root/Development/ray/doc/man/man1/pvsum.1
Revision: 1.5
Committed: Wed Oct 29 02:48:50 2025 UTC (7 weeks, 4 days ago) by greg
Changes since 1.4: +28 -10 lines
feat(pvsum): Added -m option to optimize speed and memory usage
# User Rev Content
1 greg 1.5 .\" RCSid $Id: pvsum.1,v 1.4 2025/05/22 21:39:42 greg Exp $"
2 greg 1.1 .TH PVSUM 1 12/09/09 RADIANCE
3     .SH NAME
4     pvsum - sum component Radiance pictures based on vector or matrix
5     .SH SYNOPSIS
6     .B pvsum
7     [
8     .B "\-o ospec"
9     ][
10     .B "\-o{f|c}
11     ][
12     .B "\-N nproc"
13 greg 1.5 ][
14     .B "-m cacheGB"
15 greg 1.1 ]
16     .B ispec
17     [
18     .B mtx
19     ]
20     .SH DESCRIPTION
21     .I Pvsum
22     is an efficient tool for summing Radiance pictures
23     into one or more output pictures.
24     Similar to
25     .I dctimestep(1),
26     multiple frames are produced if the input
27     .I mtx
28     has more than one column.
29     The number of rows in this matrix corresponds to the
30     number of component pictures specified in
31     .I ispec
32     with an incorporated "%d" or similar format string.
33     The first row in the matrix corresponds to picture 0, and
34     counting proceeds to one less than the number of matrix rows.
35     .PP
36     If no
37     .I mtx
38     is specified on the command line, the required data is read
39     from the standard input.
40     The input matrix
41     must either have a single component or match the number of components
42     in the input pictures, and the output pictures will match the latter component
43     count.
44     (I.e., grayscale float pictures have a component count of 1, RGB and XYZ
45     pictures a count of 3, and spectral pictures typically have 6 or more
46     components.)\0
47     .PP
48     By default, the output pixel type will match that of the input pictures,
49     either floating point or common-exponent byte format (i.e., RGBE, XYZE,
50     or Radiance_spectra).
51     If float output is preferred, specify the
52     .I \-of
53     option.
54     If common-exponent byte format is preferred, use the
55     .I \-oc
56     option.
57     .PP
58     If a
59     .I "\-o ospec"
60     argument begins with an exclamation point ('!') and contains a "%d"
61     format string or similar, then a separate command will be executed
62     for each output stream.
63     If no
64     .I \-o
65     option is given, all data is sent to the standard output,
66     which may be a sequence of Radiance pictures as understood by
67     .I ra_rgbe(1)
68     in the case of a multi-column input matrix.
69 greg 1.3 (Note that there is currently no Radiance tool that fully
70     handles a concatenated series of float or spectral pictures.)\0
71 greg 1.1 .PP
72     The
73     .I \-N
74 greg 1.5 option may be used to specify the number of
75 greg 1.1 processes to employ in the summations.
76     This setting has an upper limit equal to
77     the count of matrix columns, but
78     the optimal number of processes depends on several factors.
79     Setting the process count above the number of physical cores may
80     offer some benefit on large input collections if
81     their total size significantly exceeds the available system RAM.
82 greg 1.5 .PP
83     Alternatively, one can set
84     .I \-N
85     to the number of cores and the
86     .I \-m
87     option to the free memory cache available in GBytes.
88     (This will be less than the total RAM, due to the operating
89     system and other processes.)\0
90     When
91     .I \-m
92     is set,
93     .I pvsum
94     will make multiple accumulation passes as needed to stay within
95     the available cache space.
96     .PP
97     Experimentation with these settings is encouraged.
98 greg 1.1 .SH EXAMPLES
99 greg 1.5 To compute Window2's contribution to an interior view at 12 noon on the
100     summer solstice:
101 greg 1.1 .IP "" .2i
102     gensky 6 21 12 | genskyvec | rmtxop Blinds30.xml
103     Window2.dmx - | pvsum view%03d.hdr > view_6-21-12.hdr
104     .PP
105     To compute a set of hourly spectral pictures at SFO airport
106 greg 1.2 from a weather tape and set of Tregenza component pictures using
107 greg 1.5 10 processes and 6.5 GBytes of memory:
108 greg 1.1 .IP "" .2i
109 greg 1.5 gensdaymtx -of sfo.epw | pvsum -o timestep%04d.hsr -N 10 -m 6.5 tregcomp%03d.hsr
110 greg 1.1 .SH NOTES
111 greg 1.2 This tool overlaps with
112 greg 1.1 .I dctimestep,
113 greg 1.5 but provides some missing capabilities and performance features.
114 greg 1.4 Foremost,
115 greg 1.1 .I pvsum
116     reads and can produce spectral pictures and matrices, whereas
117     .I dctimestep
118     expects and requires 3-component pictures and matrices throughout.
119 greg 1.4 In addition,
120 greg 1.1 .I pvsum
121 greg 1.5 accelerates picture sums on systems with more
122 greg 1.4 memory and CPU cores.
123 greg 1.5 Operations are simplified by focusing on the Daylight Coefficient
124 greg 1.1 command form, where the DC matrix is represented as a collection of
125     pictures.
126 greg 1.4 Finally,
127     .I pvsum
128     offers more flexible floating-point support and
129     can output to commands as well as files.
130 greg 1.1 .SH AUTHOR
131     Greg Ward
132     .SH "SEE ALSO"
133     dcglare(1), dctimestep(1), gendaymtx(1), gensdaymtx(1), genskyvec(1), getinfo(1),
134     mkillum(1), ra_rgbe(1), rcollate(1), rcomb(1), rcontrib(1), rcrop(1),
135 greg 1.5 rfluxmtx(1), rmtxop(1), rtrace(1), rxfluxmtx(1), vwrays(1)
