root/radiance/ray/doc/man/man1/ra_rgbe.1
Revision: 1.5
Committed: Fri Mar 28 16:36:31 2025 UTC (5 weeks, 5 days ago) by greg
docs: Minor fixes
1 .\" RCSid "$Id: ra_rgbe.1,v 1.4 2024/10/01 01:16:26 greg Exp $"
2 .TH RA_RGBE 1 1/23/98 RADIANCE
3 .SH NAME
4 ra_rgbe - convert between different RADIANCE picture types
5 .SH SYNOPSIS
6 .B ra_rgbe
7 [
8 .B \-r
9 ][
10 .B "\-e +/-stops"
11 ][
12 .B \-f
13 ][
14 .B "\-n frameno"
15 ]
16 [
17 .B input
18 [
19 .B outspec
20 ]
21 ]
22 .SH DESCRIPTION
23 .I Ra_rgbe
24 converts between RADIANCE run-length encoded and flat formats, and
25 separates concatanated animation frames produced by
26 .I rpict(1).
27 The
28 .I \-e
29 option specifies an exposure compensation in f-stops (powers of two).
30 Only integer stops are allowed, for efficiency.
31 By default,
32 .I ra_rgbe
33 produces a flat RADIANCE picture file from any type of RADIANCE
34 input picture.
35 The
36 .I \-r
37 option causes
38 .I ra_rgbe
39 to produce a run-length encoded file instead.
40 .PP
41 If the input file consists of multiple animation frames as produced by
42 .I rpict
43 with the
44 .I \-S
45 option,
46 .I ra_rgbe
47 will read each frame and write it to the output file created by calling
48 .I printf(3)
49 with the output specification and frame number as arguments.
50 If the output specification begins with an exclamation mark ('!'),
51 then this interpreted as a command spec., which is also run through
52 .I printf
53 with the frame number to get the final command.
54 This command must accept a Radiance picture on its standard input,
55 and may write results either to a file or to the standard output.
56 The
57 .I \-n
58 option may be used to select a specific frame for output, and
59 other frames in the input will be skipped.
60 Normally, all frames will be read and written.
61 .PP
62 .I Ra_rgbe
63 will report an error and exit if the target output file already exists,
64 unless the
65 .I \-f
66 option is given.
67 If the output file is missing, the standard output is used.
68 If the input file is missing or set to '-', the standard input is used.
69 .SH NOTES
70 The file format for RADIANCE pictures was changed between release
71 1.4 and release 2.0.
72 The older format can still be read by all the programs, but only
73 the newer format is produced.
74 This newer format cannot be read by RADIANCE software prior to
75 release 2.0.
76 .PP
77 .I Ra_rgbe
78 provides some downward compatibility by producing files that can
79 be read by older RADIANCE software.
80 The resultant files are also easier to manipulate with programs
81 designed to read raw raster data.
82 .PP
83 The other use for
84 .I ra_rgbe
85 is as a quicker way to adjust the exposure of a RADIANCE picture than
86 .I pfilt(1),
87 since
88 .I ra_rgbe
89 only allows integer f-stop changes.
90 In this mode,
91 .I ra_rgbe
92 should be used with the
93 .I \-r
94 option.
95 .SH NOTES
96 Hyperspectral Radiance pictures (.hsr files) are
97 converted to approximate RGBE pixels.
98 However, the colors may not be very accurate.
99 Pass the HSR picture through
100 .I rcomb(1)
101 or
102 .I ra_xyze(1)
103 first if greater color fidelity is required.
104 .SH AUTHOR
105 Greg Ward
106 .SH ACKNOWLEDGEMENT
107 Work on this program was initiated and sponsored by the LESO
108 group at EPFL in Switzerland.
109 .SH "SEE ALSO"
110 dctimestep(1), pfilt(1), printf(1), pvsum(1), ra_xyze(1), rcomb(1), rpict(1)
