| 1 |
.\" RCSid "$Id: ra_t16.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
| 2 |
.TH RA_T16 1 11/15/93 RADIANCE
| 3 |
.SH NAME
| 4 |
ra_t16 - convert RADIANCE picture to/from Targa 16 or 24-bit image file
| 5 |
.SH SYNOPSIS
| 6 |
.B ra_t16
| 7 |
| 8 |
.B \-2
| 9 |
| 10 |
.B \-3
| 11 |
| 12 |
.B "\-g gamma"
| 13 |
| 14 |
.B "\-e +/-stops"
| 15 |
| 16 |
| 17 |
.B input
| 18 |
| 19 |
.B output
| 20 |
| 21 |
| 22 |
.br
| 23 |
.B ra_t16
| 24 |
.B \-r
| 25 |
| 26 |
.B "\-g gamma"
| 27 |
| 28 |
.B "\-e +/-stops"
| 29 |
| 30 |
| 31 |
.B input
| 32 |
| 33 |
.B output
| 34 |
| 35 |
| 36 |
.SH DESCRIPTION
| 37 |
.I Ra_t16
| 38 |
converts between RADIANCE and Targa 16-bit or 24-bit RGB image files
| 39 |
(type 2 in Targa's documentation).
| 40 |
In the default mode, a RADIANCE picture is converted to an
| 41 |
RGB file of the same horizontal and vertical dimensions with
| 42 |
16-bits per pixel.
| 43 |
The
| 44 |
.I \-3
| 45 |
option tells the program to produce a 24-bit image file instead.
| 46 |
The
| 47 |
.I \-g
| 48 |
option specifies the exponent used in gamma correction;
| 49 |
the default value is 2.2.
| 50 |
An exponent of 1.0 turns gamma correction off.
| 51 |
The
| 52 |
.I \-e
| 53 |
option specifies an exposure compensation in f-stops (powers of two).
| 54 |
Only integer stops are allowed, for efficiency.
| 55 |
The
| 56 |
.I \-r
| 57 |
option invokes a reverse conversion, from a 16-bit or 24-bit
| 58 |
Targa file to a RADIANCE picture.
| 59 |
The determination of depth is made automatically on reverse
| 60 |
translation, so the
| 61 |
.I \-2
| 62 |
and
| 63 |
.I \-3
| 64 |
options are not necessary.
| 65 |
If the output file is missing, the standard output is used.
| 66 |
.SH AUTHORS
| 67 |
Greg Ward
| 68 |
.SH BUGS
| 69 |
Run-length encoded files can be read but not written with this
| 70 |
program.
| 71 |
.SH "SEE ALSO"
| 72 |
pfilt(1), ra_bmp(1), ra_bn(1), ra_ppm(1), ra_pr(1), ra_pr24(1),
| 73 |
ra_t8(1), ra_tiff(1), ximage(1)
