1 |
.\" RCSid "$Id: ra_pict.1,v 1.3 2007/09/04 17:36:40 greg Exp $" |
2 |
.TH RA_PICT 1 11/15/93 RADIANCE |
3 |
.SH NAME |
4 |
ra_pict - convert Radiance pictures to Macintosh PICT files |
5 |
.SH SYNOPSIS |
6 |
.B ra_pict |
7 |
8 |
.B \-e +/- |
9 |
.I stops |
10 |
11 |
.B \-v |
12 |
13 |
.B \-g |
14 |
.I gamma |
15 |
16 |
.I infile |
17 |
18 |
.I outfile |
19 |
20 |
.SH DESCRIPTION |
21 |
.B Ra_pict |
22 |
converts a Radiance picture, as produced by |
23 |
.B rpict |
24 |
(1) to a Macintosh PICT file. The picture will be a 24 bit PICT 2 picture, |
25 |
using a single bit map (DirectRect). |
26 |
.SH OPTIONS |
27 |
.TP 10n |
28 |
.BI \-g " gamma" |
29 |
This sets an explict gamma correction for the image. If it is not |
30 |
specified, the default value of 2.0 is used. |
31 |
.TP |
32 |
.B \-v |
33 |
Invokes verbose mode, and gives line on standard error giving the |
34 |
size of the picture and the gamma correction used. |
35 |
.TP |
36 |
.BI "\-e +/\-" " stops" |
37 |
Adjusts the exposure by stops. |
38 |
.TP |
39 |
.I infile |
40 |
Specifies the file to read the picture from. If none is specified, |
41 |
it takes it from standard input. If standard input is used, then |
42 |
the picture is sent to standard output. |
43 |
.TP |
44 |
.I outfile |
45 |
Specifies the file to send the PICT file to. If none is specified, |
46 |
it is sent to standard output. |
47 |
.SH EXAMPLES |
48 |
.PP |
49 |
ra_pict mypict.hdr mypict.pict |
50 |
.PP |
51 |
Will convert the Radiance picture mypict.hdr, giving the Macintosh |
52 |
PICT mypict.pict. |
53 |
.PP |
54 |
ra_pict \-g 2.2 mypict.hdr mypict.pict |
55 |
.PP |
56 |
Will convert the file using a gamma of 2.2. |
57 |
.SH "SEE ALSO" |
58 |
rpict(1) |
59 |
.SH BUGS |
60 |
Does not yet do Macintosh PICT to Radiance PIC, as this PICT files |
61 |
are a lot more complex than just one bit map. This is left as an |
62 |
exercise for the reader :-) |
63 |
.SH AUTHOR |
64 |
Russell Street |
