--- ray/doc/man/man1/pvalue.1 2019/07/18 14:45:59 1.11 +++ ray/doc/man/man1/pvalue.1 2022/02/04 20:11:48 1.12 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: pvalue.1,v 1.11 2019/07/18 14:45:59 greg Exp $" +.\" RCSid "$Id: pvalue.1,v 1.12 2022/02/04 20:11:48 greg Exp $" .TH PVALUE 1 1/15/99 RADIANCE .SH NAME pvalue - convert RADIANCE picture to/from alternate formats @@ -53,8 +53,9 @@ turns this option off, which is the default. .BR \-o Print original values, before exposure compensation. If the input file is in XYZE format, the Y (green) channel -will correspond to units of candelas/meter^2. -Otherwise, the RGB values should be in spectral watts/steradian/meter^2. +will correspond to units of candelas/meter^2, unless +.I \-O +is specified, when watts/sr/meter^2 are always reported. Specifying .I \+o uses final exposed values, which is the default.
