root/radiance/ray/doc/man/man1/ra_pr24.1
Revision: 1.4
Committed: Fri Nov 5 03:31:36 2004 UTC (20 years, 6 months ago) by greg
State: FILE REMOVED
1 .\" RCSid "$Id: ra_pr24.1,v 1.3 2004/03/26 22:58:20 greg Exp $"
2 .TH RA_PR24 1 11/15/93 RADIANCE
3 .SH NAME
4 ra_pr24 - convert RADIANCE picture to/from 24-bit rasterfile
5 .SH SYNOPSIS
6 .B ra_pr24
7 [
8 .B \-r
9 |
10 .B \-rgb
11 ][
12 .B "\-g gamma"
13 ][
14 .B "\-e +/-stops"
15 ]
16 [
17 .B input
18 [
19 .B output
20 ]
21 ]
22 .SH DESCRIPTION
23 .I Ra_pr24
24 converts between RADIANCE and 24-bit pixrect rasterfile formats.
25 The
26 .I \-g
27 option specifies the exponent used in gamma correction;
28 the default value is 2.2.
29 An exponent of 1 turns gamma correction off.
30 The
31 .I \-e
32 option specifies an exposure compensation in f-stops (powers of two).
33 Only integer stops are allowed, for efficiency.
34 The
35 .I \-r
36 option invokes a reverse conversion, from a 24-bit rasterfile to
37 a RADIANCE picture.
38 If the
39 .I \-rgb
40 option is used, the output rasterfile will be in RGB byte-ordering
41 rather than the more standard (for Sun) BGR ordering.
42 Byte ordering is determined automatically for the reverse
43 conversion.
44 If the output file is missing, the standard output is used.
45 If the input file is missing as well, the standard input is used.
46 .SH AUTHOR
47 Greg Ward
48 .SH BUGS
49 Only standard 24-bit color rasterfiles are read or written.
50 .SH "SEE ALSO"
51 pfilt(1), ra_bmp(1), ra_bn(1), ra_ppm(1), ra_pr(1), ra_t8(1), ra_t16(1),
52 ra_tiff(1), ximage(1)
