1 |
.TH RA_BMP 1 3/25/04 RADIANCE |
2 |
.SH NAME |
3 |
ra_bmp - convert RADIANCE picture to/from Windows BMP image |
4 |
.SH SYNOPSIS |
5 |
.B ra_bmp |
6 |
7 |
.B \-b |
8 |
9 |
.B "\-g gamma" |
10 |
11 |
.B "\-e +/-stops" |
12 |
13 |
14 |
15 |
.B input|- |
16 |
17 |
.B output |
18 |
19 |
20 |
.br |
21 |
.B ra_bmp |
22 |
.B \-r |
23 |
24 |
.B "\-g gamma" |
25 |
26 |
.B "\-e +/-stops" |
27 |
28 |
29 |
30 |
.B input|- |
31 |
32 |
.B output |
33 |
34 |
35 |
.SH DESCRIPTION |
36 |
.I Ra_bmp |
37 |
converts between RADIANCE and a Windows BMP image. |
38 |
The |
39 |
.I \-b |
40 |
option produces 8-bit grayscale output rather than 24-bit RGB. |
41 |
The |
42 |
.I \-g |
43 |
option specifies the exponent used in gamma correction; |
44 |
the default value is 2.2. |
45 |
The |
46 |
.I \-e |
47 |
option specifies an exposure compensation in f-stops (powers of two |
48 |
and proceeded by +/-). |
49 |
Only integer stops are allowed, for efficiency. |
50 |
The |
51 |
.I \-r |
52 |
option invokes a reverse conversion, from a Windows BMP image |
53 |
to a RADIANCE picture. |
54 |
.I Ra_bmp |
55 |
can accept 16-bit or color-mapped BMP files on input, |
56 |
but cannot not produce them on output. |
57 |
.PP |
58 |
A hyphen ('-') may be specified to indicate standard input for |
59 |
either forward or reverse conversion so that an output file may be |
60 |
specified. |
61 |
If the BMP input is taken from the standard input or sent to the |
62 |
standard output, then the scanlines may be reversed from their |
63 |
usual ordering. |
64 |
This sometimes causes difficulties for programs attempting |
65 |
to interpret the resulting RADIANCE picture or BMP image, which |
66 |
may be rejected or displayed inverted. |
67 |
.SH AUTHOR |
68 |
Greg Ward |
69 |
.SH "SEE ALSO" |
70 |
pfilt(1), ra_ppm(1), ra_pr(1), ra_pr24(1), ra_t8(1), ra_t16(1), |
71 |
ra_tiff(1), ximage(1) |
