root/radiance/ray/doc/man/man1/ra_bn.1
Revision: 1.4
Committed: Fri Nov 5 03:31:36 2004 UTC (20 years, 7 months ago) by greg
State: FILE REMOVED
Error occurred while calculating annotation data.
1 .\" RCSid "$Id: ra_bn.1,v 1.3 2004/03/26 22:58:20 greg Exp $"
2 .TH RA_BN 1 11/15/93 RADIANCE
3 .SH NAME
4 ra_bn - convert RADIANCE picture to/from Barneyscan image
5 .SH SYNOPSIS
6 .B ra_bn
7 [
8 .B "\-g gamma"
9 ][
10 .B "\-e +/-stops"
11 ]
12 {
13 .B input|-
14 }
15 [
16 .B output
17 ]
18 .br
19 .B ra_bn
20 .B \-r
21 [
22 .B "\-g gamma"
23 ][
24 .B "\-e +/-stops"
25 ]
26 .B input
27 [
28 .B output
29 ]
30 .SH DESCRIPTION
31 .I Ra_bn
32 converts between RADIANCE and Barneyscan native RGB image files.
33 Since Barneyscan images are stored in three files, one for each
34 color component, only the root file name is given and the program
35 appends the suffixes "red", "grn" and "blu".
36 The
37 .I \-g
38 option specifies the exponent used in gamma correction;
39 the default value is 2.0.
40 An exponent of 1.0 turns gamma correction off.
41 The
42 .I \-e
43 option specifies an exposure compensation in f-stops (powers of two).
44 Only integer stops are allowed, for efficiency.
45 The
46 .I \-r
47 option invokes a reverse conversion, from a Barneyscan image
48 to a RADIANCE picture.
49 .SH AUTHORS
50 Greg Ward
51 .SH "SEE ALSO"
52 pfilt(1), ra_bmp(1), ra_ppm(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1),
53 ra_tiff(1), ximage(1)
