root/radiance/ray/doc/man/man1/pvalue.1
Revision: 1.4
Committed: Thu Jan 1 19:31:45 2004 UTC (20 years, 5 months ago) by greg
1 .\" RCSid "$Id: pvalue.1,v 1.3 2003/12/09 15:59:06 greg Exp $"
2 .TH PVALUE 1 1/15/99 RADIANCE
3 .SH NAME
4 pvalue - convert RADIANCE picture to/from alternate formats
5 .SH SYNOPSIS
6 .B pvalue
7 [
8 .B options
9 ]
10 [
11 .B file
12 ]
13 .br
14 .B "pvalue -r"
15 [
16 .B options
17 ]
18 [
19 .B file1
20 [
21 .B "file2 file3"
22 ]
23 ]
24 .SH DESCRIPTION
25 .I Pvalue
26 converts the pixels of a RADIANCE picture to or from another format.
27 In the default mode, pixels are sent to the
28 standard output, one per line, in the following ascii format:
29
30 xpos ypos red green blue
31
32 If no
33 .I file
34 is given, the standard input is read.
35 .PP
36 The reverse conversion option
37 .I (-r)
38 may be used with a single input file or when reading from the
39 standard input, but if the second form is used with three separate
40 input files, the three primaries are presumed to be separated in
41 these files.
42 .TP 10n
43 .BR \-u
44 Print only unique values in the output, skipping runs of equal pixels.
45 Specifying
46 .I \+u
47 turns this option off, which is the default.
48 .TP
49 .BR \-o
50 Print original values, before exposure compensation.
51 Specifying
52 .I \+o
53 uses final values, which is the default.
54 .TP
55 .BR \-h
56 Do not print header.
57 Specifying
58 .I \+h
59 causes the header to be printed, which is the default.
60 .TP
61 .BI \-H
62 Do not print the resolution string.
63 (See also the
64 .I \-r
65 option below.)
66 Specifying an input resolution for reverse conversion also turns
67 this option off.
68 Specifying
69 .I \+H
70 causes the resolution string to be printed, which is the default.
71 .TP
72 .BI \-s \ nbytes
73 Skip the specified number of bytes on the input header.
74 This option is useful for skipping unintelligible headers in
75 foreign file formats.
76 (Does not work when reading from standard input.)
77 .TP
78 .BI \-e \ exposure
79 Adjust the exposure by the amount specified.
80 If the exposure is being given as a conversion factor, use
81 .I \+e
82 instead, so an EXPOSURE line will not be recorded in the header
83 (if any).
84 .TP
85 .BI \-g \ gamma
86 Set gamma correction for conversion.
87 When converting from a RADIANCE picture to another format,
88 the inverse gamma is applied to correct for monitor response.
89 When converting to a RADIANCE picture
90 .I (\-r
91 option), the gamma is applied directly to recover the linear values.
92 By default,
93 .I gamma
94 is set to 1.0, meaning no gamma correction is performed.
95 .TP
96 .BR \-d
97 Data only,
98 do not print x and y pixel position.
99 .TP
100 .BR \-da
101 Same as
102 .I \-d.
103 .TP
104 .BR \-di
105 Print ascii integer values from 0 to 255+.
106 If
107 .I \+di
108 is given, the integer values will be preceded by
109 the x and y pixel locations.
110 .TP
111 .BR \-db
112 Output binary byte values from 0 to 255.
113 .TP
114 .BR \-dw
115 Output binary 16-bit words from 0 to 65535.
116 .TP
117 .BR \-dW
118 Output binary 16-bit words from 0 to 65535, byte-swapped.
119 .TP
120 .BR \-df
121 Output binary float values.
122 .TP
123 .BR \-dF
124 Output byte-swapped binary float values.
125 .TP
126 .BR \-dd
127 Output binary double values.
128 .TP
129 .BR \-dD
130 Output byte-swapped binary double values.
131 .TP
132 .BR \-R
133 Reverse ordering of colors so that the output is blue then green
134 then red.
135 The default ordering (specified with
136 .I \+R)
137 is red then green then blue.
138 .TP
139 .BR \-n
140 The RGB values are non-interleaved, meaning that all the red, green
141 and blue data are stored together in separate chunks.
142 Interleaving may be turned on with the
143 .I \+n
144 option, which is the default.
145 .TP
146 .BR \-b
147 Print brightness values rather than RGB.
148 Specifying
149 .I \+b
150 turns this option off, which is the default.
151 .TP
152 .BI \-p P
153 Put out only the primary
154 .I P,
155 where
156 .I P
157 is one of upper or lower case 'R', 'G' or 'B' for red, green or
158 blue, respectively.
159 This option may be used to separate the Radiance primaries into
160 three files with three separate runs of
161 .I pvalue,
162 or only one file when only one primary is needed.
163 Note that there is no space between this option and its argument.
164 .TP
165 .BR \-r
166 Perform reverse conversion.
167 Input is in the format given by the other options.
168 The x and y resolution must be specified on the command line, unless
169 the image file contains a Radiance resolution string at the
170 beginning (see
171 .I \-H
172 option above and
173 .I \-y
174 option below).
175 Specifying
176 .I \+r
177 converts from a Radiance picture to other values, which is the
178 default.
179 .TP
180 .BI -y \ res
181 Set the output y resolution to
182 .I res.
183 If
184 .I \+y
185 is specified, then the scanlines are assumed to be in
186 increasing order (ie. bottom to top).
187 The default value for this option is 0, which means
188 that the picture size and scanline order must appear
189 as the first line after the header (if any) in the
190 input file.
191 Either an upper or lower case 'Y' may be used for this option.
192 Since Radiance files always contain such a line,
193 this option has no effect for forward conversions.
194 .TP
195 .BI +x \ res
196 Set the output x resolution to
197 .I res.
198 If
199 .I \-x
200 is specified, then the scanlines are assumed to be in
201 decreasing order (ie. right to left).
202 The ordering of the
203 .I \-y
204 and
205 .I \+x
206 options determines whether the scanlines are sorted along
207 x or along y.
208 Most Radiance pictures are sorted top to bottom, then left
209 to right.
210 This corresponds to a specification of the form "-y yres +x xres".
211 Either an upper or lower case 'X' may be used for this option.
212 Like the
213 .I \-y
214 option,
215 .I \-x
216 options have no effect for forward conversions.
217 .SH EXAMPLE
218 To look at the original, unique pixels in picture:
219 .IP "" .2i
220 pvalue -o -u picture | more
221 .PP
222 To convert from a 512x400 8-bit greyscale image in bottom to top,
223 left to right scanline ordering:
224 .IP "" .2i
225 pvalue -r -db -b -h +y 400 +x 512 input.im > flipped.pic
226 .br
227 pflip -v flipped.pic > final.pic
228 .SH AUTHOR
229 Greg Ward
230 .SH BUGS
231 The
232 .I \-r
233 option does not work with the
234 .I \-u
235 option.
236 Also, input pixel locations are ignored during a reverse
237 conversion, so this information is not used in determining
238 the scanline ordering or picture size.
239 .SH "SEE ALSO"
240 getinfo(1), pcompos(1), pfilt(1), pflip(1),
241 protate(1), rpict(1), rtrace(1), rvu(1)
