with |
118 |
.I pfilt(1) |
119 |
using the |
120 |
.I \-er, |
121 |
.I \-eg |
122 |
and |
123 |
.I \-eb |
124 |
options first. |
125 |
(Simply look at the header and apply the reciprocal primaries of all |
126 |
COLORCORR= lines multiplied together.) |
127 |
Better still, get the picture before color correction is applied. |
128 |
.SH "SEE ALSO" |
129 |
pfilt(1), ra_rgbe(1), rpict(1) |
