1 |
greg |
1.3 |
.\" RCSid "$Id: ra_pr24.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
2 |
greg |
1.1 |
.TH RA_PR24 1 11/15/93 RADIANCE |
3 |
.SH NAME |
4 |
ra_pr24 - convert RADIANCE picture to/from 24-bit rasterfile |
5 |
.SH SYNOPSIS |
6 |
.B ra_pr24 |
7 |
8 |
.B \-r |
9 |
10 |
.B \-rgb |
11 |
12 |
.B "\-g gamma" |
13 |
14 |
.B "\-e +/-stops" |
15 |
16 |
17 |
.B input |
18 |
19 |
.B output |
20 |
21 |
22 |
.SH DESCRIPTION |
23 |
.I Ra_pr24 |
24 |
converts between RADIANCE and 24-bit pixrect rasterfile formats. |
25 |
The |
26 |
.I \-g |
27 |
option specifies the exponent used in gamma correction; |
28 |
the default value is 2.2. |
29 |
An exponent of 1 turns gamma correction off. |
30 |
The |
31 |
.I \-e |
32 |
option specifies an exposure compensation in f-stops (powers of two). |
33 |
Only integer stops are allowed, for efficiency. |
34 |
The |
35 |
.I \-r |
36 |
option invokes a reverse conversion, from a 24-bit rasterfile to |
37 |
a RADIANCE picture. |
38 |
If the |
39 |
.I \-rgb |
40 |
option is used, the output rasterfile will be in RGB byte-ordering |
41 |
rather than the more standard (for Sun) BGR ordering. |
42 |
Byte ordering is determined automatically for the reverse |
43 |
conversion. |
44 |
If the output file is missing, the standard output is used. |
45 |
If the input file is missing as well, the standard input is used. |
46 |
.SH AUTHOR |
47 |
Greg Ward |
48 |
.SH BUGS |
49 |
Only standard 24-bit color rasterfiles are read or written. |
50 |
.SH "SEE ALSO" |
51 |
greg |
1.3 |
pfilt(1), ra_bmp(1), ra_bn(1), ra_ppm(1), ra_pr(1), ra_t8(1), ra_t16(1), |
52 |
greg |
1.1 |
ra_tiff(1), ximage(1) |
