| 1 |
.\" RCSid "$Id: pvalue.1,v 1.4 2004/01/01 19:31:45 greg Exp $"
| 2 |
.TH PVALUE 1 1/15/99 RADIANCE
| 3 |
.SH NAME
| 4 |
pvalue - convert RADIANCE picture to/from alternate formats
| 5 |
.SH SYNOPSIS
| 6 |
.B pvalue
| 7 |
| 8 |
.B options
| 9 |
| 10 |
| 11 |
.B file
| 12 |
| 13 |
.br
| 14 |
.B "pvalue -r"
| 15 |
| 16 |
.B options
| 17 |
| 18 |
| 19 |
.B file1
| 20 |
| 21 |
.B "file2 file3"
| 22 |
| 23 |
| 24 |
.SH DESCRIPTION
| 25 |
.I Pvalue
| 26 |
converts the pixels of a RADIANCE picture to or from another format.
| 27 |
In the default mode, pixels are sent to the
| 28 |
standard output, one per line, in the following ascii format:
| 29 |
| 30 |
xpos ypos red green blue
| 31 |
| 32 |
If no
| 33 |
.I file
| 34 |
is given, the standard input is read.
| 35 |
.PP
| 36 |
The reverse conversion option
| 37 |
.I (-r)
| 38 |
may be used with a single input file or when reading from the
| 39 |
standard input, but if the second form is used with three separate
| 40 |
input files, the three primaries are presumed to be separated in
| 41 |
these files.
| 42 |
.TP 10n
| 43 |
.BR \-u
| 44 |
Print only unique values in the output, skipping runs of equal pixels.
| 45 |
Specifying
| 46 |
.I \+u
| 47 |
turns this option off, which is the default.
| 48 |
.TP
| 49 |
.BR \-o
| 50 |
Print original values, before exposure compensation.
| 51 |
If the input file is in XYZE format, the Y (green) channel
| 52 |
will correspond to units of candelas/meter^2.
| 53 |
Otherwise, the RGB values should be in spectral watts/steradian/meter^2.
| 54 |
Specifying
| 55 |
.I \+o
| 56 |
uses final exposed values, which is the default.
| 57 |
.TP
| 58 |
.BR \-h
| 59 |
Do not print header.
| 60 |
Specifying
| 61 |
.I \+h
| 62 |
causes the header to be printed, which is the default.
| 63 |
.TP
| 64 |
.BI \-H
| 65 |
Do not print the resolution string.
| 66 |
(See also the
| 67 |
.I \-r
| 68 |
option below.)
| 69 |
Specifying an input resolution for reverse conversion also turns
| 70 |
this option off.
| 71 |
Specifying
| 72 |
.I \+H
| 73 |
causes the resolution string to be printed, which is the default.
| 74 |
.TP
| 75 |
.BI \-s \ nbytes
| 76 |
Skip the specified number of bytes on the input header.
| 77 |
This option is useful for skipping unintelligible headers in
| 78 |
foreign file formats.
| 79 |
(Does not work when reading from standard input.)
| 80 |
.TP
| 81 |
.BI \-e \ exposure
| 82 |
Adjust the exposure by the amount specified.
| 83 |
If the exposure is being given as a conversion factor, use
| 84 |
.I \+e
| 85 |
instead, so an EXPOSURE line will not be recorded in the header
| 86 |
(if any).
| 87 |
.TP
| 88 |
.BI \-g \ gamma
| 89 |
Set gamma correction for conversion.
| 90 |
When converting from a RADIANCE picture to another format,
| 91 |
the inverse gamma is applied to correct for monitor response.
| 92 |
When converting to a RADIANCE picture
| 93 |
.I (\-r
| 94 |
option), the gamma is applied directly to recover the linear values.
| 95 |
By default,
| 96 |
.I gamma
| 97 |
is set to 1.0, meaning no gamma correction is performed.
| 98 |
.TP
| 99 |
.BR \-d
| 100 |
Data only,
| 101 |
do not print x and y pixel position.
| 102 |
.TP
| 103 |
.BR \-da
| 104 |
Same as
| 105 |
.I \-d.
| 106 |
.TP
| 107 |
.BR \-di
| 108 |
Print ascii integer values from 0 to 255+.
| 109 |
If
| 110 |
.I \+di
| 111 |
is given, the integer values will be preceded by
| 112 |
the x and y pixel locations.
| 113 |
.TP
| 114 |
.BR \-db
| 115 |
Output binary byte values from 0 to 255.
| 116 |
.TP
| 117 |
.BR \-dw
| 118 |
Output binary 16-bit words from 0 to 65535.
| 119 |
.TP
| 120 |
.BR \-dW
| 121 |
Output binary 16-bit words from 0 to 65535, byte-swapped.
| 122 |
.TP
| 123 |
.BR \-df
| 124 |
Output binary float values.
| 125 |
.TP
| 126 |
.BR \-dF
| 127 |
Output byte-swapped binary float values.
| 128 |
.TP
| 129 |
.BR \-dd
| 130 |
Output binary double values.
| 131 |
.TP
| 132 |
.BR \-dD
| 133 |
Output byte-swapped binary double values.
| 134 |
.TP
| 135 |
.BR \-R
| 136 |
Reverse ordering of colors so that the output is blue then green
| 137 |
then red.
| 138 |
The default ordering (specified with
| 139 |
.I \+R)
| 140 |
is red then green then blue.
| 141 |
.TP
| 142 |
.BR \-n
| 143 |
The RGB values are non-interleaved, meaning that all the red, green
| 144 |
and blue data are stored together in separate chunks.
| 145 |
Interleaving may be turned on with the
| 146 |
.I \+n
| 147 |
option, which is the default.
| 148 |
.TP
| 149 |
.BR \-b
| 150 |
Print brightness values rather than RGB.
| 151 |
Specifying
| 152 |
.I \+b
| 153 |
| 154 |
.TP
| 155 |
.BI \-p P
| 156 |
Put out only the primary
| 157 |
.I P,
| 158 |
where
| 159 |
.I P
| 160 |
is one of upper or lower case 'R', 'G' or 'B' for red, green or
| 161 |
blue, respectively.
| 162 |
This option may be used to separate the Radiance primaries into
| 163 |
three files with three separate runs of
| 164 |
.I pvalue,
| 165 |
or only one file when only one primary is needed.
| 166 |
Note that there is no space between this option and its argument.
| 167 |
.TP
| 168 |
.BR \-r
| 169 |
Perform reverse conversion.
| 170 |
Input is in the format given by the other options.
| 171 |
The x and y resolution must be specified on the command line, unless
| 172 |
the image file contains a Radiance resolution string at the
| 173 |
beginning (see
| 174 |
.I \-H
| 175 |
option above and
| 176 |
.I \-y
| 177 |
option below).
| 178 |
Specifying
| 179 |
.I \+r
| 180 |
converts from a Radiance picture to other values, which is the
| 181 |
default.
| 182 |
.TP
| 183 |
.BI -y \ res
| 184 |
Set the output y resolution to
| 185 |
.I res.
| 186 |
If
| 187 |
.I \+y
| 188 |
is specified, then the scanlines are assumed to be in
| 189 |
increasing order (ie. bottom to top).
| 190 |
The default value for this option is 0, which means
| 191 |
that the picture size and scanline order must appear
| 192 |
as the first line after the header (if any) in the
| 193 |
input file.
| 194 |
Either an upper or lower case 'Y' may be used for this option.
| 195 |
Since Radiance files always contain such a line,
| 196 |
this option has no effect for forward conversions.
| 197 |
.TP
| 198 |
.BI +x \ res
| 199 |
Set the output x resolution to
| 200 |
.I res.
| 201 |
If
| 202 |
.I \-x
| 203 |
| 204 |
decreasing order (ie. right to left).
| 205 |
The ordering of the
| 206 |
.I \-y
| 207 |
and
| 208 |
.I \+x
| 209 |
options determines whether the scanlines are sorted along
| 210 |
x or along y.
| 211 |
Most Radiance pictures are sorted top to bottom, then left
| 212 |
to right.
| 213 |
This corresponds to a specification of the form "-y yres +x xres".
| 214 |
Either an upper or lower case 'X' may be used for this option.
| 215 |
Like the
| 216 |
.I \-y
| 217 |
option,
| 218 |
.I \-x
| 219 |
options have no effect for forward conversions.
| 220 |
.SH EXAMPLE
| 221 |
To look at the original, unique pixels in picture:
| 222 |
.IP "" .2i
| 223 |
pvalue -o -u picture | more
| 224 |
.PP
| 225 |
To convert from a 512x400 8-bit greyscale image in bottom to top,
| 226 |
left to right scanline ordering:
| 227 |
.IP "" .2i
| 228 |
pvalue -r -db -b -h +y 400 +x 512 input.im > flipped.pic
| 229 |
.br
| 230 |
pflip -v flipped.pic > final.pic
| 231 |
.SH AUTHOR
| 232 |
Greg Ward
| 233 |
.SH BUGS
| 234 |
The
| 235 |
.I \-r
| 236 |
option does not work with the
| 237 |
.I \-u
| 238 |
option.
| 239 |
Also, input pixel locations are ignored during a reverse
| 240 |
conversion, so this information is not used in determining
| 241 |
the scanline ordering or picture size.
| 242 |
.SH "SEE ALSO"
| 243 |
getinfo(1), pcompos(1), pfilt(1), pflip(1),
| 244 |
protate(1), rpict(1), rtrace(1), rvu(1)
