| 1 |
greg |
1.4 |
.\" RCSid $Id: pvsum.1,v 1.3 2025/03/28 16:36:31 greg Exp $" |
| 2 |
greg |
1.1 |
.TH PVSUM 1 12/09/09 RADIANCE |
| 3 |
.SH NAME |
| 4 |
pvsum - sum component Radiance pictures based on vector or matrix |
| 5 |
.SH SYNOPSIS |
| 6 |
.B pvsum |
| 7 |
| 8 |
.B "\-o ospec" |
| 9 |
| 10 |
.B "\-o{f|c} |
| 11 |
| 12 |
.B "\-N nproc" |
| 13 |
| 14 |
.B ispec |
| 15 |
| 16 |
.B mtx |
| 17 |
| 18 |
.SH DESCRIPTION |
| 19 |
.I Pvsum |
| 20 |
is an efficient tool for summing Radiance pictures |
| 21 |
into one or more output pictures. |
| 22 |
Similar to |
| 23 |
.I dctimestep(1), |
| 24 |
multiple frames are produced if the input |
| 25 |
.I mtx |
| 26 |
has more than one column. |
| 27 |
The number of rows in this matrix corresponds to the |
| 28 |
number of component pictures specified in |
| 29 |
.I ispec |
| 30 |
with an incorporated "%d" or similar format string. |
| 31 |
The first row in the matrix corresponds to picture 0, and |
| 32 |
counting proceeds to one less than the number of matrix rows. |
| 33 |
.PP |
| 34 |
If no |
| 35 |
.I mtx |
| 36 |
is specified on the command line, the required data is read |
| 37 |
from the standard input. |
| 38 |
The input matrix |
| 39 |
must either have a single component or match the number of components |
| 40 |
in the input pictures, and the output pictures will match the latter component |
| 41 |
count. |
| 42 |
(I.e., grayscale float pictures have a component count of 1, RGB and XYZ |
| 43 |
pictures a count of 3, and spectral pictures typically have 6 or more |
| 44 |
components.)\0 |
| 45 |
.PP |
| 46 |
By default, the output pixel type will match that of the input pictures, |
| 47 |
either floating point or common-exponent byte format (i.e., RGBE, XYZE, |
| 48 |
or Radiance_spectra). |
| 49 |
If float output is preferred, specify the |
| 50 |
.I \-of |
| 51 |
option. |
| 52 |
If common-exponent byte format is preferred, use the |
| 53 |
.I \-oc |
| 54 |
option. |
| 55 |
.PP |
| 56 |
If a |
| 57 |
.I "\-o ospec" |
| 58 |
argument begins with an exclamation point ('!') and contains a "%d" |
| 59 |
format string or similar, then a separate command will be executed |
| 60 |
for each output stream. |
| 61 |
If no |
| 62 |
.I \-o |
| 63 |
option is given, all data is sent to the standard output, |
| 64 |
which may be a sequence of Radiance pictures as understood by |
| 65 |
.I ra_rgbe(1) |
| 66 |
in the case of a multi-column input matrix. |
| 67 |
greg |
1.3 |
(Note that there is currently no Radiance tool that fully |
| 68 |
handles a concatenated series of float or spectral pictures.)\0 |
| 69 |
greg |
1.1 |
.PP |
| 70 |
The |
| 71 |
.I \-N |
| 72 |
option may be used on Unix systems to specify the number of |
| 73 |
processes to employ in the summations. |
| 74 |
This setting has an upper limit equal to |
| 75 |
the count of matrix columns, but |
| 76 |
the optimal number of processes depends on several factors. |
| 77 |
Setting the process count above the number of physical cores may |
| 78 |
offer some benefit on large input collections if |
| 79 |
their total size significantly exceeds the available system RAM. |
| 80 |
Experimentation with this setting is therefore encouraged. |
| 81 |
.SH EXAMPLES |
| 82 |
To compute Window2's contribution to an interior view at 12 noon on the summer solstice: |
| 83 |
.IP "" .2i |
| 84 |
gensky 6 21 12 | genskyvec | rmtxop Blinds30.xml |
| 85 |
Window2.dmx - | pvsum view%03d.hdr > view_6-21-12.hdr |
| 86 |
.PP |
| 87 |
To compute a set of hourly spectral pictures at SFO airport |
| 88 |
greg |
1.2 |
from a weather tape and set of Tregenza component pictures using |
| 89 |
10 processes: |
| 90 |
greg |
1.1 |
.IP "" .2i |
| 91 |
greg |
1.2 |
gensdaymtx -of sfo.epw | pvsum -o timestep%04d.hsr -N 10 tregcomp%03d.hsr |
| 92 |
greg |
1.1 |
.SH NOTES |
| 93 |
greg |
1.2 |
This tool overlaps with |
| 94 |
greg |
1.1 |
.I dctimestep, |
| 95 |
greg |
1.4 |
but provides some missing capabilities. |
| 96 |
Foremost, |
| 97 |
greg |
1.1 |
.I pvsum |
| 98 |
reads and can produce spectral pictures and matrices, whereas |
| 99 |
.I dctimestep |
| 100 |
expects and requires 3-component pictures and matrices throughout. |
| 101 |
greg |
1.4 |
In addition, |
| 102 |
greg |
1.1 |
.I pvsum |
| 103 |
accelerates picture sums on Unix systems with more |
| 104 |
greg |
1.4 |
memory and CPU cores. |
| 105 |
Operations were simplified by focusing on the Daylight Coefficient |
| 106 |
greg |
1.1 |
command form, where the DC matrix is represented as a collection of |
| 107 |
pictures. |
| 108 |
greg |
1.4 |
Finally, |
| 109 |
.I pvsum |
| 110 |
offers more flexible floating-point support and |
| 111 |
can output to commands as well as files. |
| 112 |
greg |
1.1 |
.SH AUTHOR |
| 113 |
Greg Ward |
| 114 |
.SH "SEE ALSO" |
| 115 |
dcglare(1), dctimestep(1), gendaymtx(1), gensdaymtx(1), genskyvec(1), getinfo(1), |
| 116 |
mkillum(1), ra_rgbe(1), rcollate(1), rcomb(1), rcontrib(1), rcrop(1), |
| 117 |
rfluxmtx(1), rmtxop(1), rtrace(1), vwrays(1) |
