root/radiance/ray/doc/man/man1/ra_ps.1
Revision: 1.3
Committed: Fri Mar 26 22:58:20 2004 UTC (20 years, 1 month ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8, rad3R9
Added support to ra_bmp for 16-bit images and RLE, plus created man page
1 .\" RCSid "$Id: ra_ps.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH RA_PS 1 8/28/98 RADIANCE
3 .SH NAME
4 ra_ps - convert RADIANCE picture to a PostScript file
5 .SH SYNOPSIS
6 .B ra_ps
7 [
8 .B \-b|c
9 ][
10 .B \-A|B|C
11 ][
12 .B "\-n ncopies"
13 ][
14 .B "\-e +/-stops"
15 ][
16 .B "\-g gamma"
17 ][
18 .B "\-p paper"
19 ][
20 .B "\-m[h|v] margin"
21 ][
22 .B "\-d dpi"
23 ]
24 [
25 .B input
26 [
27 .B output
28 ]
29 ]
30 .SH DESCRIPTION
31 .I Ra_ps
32 translates a RADIANCE picture to a color or greyscale
33 Adobe PostScript file for printing on
34 a laser printer or importing to a page layout program.
35 The
36 .I \-b
37 option tells
38 .I ra_ps
39 to produce greyscale output.
40 (The default is color, which may be specified explicitly with the
41 .I \-c
42 option.)\0
43 .PP
44 The
45 .I \-A
46 option specifies that the output should be in uncompressed ASCII
47 hexstring format (the default).
48 The
49 .I \-B
50 option specifies that the output should be in uncompressed binary
51 string format.
52 The file size will be roughly half that of the ASCII equivalent,
53 but some printers and especially some printer connections do not
54 support binary transfer, so this option should be used with caution.
55 The
56 .I \-C
57 option specifies that the output should be in run-length compressed
58 ASCII format.
59 The file size will be one half to one tenth as large as the
60 hexstring equivalent and can be sent over any network or by e-mail.
61 The only disadvantage is that it will actually take longer to print
62 on some printers, since the "readhexstring" procedure is generally
63 faster than a custom replacement.
64 .PP
65 The
66 .I \-n
67 option specifies the number of copies to print of this image.
68 It is often preferable to use this option instead of the
69 multiple copy option of the print spooler program,
70 since the latter often results in duplication of the input
71 file with a large associated cost.
72 .PP
73 The
74 .I \-e
75 option specifies an exposure compensation in f-stops (powers of two).
76 Only integer stops are allowed, for efficiency.
77 The
78 .I \-g
79 option specifies a power law for the printer
80 transfer function.
81 The default gamma setting for greyscale printers is 1.0 (linear),
82 and the default gamma for color printers is 1.8 (commonly used in prepress).
83 If your output seems to have too much contrast relative to its screen
84 equivalent, print out the file "ray/lib/lib/gamma.pic" to your printer
85 without any gamma correction and using the
86 .I \-d
87 option to set the dots-per-inch (see below).
88 The best match between the small lines and the grey patch next to it indicate
89 the approximate gamma of your printer, which you should use with the
90 .I \-g
91 option for best contrast reproduction in subsequent conversions.
92 .PP
93 The standard print area assumes 8.5 by 11 inch (U.S. letter)
94 paper, with 0.5 inch margins on all sides.
95 The image will be rotated 90 degrees
96 if it fits better that way in the available print area, and
97 it will always be centered on the page.
98 The
99 .I \-p
100 and
101 .I \-m
102 options to control the paper size and margins, respectively.
103 The argument to the
104 .I \-p
105 option is the common name for a given paper size, or WWxHH, where
106 WW is the width (in inches) and HH is the height.
107 If millimeters or centimeters are the preferred measurement unit,
108 the 'x' may be replaced by 'm' or 'c', respectively.
109 The WW and HH values are decimal quantities, of course.
110 The current paper identifiers understood by the program may be discovered
111 by giving a 0 argument to the
112 .I \-p
113 option.
114 They are currently:
115 .PP
116 .nf
117 _Name________Width_Height_(inches)
118 envelope 4.12 9.50
119 executive 7.25 10.50
120 letter 8.50 11.00
121 lettersmall 7.68 10.16
122 legal 8.50 14.00
123 monarch 3.87 7.50
124 statement 5.50 8.50
125 tabloid 11.00 17.00
126 A3 11.69 16.54
127 A4 8.27 11.69
128 A4small 7.47 10.85
129 A5 6.00 8.27
130 A6 4.13 6.00
131 B4 10.12 14.33
132 B5 7.17 10.12
133 C5 6.38 9.01
134 C6 4.49 6.38
135 DL 4.33 8.66
136 hagaki 3.94 5.83
137 .fi
138 .PP
139 The paper size name may be abbreviated with three or more letters, and
140 character case is ignored.
141 The argument to the
142 .I \-m
143 option is the margin width, which is 0.5 inches by default.
144 A millimeter or centimeter quantity may be given instead of inches
145 by immediately following the value with a 'm' or 'c' character, respectively.
146 (Leave no space between the quantity and its unit letter.)\0
147 If you wish to specify the horizontal and vertical margins separately,
148 use the
149 .I \-mh
150 and
151 .I \-mv
152 options, instead.
153 .PP
154 The
155 .I \-d
156 option may be used to explicitly set the print density (in dots per inch).
157 If the input picture is lower resolution than the printer and has square
158 pixels, then
159 .I ra_ps
160 will adjust the image size so that pixels map to dot regions exactly.
161 This may improve the appearance of fine detail, and may speed up the
162 printing process as well, at the expense of a slightly smaller image area.
163 If you wish to maximize print area and the input image contains no fine
164 detail, then do not specify this option.
165 .PP
166 The output from
167 .I ra_ps
168 is designed to be compatible with the Encapsulated PostScript standard,
169 which means that the resulting file may be incorporated into
170 documents by page layout programs that can read in EPS files.
171 Unfortunately, there is currently no option for generating a preview
172 bitmap, so the image will show up on the screen as a rectangular area only.
173 To control the EPS image size directly, use the
174 .I \-p
175 option as explained above with the WWxHH specification, and set
176 .I "\-m 0"
177 to turn off the margins.
178 .SH AUTHOR
179 Greg Ward
180 .SH "SEE ALSO"
181 pfilt(1), ra_bmp(1), ra_bn(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1),
182 ra_ppm(1), ra_tiff(1), ximage(1)
