| 1 |
.\" RCSid "$Id: ra_ppm.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
| 2 |
.TH RA_PPM 1 2/10/99 RADIANCE |
| 3 |
.SH NAME |
| 4 |
ra_ppm - convert RADIANCE picture to/from a Poskanzer Portable Pixmap |
| 5 |
.SH SYNOPSIS |
| 6 |
.B ra_ppm |
| 7 |
| 8 |
.B \-r |
| 9 |
| 10 |
.B \-a |
| 11 |
| 12 |
.B \-b |
| 13 |
| 14 |
.B "\-s maxv" |
| 15 |
| 16 |
.B "\-g gamma" |
| 17 |
| 18 |
.B "\-e +/-stops" |
| 19 |
| 20 |
| 21 |
.B input |
| 22 |
| 23 |
.B output |
| 24 |
| 25 |
| 26 |
.SH DESCRIPTION |
| 27 |
.I Ra_ppm |
| 28 |
converts between RADIANCE and Poskanzer Portable Pixmap formats. |
| 29 |
The |
| 30 |
.I \-g |
| 31 |
option specifies the exponent used in gamma correction; |
| 32 |
the default value is 2.2. |
| 33 |
An exponent of 1 turns gamma correction off. |
| 34 |
The |
| 35 |
.I \-e |
| 36 |
option specifies an exposure compensation in f-stops (powers of two). |
| 37 |
Only integer stops are allowed, for efficiency. |
| 38 |
The |
| 39 |
.I \-r |
| 40 |
option invokes a reverse conversion, from a Pixmap to |
| 41 |
a RADIANCE picture. |
| 42 |
If the output file is missing, the standard output is used. |
| 43 |
If the input file is missing as well, the standard input is used. |
| 44 |
.PP |
| 45 |
The |
| 46 |
.I \-a |
| 47 |
option produces a standard ASCII Pixmap representation instead of |
| 48 |
the default binary file. |
| 49 |
The file is much larger and the conversion is much slower, which is |
| 50 |
why this format is not normally used. |
| 51 |
The |
| 52 |
.I \-b |
| 53 |
option forces greyscale output. |
| 54 |
The |
| 55 |
.I \-s |
| 56 |
option controls the output scale, which is 255 by default. |
| 57 |
If this value is set above 255, then two bytes will be output for each |
| 58 |
component in binary mode. |
| 59 |
This may not be understood by some PPM readers, which do not understand |
| 60 |
files with maximum values greater than 255. |
| 61 |
The maximum allowed setting for this parameter is 65535. |
| 62 |
.PP |
| 63 |
With the |
| 64 |
.I \-r |
| 65 |
option, the type of the Pixmap input file is determined automatically. |
| 66 |
.I Ra_ppm |
| 67 |
will read either greyscale or color Pixmaps, with any precision up |
| 68 |
to a maximum scale of 65535. |
| 69 |
.SH NOTES |
| 70 |
The Poskanzer Portable Bitmap Plus package contains translators between the |
| 71 |
Pixmap format and many of the dozen or so image |
| 72 |
file "standards" that exist. |
| 73 |
At the time of this writing, the software is free and available by |
| 74 |
anonymous ftp from export.lcs.mit.edu (18.30.0.238) in the file |
| 75 |
"contrib/pbmplus.tar.Z". |
| 76 |
.SH AUTHOR |
| 77 |
Greg Ward |
| 78 |
.SH ACKNOWLEDGEMENT |
| 79 |
Work on this program was initiated and sponsored by the LESO |
| 80 |
group at EPFL in Switzerland and Silicon Graphics, Inc. |
| 81 |
.SH "SEE ALSO" |
| 82 |
pfilt(1), ra_bmp(1), ra_bn(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1), |
| 83 |
ra_tiff(1), ximage(1) |
