root/Development/ray/doc/man/man1/ra_pr.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 9 months ago) by greg
Added documentation to repository
# User Rev Content
1 greg 1.1 .\" RCSid "$Id"
2     .TH RA_PR 1 11/15/93 RADIANCE
3     .SH NAME
4     ra_pr - convert RADIANCE picture to/from pixrect rasterfile
5     .SH SYNOPSIS
6     .B ra_pr
7     [
8     .B \-d
9     ][
10     .B \-b
11     ][
12     .B "\-c ncolors"
13     ][
14     .B "\-g gamma"
15     ][
16     .B "\-e +/-stops"
17     ]
18     .B input
19     [
20     .B output
21     ]
22     .br
23     .B ra_pr
24     .B \-r
25     [
26     .B "\-g gamma"
27     ][
28     .B "\-e +/-stops"
29     ]
30     [
31     .B input
32     [
33     .B output
34     ]
35     ]
36     .SH DESCRIPTION
37     .I Ra_pr
38     converts between RADIANCE and pixrect rasterfile formats.
39     In the default mode, a RADIANCE picture is converted to a pixrect
40     rasterfile of the same horizontal and vertical dimensions with
41     8-bits per pixel.
42     The
43     .I \-d
44     option turns off dithering.
45     The
46     .I \-b
47     option converts the image to black and white, for improved quality
48     on greyscale monitors.
49     Only with this option can the input be taken from stdin.
50     The
51     .I \-c
52     option allows fewer than 256 colors.
53     The
54     .I \-g
55     option specifies the exponent used in gamma correction;
56     the default value is 2.2.
57     An exponent of 1.0 turns gamma correction off.
58     The
59     .I \-e
60     option specifies an exposure compensation in f-stops (powers of two).
61     Only integer stops are allowed, for efficiency.
62     The
63     .I \-r
64     option invokes a reverse conversion, from a pixrect rasterfile to
65     a RADIANCE picture.
66     If the output file is missing, the standard output is used.
67     .SH AUTHORS
68     Greg Ward
69     .br
70     Paul Heckbert provided the code for color quantization
71     .SH BUGS
72     Only standard 8-bit color rasterfiles are read or written.
73     .SH "SEE ALSO"
74     pfilt(1), ra_bn(1), ra_ppm(1), ra_pr24(1), ra_t8(1), ra_t16(1),
75     ra_tiff(1), ximage(1)
