root/radiance/ray/doc/man/man1/ra_tiff.1
Revision: 1.1
Committed: Sat Mar 15 17:32:55 2003 UTC (21 years, 2 months ago) by greg
1 .\" SCCSid "@(#)ra_tiff.1 2.3 8/29/97 LBL"
2 .TH RA_TIFF 1 8/29/97 RADIANCE
3 .SH NAME
4 ra_tiff - convert RADIANCE picture to/from a TIFF color or greyscale image
5 .SH SYNOPSIS
6 .B ra_tiff
7 [
8 .B "-z|-L|-l"
9 ][
10 .B -b
11 ][
12 .B "-e +/-stops"
13 ][
14 .B "-g gamma"
15 ]
16 {
17 .B "in.pic|-"
18 }
19 .B out.tif
20 .br
21 .B "ra_tiff -r"
22 [
23 .B \-x
24 ][
25 .B "\-g gamma"
26 ][
27 .B "\-e +/-stops"
28 ]
29 .B in.tif
30 [
31 .B "out.pic|-"
32 ]
33 .SH DESCRIPTION
34 .I Ra_tiff
35 converts between RADIANCE and TIFF image formats.
36 The
37 .I \-g
38 option specifies the exponent used in gamma correction;
39 the default value is 2.2, which is the recommended value
40 for TIFF images.
41 .PP
42 The
43 .I \-b
44 option can be used to specify an 8-bit greyscale TIFF output file.
45 The type of input file is determined automatically.
46 .PP
47 The
48 .I \-z
49 option will result in LZW compression of the TIFF output file.
50 The
51 .I \-L
52 option specifies SGILOG compression, which is recommended
53 to capture the full dynamic range of the Radiance picture.
54 However, since many TIFF readers do not yet support this format,
55 use this option under advisement.
56 The
57 .I \-l
58 option specifies SGILOG24 compressed output, which has slightly
59 less dynamic range than SGILOG, but may be smaller in some cases.
60 (It may also be larger in some cases.)\0
61 Decompression is automatically determined for TIFF input.
62 .PP
63 The
64 .I \-e
65 option specifies an exposure compensation in f-stops (powers of two).
66 Only integer stops are allowed, for efficiency.
67 .PP
68 The
69 .I \-r
70 option invokes a reverse conversion, from a TIFF image to
71 a RADIANCE picture.
72 The RADIANCE picture file can be taken from the standard input
73 or sent to the standard output by using a hyphen ('-') in place
74 of the file name, but the TIFF image must be to or from a file.
75 The
76 .I \-x
77 option can be used to specify an XYZE Radiance output file, rather
78 than the default RGBE.
79 .SH EXAMPLES
80 To convert a Radiance picture to SGILOG-compressed TIFF format:
81 .IP "" .2i
82 ra_tiff -L scene1.pic scene1.tif
83 .PP
84 To later convert this image back into Radiance and display using
85 human visibility tone-mapping:
86 .IP "" .2i
87 ra_tiff -r scene1.tif scene1.pic
88 .br
89 ximage -e human scene1.pic
90 .SH AUTHOR
91 Greg Ward Larson
92 .br
93 Sam Leffler
94 .SH ACKNOWLEDGEMENT
95 Work on this program was initiated and sponsored by the LESO
96 group at EPFL in Switzerland.
97 Additions for the SGILOG data encoding were sponsored by Silicon Graphics, Inc.
98 .SH BUGS
99 Many TIFF file subtypes are not supported.
100 .br
101 A gamma value other than 2.2 is not properly recorded or understood if
102 recorded in the TIFF file.
103 .SH "SEE ALSO"
104 pfilt(1), ra_bn(1), ra_ppm(1), ra_pr(1), ra_pr24(1), ra_t8(1),
105 ra_t16(1), ximage(1)
