--- ray/doc/man/man1/pvalue.1 2008/11/10 19:08:17 1.7 +++ ray/doc/man/man1/pvalue.1 2024/09/11 18:56:11 1.13 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: pvalue.1,v 1.7 2008/11/10 19:08:17 greg Exp $" +.\" RCSid "$Id: pvalue.1,v 1.13 2024/09/11 18:56:11 greg Exp $" .TH PVALUE 1 1/15/99 RADIANCE .SH NAME pvalue - convert RADIANCE picture to/from alternate formats @@ -42,6 +42,10 @@ these files. .TP 10n .BR \-u Print only unique values in the output, skipping runs of equal pixels. +For reverse conversions, the +.I \-u +option writes uncompressed output rather than the standard run-length RGBE +encoding. Specifying .I \+u turns this option off, which is the default. @@ -49,8 +53,9 @@ turns this option off, which is the default. .BR \-o Print original values, before exposure compensation. If the input file is in XYZE format, the Y (green) channel -will correspond to units of candelas/meter^2. -Otherwise, the RGB values should be in spectral watts/steradian/meter^2. +will correspond to units of candelas/meter^2, unless +.I \-O +is specified, when watts/sr/meter^2 are always reported. Specifying .I \+o uses final exposed values, which is the default. @@ -76,7 +81,6 @@ causes the resolution string to be printed, which is t Skip the specified number of bytes on the input header. This option is useful for skipping unintelligible headers in foreign file formats. -(Does not work when reading from standard input.) .TP .BI \-e \ exposure Adjust the exposure by the amount specified. @@ -180,6 +184,14 @@ Specifying converts from a Radiance picture to other values, which is the default. .TP +.BI \-p " xr yr xg yg xb yb xw yw" +On reverse conversion, RGB input uses the given set of color primaries. +These are written into the output header with the PRIMARIES variable. +.TP +.BR \-pXYZ +On reverse conversion, input is in CIE XYZ coordinates, rather than RGB. +The Y channel is assumed to be in candelas/meter^2. +.TP .BI -y \ res Set the output y resolution to .I res. @@ -228,17 +240,19 @@ left to right scanline ordering: pvalue \-r \-db \-b \-h +y 400 +x 512 input.im > flipped.hdr .br pflip \-v flipped.hdr > final.hdr +.SH NOTES +Hyperspectral Radiance pictures (.hsr files) are +converted to approximate RGB. +However, the colors may not be very accurate. +Use +.I rcomb(1) +for conversion if greater color fidelity is required. .SH AUTHOR Greg Ward .SH BUGS -The -.I \-r -option does not work with the -.I \-u -option. -Also, input pixel locations are ignored during a reverse +Input pixel locations are ignored during a reverse conversion, so this information is not used in determining the scanline ordering or picture size. .SH "SEE ALSO" getinfo(1), pcompos(1), pfilt(1), pflip(1), -protate(1), rpict(1), rtrace(1), rvu(1) +protate(1), ra_xyze(1), rcomb(1), rpict(1), rtrace(1), rvu(1)
