root/radiance/ray/doc/man/man1/ra_bmp.1
Mon Oct 4 17:44:21 2004 UTC (20 years, 7 months ago) by greg
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 1.3: +0 -2 lines
Diff to previous 1.3
Thu Sep 23 18:00:53 2004 UTC (20 years, 7 months ago) by greg
Changes since 1.2: +6 -5 lines
Diff to previous 1.2
Fri Apr 30 17:00:28 2004 UTC (21 years ago) by greg
Changes since 1.1: +22 -6 lines
Diff to previous 1.1
Fri Mar 26 22:58:20 2004 UTC (21 years, 1 month ago) by greg
Added support to ra_bmp for 16-bit images and RLE, plus created man page
