1 |
.\" RCSid "$Id$" |
2 |
.TH RA_RGBE 1 1/23/98 RADIANCE |
3 |
.SH NAME |
4 |
ra_rgbe - convert between different RADIANCE picture types |
5 |
.SH SYNOPSIS |
6 |
.B ra_rgbe |
7 |
8 |
.B \-r |
9 |
10 |
.B "\-e +/-stops" |
11 |
12 |
.B \-f |
13 |
14 |
.B "\-n frameno" |
15 |
16 |
17 |
.B input |
18 |
19 |
.B outspec |
20 |
21 |
22 |
.SH DESCRIPTION |
23 |
.I Ra_rgbe |
24 |
converts between RADIANCE run-length encoded and flat formats, and |
25 |
separates concatanated animation frames produced by |
26 |
.I rpict(1). |
27 |
The |
28 |
.I \-e |
29 |
option specifies an exposure compensation in f-stops (powers of two). |
30 |
Only integer stops are allowed, for efficiency. |
31 |
By default, |
32 |
.I ra_rgbe |
33 |
produces a flat RADIANCE picture file from any type of RADIANCE |
34 |
input picture. |
35 |
The |
36 |
.I \-r |
37 |
option causes |
38 |
.I ra_rgbe |
39 |
to produce a run-length encoded file instead. |
40 |
.PP |
41 |
If the input file consists of multiple animation frames as produced by |
42 |
.I rpict |
43 |
with the |
44 |
.I \-S |
45 |
option, |
46 |
.I ra_rgbe |
47 |
will read each frame and write it to the output file created by calling |
48 |
.I printf(3) |
49 |
with the output specification and frame number as arguments. |
50 |
If the output specification begins with an exclamation mark ('!'), |
51 |
then this interpreted as a command spec., which is also run through |
52 |
.I printf |
53 |
with the frame number to get the final command. |
54 |
This command must accept a Radiance picture on its standard input, |
55 |
and may write results either to a file or to the standard output. |
56 |
The |
57 |
.I \-n |
58 |
option may be used to select a specific frame for output, and |
59 |
other frames in the input will be skipped. |
60 |
Normally, all frames will be read and written. |
61 |
.PP |
62 |
.I Ra_rgbe |
63 |
will report an error and exit if the target output file already exists, |
64 |
unless the |
65 |
.I \-f |
66 |
option is given. |
67 |
If the output file is missing, the standard output is used. |
68 |
If the input file is missing or set to '-', the standard input is used. |
69 |
.SH NOTES |
70 |
The file format for RADIANCE pictures was changed between release |
71 |
1.4 and release 2.0. |
72 |
The older format can still be read by all the programs, but only |
73 |
the newer format is produced. |
74 |
This newer format cannot be read by RADIANCE software prior to |
75 |
release 2.0. |
76 |
.PP |
77 |
.I Ra_rgbe |
78 |
provides some downward compatibility by producing files that can |
79 |
be read by older RADIANCE software. |
80 |
The resultant files are also easier to manipulate with programs |
81 |
designed to read raw raster data. |
82 |
.PP |
83 |
The other use for |
84 |
.I ra_rgbe |
85 |
is as a quicker way to adjust the exposure of a RADIANCE picture than |
86 |
.I pfilt(1), |
87 |
since |
88 |
.I ra_rgbe |
89 |
only allows integer f-stop changes. |
90 |
In this mode, |
91 |
.I ra_rgbe |
92 |
should be used with the |
93 |
.I \-r |
94 |
option. |
95 |
.SH AUTHOR |
96 |
Greg Ward |
97 |
.SH ACKNOWLEDGEMENT |
98 |
Work on this program was initiated and sponsored by the LESO |
99 |
group at EPFL in Switzerland. |
100 |
.SH "SEE ALSO" |
101 |
pfilt(1), printf(1), ra_xyze(1), rpict(1) |
