root/radiance/ray/doc/man/man1/ra_pict.1
Revision: 1.4
Committed: Mon Nov 10 19:08:17 2008 UTC (16 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3, HEAD
1 .\" RCSid "$Id: ra_pict.1,v 1.3 2007/09/04 17:36:40 greg Exp $"
2 .TH RA_PICT 1 11/15/93 RADIANCE
3 .SH NAME
4 ra_pict - convert Radiance pictures to Macintosh PICT files
5 .SH SYNOPSIS
6 .B ra_pict
7 [
8 .B \-e +/-
9 .I stops
10 ] [
11 .B \-v
12 ] [
13 .B \-g
14 .I gamma
15 ] [
16 .I infile
17 [
18 .I outfile
19 ]]
20 .SH DESCRIPTION
21 .B Ra_pict
22 converts a Radiance picture, as produced by
23 .B rpict
24 (1) to a Macintosh PICT file. The picture will be a 24 bit PICT 2 picture,
25 using a single bit map (DirectRect).
26 .SH OPTIONS
27 .TP 10n
28 .BI \-g " gamma"
29 This sets an explict gamma correction for the image. If it is not
30 specified, the default value of 2.0 is used.
31 .TP
32 .B \-v
33 Invokes verbose mode, and gives line on standard error giving the
34 size of the picture and the gamma correction used.
35 .TP
36 .BI "\-e +/\-" " stops"
37 Adjusts the exposure by stops.
38 .TP
39 .I infile
40 Specifies the file to read the picture from. If none is specified,
41 it takes it from standard input. If standard input is used, then
42 the picture is sent to standard output.
43 .TP
44 .I outfile
45 Specifies the file to send the PICT file to. If none is specified,
46 it is sent to standard output.
47 .SH EXAMPLES
48 .PP
49 ra_pict mypict.hdr mypict.pict
50 .PP
51 Will convert the Radiance picture mypict.hdr, giving the Macintosh
52 PICT mypict.pict.
53 .PP
54 ra_pict \-g 2.2 mypict.hdr mypict.pict
55 .PP
56 Will convert the file using a gamma of 2.2.
57 .SH "SEE ALSO"
58 rpict(1)
59 .SH BUGS
60 Does not yet do Macintosh PICT to Radiance PIC, as this PICT files
61 are a lot more complex than just one bit map. This is left as an
62 exercise for the reader :-)
63 .SH AUTHOR
64 Russell Street
