root/Development/ray/doc/man/man1/ra_t16.1
Revision: 1.3
Committed: Fri Mar 26 22:58:20 2004 UTC (21 years, 9 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, HEAD
Added support to ra_bmp for 16-bit images and RLE, plus created man page
1 .\" RCSid "$Id: ra_t16.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH RA_T16 1 11/15/93 RADIANCE
3 .SH NAME
4 ra_t16 - convert RADIANCE picture to/from Targa 16 or 24-bit image file
5 .SH SYNOPSIS
6 .B ra_t16
7 [
8 .B \-2
9 ][
10 .B \-3
11 ][
12 .B "\-g gamma"
13 ][
14 .B "\-e +/-stops"
15 ]
16 [
17 .B input
18 [
19 .B output
20 ]
21 ]
22 .br
23 .B ra_t16
24 .B \-r
25 [
26 .B "\-g gamma"
27 ][
28 .B "\-e +/-stops"
29 ]
30 [
31 .B input
32 [
33 .B output
34 ]
35 ]
36 .SH DESCRIPTION
37 .I Ra_t16
38 converts between RADIANCE and Targa 16-bit or 24-bit RGB image files
39 (type 2 in Targa's documentation).
40 In the default mode, a RADIANCE picture is converted to an
41 RGB file of the same horizontal and vertical dimensions with
42 16-bits per pixel.
43 The
44 .I \-3
45 option tells the program to produce a 24-bit image file instead.
46 The
47 .I \-g
48 option specifies the exponent used in gamma correction;
49 the default value is 2.2.
50 An exponent of 1.0 turns gamma correction off.
51 The
52 .I \-e
53 option specifies an exposure compensation in f-stops (powers of two).
54 Only integer stops are allowed, for efficiency.
55 The
56 .I \-r
57 option invokes a reverse conversion, from a 16-bit or 24-bit
58 Targa file to a RADIANCE picture.
59 The determination of depth is made automatically on reverse
60 translation, so the
61 .I \-2
62 and
63 .I \-3
64 options are not necessary.
65 If the output file is missing, the standard output is used.
66 .SH AUTHORS
67 Greg Ward
68 .SH BUGS
69 Run-length encoded files can be read but not written with this
70 program.
71 .SH "SEE ALSO"
72 pfilt(1), ra_bmp(1), ra_bn(1), ra_ppm(1), ra_pr(1), ra_pr24(1),
73 ra_t8(1), ra_tiff(1), ximage(1)
