root/radiance/ray/doc/man/man1/ra_ps.1
Revision: 1.4
Committed: Mon Nov 10 19:08:17 2008 UTC (16 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3, HEAD
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: ra_ps.1,v 1.3 2004/03/26 22:58:20 greg Exp $"
2 greg 1.1 .TH RA_PS 1 8/28/98 RADIANCE
3     .SH NAME
4     ra_ps - convert RADIANCE picture to a PostScript file
5     .SH SYNOPSIS
6     .B ra_ps
7     [
8     .B \-b|c
9     ][
10     .B \-A|B|C
11     ][
12     .B "\-n ncopies"
13     ][
14     .B "\-e +/-stops"
15     ][
16     .B "\-g gamma"
17     ][
18     .B "\-p paper"
19     ][
20     .B "\-m[h|v] margin"
21     ][
22     .B "\-d dpi"
23     ]
24     [
25     .B input
26     [
27     .B output
28     ]
29     ]
30     .SH DESCRIPTION
31     .I Ra_ps
32     translates a RADIANCE picture to a color or greyscale
33     Adobe PostScript file for printing on
34     a laser printer or importing to a page layout program.
35     The
36     .I \-b
37     option tells
38     .I ra_ps
39     to produce greyscale output.
40     (The default is color, which may be specified explicitly with the
41     .I \-c
42     option.)\0
43     .PP
44     The
45     .I \-A
46     option specifies that the output should be in uncompressed ASCII
47     hexstring format (the default).
48     The
49     .I \-B
50     option specifies that the output should be in uncompressed binary
51     string format.
52     The file size will be roughly half that of the ASCII equivalent,
53     but some printers and especially some printer connections do not
54     support binary transfer, so this option should be used with caution.
55     The
56     .I \-C
57     option specifies that the output should be in run-length compressed
58     ASCII format.
59     The file size will be one half to one tenth as large as the
60     hexstring equivalent and can be sent over any network or by e-mail.
61     The only disadvantage is that it will actually take longer to print
62     on some printers, since the "readhexstring" procedure is generally
63     faster than a custom replacement.
64     .PP
65     The
66     .I \-n
67     option specifies the number of copies to print of this image.
68     It is often preferable to use this option instead of the
69     multiple copy option of the print spooler program,
70     since the latter often results in duplication of the input
71     file with a large associated cost.
72     .PP
73     The
74     .I \-e
75     option specifies an exposure compensation in f-stops (powers of two).
76     Only integer stops are allowed, for efficiency.
77     The
78     .I \-g
79     option specifies a power law for the printer
80     transfer function.
81     The default gamma setting for greyscale printers is 1.0 (linear),
82     and the default gamma for color printers is 1.8 (commonly used in prepress).
83     If your output seems to have too much contrast relative to its screen
84 greg 1.4 equivalent, print out the file "ray/lib/lib/gamma.hdr" to your printer
85 greg 1.1 without any gamma correction and using the
86     .I \-d
87     option to set the dots-per-inch (see below).
88     The best match between the small lines and the grey patch next to it indicate
89     the approximate gamma of your printer, which you should use with the
90     .I \-g
91     option for best contrast reproduction in subsequent conversions.
92     .PP
93     The standard print area assumes 8.5 by 11 inch (U.S. letter)
94     paper, with 0.5 inch margins on all sides.
95     The image will be rotated 90 degrees
96     if it fits better that way in the available print area, and
97     it will always be centered on the page.
98     The
99     .I \-p
100     and
101     .I \-m
102     options to control the paper size and margins, respectively.
103     The argument to the
104     .I \-p
105     option is the common name for a given paper size, or WWxHH, where
106     WW is the width (in inches) and HH is the height.
107     If millimeters or centimeters are the preferred measurement unit,
108     the 'x' may be replaced by 'm' or 'c', respectively.
109     The WW and HH values are decimal quantities, of course.
110     The current paper identifiers understood by the program may be discovered
111     by giving a 0 argument to the
112     .I \-p
113     option.
114     They are currently:
115     .PP
116     .nf
117     _Name________Width_Height_(inches)
118     envelope 4.12 9.50
119     executive 7.25 10.50
120     letter 8.50 11.00
121     lettersmall 7.68 10.16
122     legal 8.50 14.00
123     monarch 3.87 7.50
124     statement 5.50 8.50
125     tabloid 11.00 17.00
126     A3 11.69 16.54
127     A4 8.27 11.69
128     A4small 7.47 10.85
129     A5 6.00 8.27
130     A6 4.13 6.00
131     B4 10.12 14.33
132     B5 7.17 10.12
133     C5 6.38 9.01
134     C6 4.49 6.38
135     DL 4.33 8.66
136     hagaki 3.94 5.83
137     .fi
138     .PP
139     The paper size name may be abbreviated with three or more letters, and
140     character case is ignored.
141     The argument to the
142     .I \-m
143     option is the margin width, which is 0.5 inches by default.
144     A millimeter or centimeter quantity may be given instead of inches
145     by immediately following the value with a 'm' or 'c' character, respectively.
146     (Leave no space between the quantity and its unit letter.)\0
147     If you wish to specify the horizontal and vertical margins separately,
148     use the
149     .I \-mh
150     and
151     .I \-mv
152     options, instead.
153     .PP
154     The
155     .I \-d
156     option may be used to explicitly set the print density (in dots per inch).
157     If the input picture is lower resolution than the printer and has square
158     pixels, then
159     .I ra_ps
160     will adjust the image size so that pixels map to dot regions exactly.
161     This may improve the appearance of fine detail, and may speed up the
162     printing process as well, at the expense of a slightly smaller image area.
163     If you wish to maximize print area and the input image contains no fine
164     detail, then do not specify this option.
165     .PP
166     The output from
167     .I ra_ps
168     is designed to be compatible with the Encapsulated PostScript standard,
169     which means that the resulting file may be incorporated into
170     documents by page layout programs that can read in EPS files.
171     Unfortunately, there is currently no option for generating a preview
172     bitmap, so the image will show up on the screen as a rectangular area only.
173     To control the EPS image size directly, use the
174     .I \-p
175     option as explained above with the WWxHH specification, and set
176     .I "\-m 0"
177     to turn off the margins.
178     .SH AUTHOR
179     Greg Ward
180     .SH "SEE ALSO"
181 greg 1.3 pfilt(1), ra_bmp(1), ra_bn(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1),
182 greg 1.1 ra_ppm(1), ra_tiff(1), ximage(1)
