root/radiance/ray/doc/man/man1/ra_ppm.1
Revision: 1.3
Committed: Fri Mar 26 22:58:20 2004 UTC (21 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Added support to ra_bmp for 16-bit images and RLE, plus created man page
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: ra_ppm.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH RA_PPM 1 2/10/99 RADIANCE
3     .SH NAME
4     ra_ppm - convert RADIANCE picture to/from a Poskanzer Portable Pixmap
5     .SH SYNOPSIS
6     .B ra_ppm
7     [
8     .B \-r
9     ][
10     .B \-a
11     ][
12     .B \-b
13     ][
14     .B "\-s maxv"
15     ][
16     .B "\-g gamma"
17     ][
18     .B "\-e +/-stops"
19     ]
20     [
21     .B input
22     [
23     .B output
24     ]
25     ]
26     .SH DESCRIPTION
27     .I Ra_ppm
28     converts between RADIANCE and Poskanzer Portable Pixmap formats.
29     The
30     .I \-g
31     option specifies the exponent used in gamma correction;
32     the default value is 2.2.
33     An exponent of 1 turns gamma correction off.
34     The
35     .I \-e
36     option specifies an exposure compensation in f-stops (powers of two).
37     Only integer stops are allowed, for efficiency.
38     The
39     .I \-r
40     option invokes a reverse conversion, from a Pixmap to
41     a RADIANCE picture.
42     If the output file is missing, the standard output is used.
43     If the input file is missing as well, the standard input is used.
44     .PP
45     The
46     .I \-a
47     option produces a standard ASCII Pixmap representation instead of
48     the default binary file.
49     The file is much larger and the conversion is much slower, which is
50     why this format is not normally used.
51     The
52     .I \-b
53     option forces greyscale output.
54     The
55     .I \-s
56     option controls the output scale, which is 255 by default.
57     If this value is set above 255, then two bytes will be output for each
58     component in binary mode.
59     This may not be understood by some PPM readers, which do not understand
60     files with maximum values greater than 255.
61     The maximum allowed setting for this parameter is 65535.
62     .PP
63     With the
64     .I \-r
65     option, the type of the Pixmap input file is determined automatically.
66     .I Ra_ppm
67     will read either greyscale or color Pixmaps, with any precision up
68     to a maximum scale of 65535.
69     .SH NOTES
70     The Poskanzer Portable Bitmap Plus package contains translators between the
71     Pixmap format and many of the dozen or so image
72     file "standards" that exist.
73     At the time of this writing, the software is free and available by
74     anonymous ftp from export.lcs.mit.edu (18.30.0.238) in the file
75     "contrib/pbmplus.tar.Z".
76     .SH AUTHOR
77     Greg Ward
78     .SH ACKNOWLEDGEMENT
79     Work on this program was initiated and sponsored by the LESO
80     group at EPFL in Switzerland and Silicon Graphics, Inc.
81     .SH "SEE ALSO"
82 greg 1.3 pfilt(1), ra_bmp(1), ra_bn(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1),
83 greg 1.1 ra_tiff(1), ximage(1)
