| 1 |
.\" RCSid "$Id$"
| 2 |
.TH RA_PPM 1 2/10/99 RADIANCE
| 3 |
.SH NAME
| 4 |
ra_ppm - convert RADIANCE picture to/from a Poskanzer Portable Pixmap
| 5 |
.SH SYNOPSIS
| 6 |
.B ra_ppm
| 7 |
| 8 |
.B \-r
| 9 |
| 10 |
.B \-a
| 11 |
| 12 |
.B \-b
| 13 |
| 14 |
.B "\-s maxv"
| 15 |
| 16 |
.B "\-g gamma"
| 17 |
| 18 |
.B "\-e +/-stops"
| 19 |
| 20 |
| 21 |
.B input
| 22 |
| 23 |
.B output
| 24 |
| 25 |
| 26 |
.SH DESCRIPTION
| 27 |
.I Ra_ppm
| 28 |
converts between RADIANCE and Poskanzer Portable Pixmap formats.
| 29 |
The
| 30 |
.I \-g
| 31 |
option specifies the exponent used in gamma correction;
| 32 |
the default value is 2.2.
| 33 |
An exponent of 1 turns gamma correction off.
| 34 |
The
| 35 |
.I \-e
| 36 |
option specifies an exposure compensation in f-stops (powers of two).
| 37 |
Only integer stops are allowed, for efficiency.
| 38 |
The
| 39 |
.I \-r
| 40 |
option invokes a reverse conversion, from a Pixmap to
| 41 |
a RADIANCE picture.
| 42 |
If the output file is missing, the standard output is used.
| 43 |
If the input file is missing as well, the standard input is used.
| 44 |
.PP
| 45 |
The
| 46 |
.I \-a
| 47 |
option produces a standard ASCII Pixmap representation instead of
| 48 |
the default binary file.
| 49 |
The file is much larger and the conversion is much slower, which is
| 50 |
why this format is not normally used.
| 51 |
The
| 52 |
.I \-b
| 53 |
option forces greyscale output.
| 54 |
The
| 55 |
.I \-s
| 56 |
option controls the output scale, which is 255 by default.
| 57 |
If this value is set above 255, then two bytes will be output for each
| 58 |
component in binary mode.
| 59 |
This may not be understood by some PPM readers, which do not understand
| 60 |
files with maximum values greater than 255.
| 61 |
The maximum allowed setting for this parameter is 65535.
| 62 |
.PP
| 63 |
With the
| 64 |
.I \-r
| 65 |
option, the type of the Pixmap input file is determined automatically.
| 66 |
.I Ra_ppm
| 67 |
will read either greyscale or color Pixmaps, with any precision up
| 68 |
to a maximum scale of 65535.
| 69 |
.SH NOTES
| 70 |
The Poskanzer Portable Bitmap Plus package contains translators between the
| 71 |
Pixmap format and many of the dozen or so image
| 72 |
file "standards" that exist.
| 73 |
At the time of this writing, the software is free and available by
| 74 |
anonymous ftp from export.lcs.mit.edu (18.30.0.238) in the file
| 75 |
"contrib/pbmplus.tar.Z".
| 76 |
.SH AUTHOR
| 77 |
Greg Ward
| 78 |
.SH ACKNOWLEDGEMENT
| 79 |
Work on this program was initiated and sponsored by the LESO
| 80 |
group at EPFL in Switzerland and Silicon Graphics, Inc.
| 81 |
.SH "SEE ALSO"
| 82 |
pfilt(1), ra_bn(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1),
| 83 |
ra_tiff(1), ximage(1)
