root/Development/ray/doc/man/man1/ra_ppm.1
Revision: 1.3
Committed: Fri Mar 26 22:58:20 2004 UTC (21 years, 6 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
Error occurred while calculating annotation data.
Added support to ra_bmp for 16-bit images and RLE, plus created man page
1 .\" RCSid "$Id: ra_ppm.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH RA_PPM 1 2/10/99 RADIANCE
3 .SH NAME
4 ra_ppm - convert RADIANCE picture to/from a Poskanzer Portable Pixmap
5 .SH SYNOPSIS
6 .B ra_ppm
7 [
8 .B \-r
9 ][
10 .B \-a
11 ][
12 .B \-b
13 ][
14 .B "\-s maxv"
15 ][
16 .B "\-g gamma"
17 ][
18 .B "\-e +/-stops"
19 ]
20 [
21 .B input
22 [
23 .B output
24 ]
25 ]
26 .SH DESCRIPTION
27 .I Ra_ppm
28 converts between RADIANCE and Poskanzer Portable Pixmap formats.
29 The
30 .I \-g
31 option specifies the exponent used in gamma correction;
32 the default value is 2.2.
33 An exponent of 1 turns gamma correction off.
34 The
35 .I \-e
36 option specifies an exposure compensation in f-stops (powers of two).
37 Only integer stops are allowed, for efficiency.
38 The
39 .I \-r
40 option invokes a reverse conversion, from a Pixmap to
41 a RADIANCE picture.
42 If the output file is missing, the standard output is used.
43 If the input file is missing as well, the standard input is used.
44 .PP
45 The
46 .I \-a
47 option produces a standard ASCII Pixmap representation instead of
48 the default binary file.
49 The file is much larger and the conversion is much slower, which is
50 why this format is not normally used.
51 The
52 .I \-b
53 option forces greyscale output.
54 The
55 .I \-s
56 option controls the output scale, which is 255 by default.
57 If this value is set above 255, then two bytes will be output for each
58 component in binary mode.
59 This may not be understood by some PPM readers, which do not understand
60 files with maximum values greater than 255.
61 The maximum allowed setting for this parameter is 65535.
62 .PP
63 With the
64 .I \-r
65 option, the type of the Pixmap input file is determined automatically.
66 .I Ra_ppm
67 will read either greyscale or color Pixmaps, with any precision up
68 to a maximum scale of 65535.
69 .SH NOTES
70 The Poskanzer Portable Bitmap Plus package contains translators between the
71 Pixmap format and many of the dozen or so image
72 file "standards" that exist.
73 At the time of this writing, the software is free and available by
74 anonymous ftp from export.lcs.mit.edu (18.30.0.238) in the file
75 "contrib/pbmplus.tar.Z".
76 .SH AUTHOR
77 Greg Ward
78 .SH ACKNOWLEDGEMENT
79 Work on this program was initiated and sponsored by the LESO
80 group at EPFL in Switzerland and Silicon Graphics, Inc.
81 .SH "SEE ALSO"
82 pfilt(1), ra_bmp(1), ra_bn(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1),
83 ra_tiff(1), ximage(1)
