1 |
greg |
1.1 |
.TH RA_BMP 1 3/25/04 RADIANCE |
2 |
.SH NAME |
3 |
ra_bmp - convert RADIANCE picture to/from Windows BMP image |
4 |
.SH SYNOPSIS |
5 |
.B ra_bmp |
6 |
7 |
.B \-b |
8 |
9 |
.B "\-g gamma" |
10 |
11 |
greg |
1.2 |
.B "\-e spec" |
12 |
13 |
.B "-p xr yr xg yg xb yb xw yw" |
14 |
greg |
1.1 |
15 |
16 |
17 |
.B input|- |
18 |
19 |
.B output |
20 |
21 |
22 |
.br |
23 |
.B ra_bmp |
24 |
.B \-r |
25 |
26 |
.B "\-g gamma" |
27 |
28 |
.B "\-e +/-stops" |
29 |
30 |
31 |
32 |
.B input|- |
33 |
34 |
.B output |
35 |
36 |
37 |
.SH DESCRIPTION |
38 |
.I Ra_bmp |
39 |
converts between RADIANCE and a Windows BMP image. |
40 |
greg |
1.2 |
During forward conversion, the |
41 |
greg |
1.1 |
.I \-b |
42 |
option produces 8-bit grayscale output rather than 24-bit RGB. |
43 |
The |
44 |
.I \-g |
45 |
greg |
1.2 |
option specifies the exponent used in monitor gamma correction; |
46 |
greg |
1.1 |
the default value is 2.2. |
47 |
The |
48 |
.I \-e |
49 |
greg |
1.2 |
option specifies a tone-mapping method or exposure compensation. |
50 |
If the argument is one of the special words "auto", "human", or "linear", |
51 |
the image will be tone-mapped with histogram adjustment, |
52 |
human vision simulation, or an averaged linear exposure, |
53 |
respectively. |
54 |
(These words may be abbreviated by one or more letters.)\0 |
55 |
Otherwise, the exposure specification is interpreted as a |
56 |
linear compensation value in integer f-stops, which must |
57 |
be proceeded by a '+' or '-'. |
58 |
greg |
1.3 |
The CRT color output primaries may be specified with the |
59 |
greg |
1.2 |
.I \-p |
60 |
option. |
61 |
.PP |
62 |
greg |
1.1 |
The |
63 |
.I \-r |
64 |
option invokes a reverse conversion, from a Windows BMP image |
65 |
to a RADIANCE picture. |
66 |
greg |
1.2 |
Tone-mapping and monitor primaries are not |
67 |
supported for reverse conversion. |
68 |
.PP |
69 |
greg |
1.1 |
.I Ra_bmp |
70 |
can accept 16-bit or color-mapped BMP files on input, |
71 |
but cannot not produce them on output. |
72 |
.PP |
73 |
A hyphen ('-') may be specified to indicate standard input for |
74 |
either forward or reverse conversion so that an output file may be |
75 |
specified. |
76 |
If the BMP input is taken from the standard input or sent to the |
77 |
greg |
1.3 |
standard output without tone-mapping, then the scanlines may |
78 |
be reversed from their usual ordering. |
79 |
Reversed scanlines sometimes causes difficulties for programs attempting |
80 |
greg |
1.1 |
to interpret the resulting RADIANCE picture or BMP image, which |
81 |
may be rejected or displayed inverted. |
82 |
.SH AUTHOR |
83 |
Greg Ward |
84 |
.SH "SEE ALSO" |
85 |
pfilt(1), ra_ppm(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1), |
86 |
ra_tiff(1), ximage(1) |
