root/Development/ray/doc/man/man1/pvalue.1
Revision: 1.12
Committed: Fri Feb 4 20:11:48 2022 UTC (3 years, 11 months ago) by greg
Changes since 1.11: +4 -3 lines
feat(pvalue,pextrem): Added -O option to report watts/sr/meter^2 always
1 .\" RCSid "$Id: pvalue.1,v 1.11 2019/07/18 14:45:59 greg Exp $"
2 .TH PVALUE 1 1/15/99 RADIANCE
3 .SH NAME
4 pvalue - convert RADIANCE picture to/from alternate formats
5 .SH SYNOPSIS
6 .B pvalue
7 [
8 .B options
9 ]
10 [
11 .B file
12 ]
13 .br
14 .B "pvalue -r"
15 [
16 .B options
17 ]
18 [
19 .B file1
20 [
21 .B "file2 file3"
22 ]
23 ]
24 .SH DESCRIPTION
25 .I Pvalue
26 converts the pixels of a RADIANCE picture to or from another format.
27 In the default mode, pixels are sent to the
28 standard output, one per line, in the following ascii format:
29
30 xpos ypos red green blue
31
32 If no
33 .I file
34 is given, the standard input is read.
35 .PP
36 The reverse conversion option
37 .I (-r)
38 may be used with a single input file or when reading from the
39 standard input, but if the second form is used with three separate
40 input files, the three primaries are presumed to be separated in
41 these files.
42 .TP 10n
43 .BR \-u
44 Print only unique values in the output, skipping runs of equal pixels.
45 For reverse conversions, the
46 .I \-u
47 option writes uncompressed output rather than the standard run-length RGBE
48 encoding.
49 Specifying
50 .I \+u
51 turns this option off, which is the default.
52 .TP
53 .BR \-o
54 Print original values, before exposure compensation.
55 If the input file is in XYZE format, the Y (green) channel
56 will correspond to units of candelas/meter^2, unless
57 .I \-O
58 is specified, when watts/sr/meter^2 are always reported.
59 Specifying
60 .I \+o
61 uses final exposed values, which is the default.
62 .TP
63 .BR \-h
64 Do not print header.
65 Specifying
66 .I \+h
67 causes the header to be printed, which is the default.
68 .TP
69 .BI \-H
70 Do not print the resolution string.
71 (See also the
72 .I \-r
73 option below.)
74 Specifying an input resolution for reverse conversion also turns
75 this option off.
76 Specifying
77 .I \+H
78 causes the resolution string to be printed, which is the default.
79 .TP
80 .BI \-s \ nbytes
81 Skip the specified number of bytes on the input header.
82 This option is useful for skipping unintelligible headers in
83 foreign file formats.
84 .TP
85 .BI \-e \ exposure
86 Adjust the exposure by the amount specified.
87 If the exposure is being given as a conversion factor, use
88 .I \+e
89 instead, so an EXPOSURE line will not be recorded in the header
90 (if any).
91 .TP
92 .BI \-g \ gamma
93 Set gamma correction for conversion.
94 When converting from a RADIANCE picture to another format,
95 the inverse gamma is applied to correct for monitor response.
96 When converting to a RADIANCE picture
97 .I (\-r
98 option), the gamma is applied directly to recover the linear values.
99 By default,
100 .I gamma
101 is set to 1.0, meaning no gamma correction is performed.
102 .TP
103 .BR \-d
104 Data only,
105 do not print x and y pixel position.
106 .TP
107 .BR \-da
108 Same as
109 .I \-d.
110 .TP
111 .BR \-di
112 Print ascii integer values from 0 to 255+.
113 If
114 .I \+di
115 is given, the integer values will be preceded by
116 the x and y pixel locations.
117 .TP
118 .BR \-db
119 Output binary byte values from 0 to 255.
120 .TP
121 .BR \-dw
122 Output binary 16-bit words from 0 to 65535.
123 .TP
124 .BR \-dW
125 Output binary 16-bit words from 0 to 65535, byte-swapped.
126 .TP
127 .BR \-df
128 Output binary float values.
129 .TP
130 .BR \-dF
131 Output byte-swapped binary float values.
132 .TP
133 .BR \-dd
134 Output binary double values.
135 .TP
136 .BR \-dD
137 Output byte-swapped binary double values.
138 .TP
139 .BR \-R
140 Reverse ordering of colors so that the output is blue then green
141 then red.
142 The default ordering (specified with
143 .I \+R)
144 is red then green then blue.
145 .TP
146 .BR \-n
147 The RGB values are non-interleaved, meaning that all the red, green
148 and blue data are stored together in separate chunks.
149 Interleaving may be turned on with the
150 .I \+n
151 option, which is the default.
152 .TP
153 .BR \-b
154 Print brightness values rather than RGB.
155 Specifying
156 .I \+b
157 turns this option off, which is the default.
158 .TP
159 .BI \-p P
160 Put out only the primary
161 .I P,
162 where
163 .I P
164 is one of upper or lower case 'R', 'G' or 'B' for red, green or
165 blue, respectively.
166 This option may be used to separate the Radiance primaries into
167 three files with three separate runs of
168 .I pvalue,
169 or only one file when only one primary is needed.
170 Note that there is no space between this option and its argument.
171 .TP
172 .BR \-r
173 Perform reverse conversion.
174 Input is in the format given by the other options.
175 The x and y resolution must be specified on the command line, unless
176 the image file contains a Radiance resolution string at the
177 beginning (see
178 .I \-H
179 option above and
180 .I \-y
181 option below).
182 Specifying
183 .I \+r
184 converts from a Radiance picture to other values, which is the
185 default.
186 .TP
187 .BI \-p " xr yr xg yg xb yb xw yw"
188 On reverse conversion, RGB input uses the given set of color primaries.
189 These are written into the output header with the PRIMARIES variable.
190 .TP
191 .BR \-pXYZ
192 On reverse conversion, input is in CIE XYZ coordinates, rather than RGB.
193 The Y channel is assumed to be in candelas/meter^2.
194 .TP
195 .BI -y \ res
196 Set the output y resolution to
197 .I res.
198 If
199 .I \+y
200 is specified, then the scanlines are assumed to be in
201 increasing order (ie. bottom to top).
202 The default value for this option is 0, which means
203 that the picture size and scanline order must appear
204 as the first line after the header (if any) in the
205 input file.
206 Either an upper or lower case 'Y' may be used for this option.
207 Since Radiance files always contain such a line,
208 this option has no effect for forward conversions.
209 .TP
210 .BI +x \ res
211 Set the output x resolution to
212 .I res.
213 If
214 .I \-x
215 is specified, then the scanlines are assumed to be in
216 decreasing order (ie. right to left).
217 The ordering of the
218 .I \-y
219 and
220 .I \+x
221 options determines whether the scanlines are sorted along
222 x or along y.
223 Most Radiance pictures are sorted top to bottom, then left
224 to right.
225 This corresponds to a specification of the form "\-y yres +x xres".
226 Either an upper or lower case 'X' may be used for this option.
227 Like the
228 .I \-y
229 option,
230 .I \-x
231 options have no effect for forward conversions.
232 .SH EXAMPLE
233 To look at the original, unique pixels in picture:
234 .IP "" .2i
235 pvalue \-o \-u picture | more
236 .PP
237 To convert from a 512x400 8-bit greyscale image in bottom to top,
238 left to right scanline ordering:
239 .IP "" .2i
240 pvalue \-r \-db \-b \-h +y 400 +x 512 input.im > flipped.hdr
241 .br
242 pflip \-v flipped.hdr > final.hdr
243 .SH AUTHOR
244 Greg Ward
245 .SH BUGS
246 Input pixel locations are ignored during a reverse
247 conversion, so this information is not used in determining
248 the scanline ordering or picture size.
249 .SH "SEE ALSO"
250 getinfo(1), pcompos(1), pfilt(1), pflip(1),
251 protate(1), ra_xyze(1), rpict(1), rtrace(1), rvu(1)
