root/Development/ray/doc/man/man1/pvsum.1
Revision: 1.5
Committed: Wed Oct 29 02:48:50 2025 UTC (6 weeks, 6 days ago) by greg
Changes since 1.4: +28 -10 lines
feat(pvsum): Added -m option to optimize speed and memory usage
1 .\" RCSid $Id: pvsum.1,v 1.4 2025/05/22 21:39:42 greg Exp $"
2 .TH PVSUM 1 12/09/09 RADIANCE
3 .SH NAME
4 pvsum - sum component Radiance pictures based on vector or matrix
5 .SH SYNOPSIS
6 .B pvsum
7 [
8 .B "\-o ospec"
9 ][
10 .B "\-o{f|c}
11 ][
12 .B "\-N nproc"
13 ][
14 .B "-m cacheGB"
15 ]
16 .B ispec
17 [
18 .B mtx
19 ]
20 .SH DESCRIPTION
21 .I Pvsum
22 is an efficient tool for summing Radiance pictures
23 into one or more output pictures.
24 Similar to
25 .I dctimestep(1),
26 multiple frames are produced if the input
27 .I mtx
28 has more than one column.
29 The number of rows in this matrix corresponds to the
30 number of component pictures specified in
31 .I ispec
32 with an incorporated "%d" or similar format string.
33 The first row in the matrix corresponds to picture 0, and
34 counting proceeds to one less than the number of matrix rows.
35 .PP
36 If no
37 .I mtx
38 is specified on the command line, the required data is read
39 from the standard input.
40 The input matrix
41 must either have a single component or match the number of components
42 in the input pictures, and the output pictures will match the latter component
43 count.
44 (I.e., grayscale float pictures have a component count of 1, RGB and XYZ
45 pictures a count of 3, and spectral pictures typically have 6 or more
46 components.)\0
47 .PP
48 By default, the output pixel type will match that of the input pictures,
49 either floating point or common-exponent byte format (i.e., RGBE, XYZE,
50 or Radiance_spectra).
51 If float output is preferred, specify the
52 .I \-of
53 option.
54 If common-exponent byte format is preferred, use the
55 .I \-oc
56 option.
57 .PP
58 If a
59 .I "\-o ospec"
60 argument begins with an exclamation point ('!') and contains a "%d"
61 format string or similar, then a separate command will be executed
62 for each output stream.
63 If no
64 .I \-o
65 option is given, all data is sent to the standard output,
66 which may be a sequence of Radiance pictures as understood by
67 .I ra_rgbe(1)
68 in the case of a multi-column input matrix.
69 (Note that there is currently no Radiance tool that fully
70 handles a concatenated series of float or spectral pictures.)\0
71 .PP
72 The
73 .I \-N
74 option may be used to specify the number of
75 processes to employ in the summations.
76 This setting has an upper limit equal to
77 the count of matrix columns, but
78 the optimal number of processes depends on several factors.
79 Setting the process count above the number of physical cores may
80 offer some benefit on large input collections if
81 their total size significantly exceeds the available system RAM.
82 .PP
83 Alternatively, one can set
84 .I \-N
85 to the number of cores and the
86 .I \-m
87 option to the free memory cache available in GBytes.
88 (This will be less than the total RAM, due to the operating
89 system and other processes.)\0
90 When
91 .I \-m
92 is set,
93 .I pvsum
94 will make multiple accumulation passes as needed to stay within
95 the available cache space.
96 .PP
97 Experimentation with these settings is encouraged.
98 .SH EXAMPLES
99 To compute Window2's contribution to an interior view at 12 noon on the
100 summer solstice:
101 .IP "" .2i
102 gensky 6 21 12 | genskyvec | rmtxop Blinds30.xml
103 Window2.dmx - | pvsum view%03d.hdr > view_6-21-12.hdr
104 .PP
105 To compute a set of hourly spectral pictures at SFO airport
106 from a weather tape and set of Tregenza component pictures using
107 10 processes and 6.5 GBytes of memory:
108 .IP "" .2i
109 gensdaymtx -of sfo.epw | pvsum -o timestep%04d.hsr -N 10 -m 6.5 tregcomp%03d.hsr
110 .SH NOTES
111 This tool overlaps with
112 .I dctimestep,
113 but provides some missing capabilities and performance features.
114 Foremost,
115 .I pvsum
116 reads and can produce spectral pictures and matrices, whereas
117 .I dctimestep
118 expects and requires 3-component pictures and matrices throughout.
119 In addition,
120 .I pvsum
121 accelerates picture sums on systems with more
122 memory and CPU cores.
123 Operations are simplified by focusing on the Daylight Coefficient
124 command form, where the DC matrix is represented as a collection of
125 pictures.
126 Finally,
127 .I pvsum
128 offers more flexible floating-point support and
129 can output to commands as well as files.
130 .SH AUTHOR
131 Greg Ward
132 .SH "SEE ALSO"
133 dcglare(1), dctimestep(1), gendaymtx(1), gensdaymtx(1), genskyvec(1), getinfo(1),
134 mkillum(1), ra_rgbe(1), rcollate(1), rcomb(1), rcontrib(1), rcrop(1),
135 rfluxmtx(1), rmtxop(1), rtrace(1), rxfluxmtx(1), vwrays(1)
