root/radiance/ray/doc/man/man1/pvalue.1
Revision: 1.5
Committed: Fri Oct 1 07:45:30 2004 UTC (20 years, 9 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Changes since 1.4: +5 -2 lines
1 .\" RCSid "$Id: pvalue.1,v 1.4 2004/01/01 19:31:45 greg Exp $"
2 .TH PVALUE 1 1/15/99 RADIANCE
3 .SH NAME
4 pvalue - convert RADIANCE picture to/from alternate formats
5 .SH SYNOPSIS
6 .B pvalue
7 [
8 .B options
9 ]
10 [
11 .B file
12 ]
13 .br
14 .B "pvalue -r"
15 [
16 .B options
17 ]
18 [
19 .B file1
20 [
21 .B "file2 file3"
22 ]
23 ]
24 .SH DESCRIPTION
25 .I Pvalue
26 converts the pixels of a RADIANCE picture to or from another format.
27 In the default mode, pixels are sent to the
28 standard output, one per line, in the following ascii format:
29
30 xpos ypos red green blue
31
32 If no
33 .I file
34 is given, the standard input is read.
35 .PP
36 The reverse conversion option
37 .I (-r)
38 may be used with a single input file or when reading from the
39 standard input, but if the second form is used with three separate
40 input files, the three primaries are presumed to be separated in
41 these files.
42 .TP 10n
43 .BR \-u
44 Print only unique values in the output, skipping runs of equal pixels.
45 Specifying
46 .I \+u
47 turns this option off, which is the default.
48 .TP
49 .BR \-o
50 Print original values, before exposure compensation.
51 If the input file is in XYZE format, the Y (green) channel
52 will correspond to units of candelas/meter^2.
53 Otherwise, the RGB values should be in spectral watts/steradian/meter^2.
54 Specifying
55 .I \+o
56 uses final exposed values, which is the default.
57 .TP
58 .BR \-h
59 Do not print header.
60 Specifying
61 .I \+h
62 causes the header to be printed, which is the default.
63 .TP
64 .BI \-H
65 Do not print the resolution string.
66 (See also the
67 .I \-r
68 option below.)
69 Specifying an input resolution for reverse conversion also turns
70 this option off.
71 Specifying
72 .I \+H
73 causes the resolution string to be printed, which is the default.
74 .TP
75 .BI \-s \ nbytes
76 Skip the specified number of bytes on the input header.
77 This option is useful for skipping unintelligible headers in
78 foreign file formats.
79 (Does not work when reading from standard input.)
80 .TP
81 .BI \-e \ exposure
82 Adjust the exposure by the amount specified.
83 If the exposure is being given as a conversion factor, use
84 .I \+e
85 instead, so an EXPOSURE line will not be recorded in the header
86 (if any).
87 .TP
88 .BI \-g \ gamma
89 Set gamma correction for conversion.
90 When converting from a RADIANCE picture to another format,
91 the inverse gamma is applied to correct for monitor response.
92 When converting to a RADIANCE picture
93 .I (\-r
94 option), the gamma is applied directly to recover the linear values.
95 By default,
96 .I gamma
97 is set to 1.0, meaning no gamma correction is performed.
98 .TP
99 .BR \-d
100 Data only,
101 do not print x and y pixel position.
102 .TP
103 .BR \-da
104 Same as
105 .I \-d.
106 .TP
107 .BR \-di
108 Print ascii integer values from 0 to 255+.
109 If
110 .I \+di
111 is given, the integer values will be preceded by
112 the x and y pixel locations.
113 .TP
114 .BR \-db
115 Output binary byte values from 0 to 255.
116 .TP
117 .BR \-dw
118 Output binary 16-bit words from 0 to 65535.
119 .TP
120 .BR \-dW
121 Output binary 16-bit words from 0 to 65535, byte-swapped.
122 .TP
123 .BR \-df
124 Output binary float values.
125 .TP
126 .BR \-dF
127 Output byte-swapped binary float values.
128 .TP
129 .BR \-dd
130 Output binary double values.
131 .TP
132 .BR \-dD
133 Output byte-swapped binary double values.
134 .TP
135 .BR \-R
136 Reverse ordering of colors so that the output is blue then green
137 then red.
138 The default ordering (specified with
139 .I \+R)
140 is red then green then blue.
141 .TP
142 .BR \-n
143 The RGB values are non-interleaved, meaning that all the red, green
144 and blue data are stored together in separate chunks.
145 Interleaving may be turned on with the
146 .I \+n
147 option, which is the default.
148 .TP
149 .BR \-b
150 Print brightness values rather than RGB.
151 Specifying
152 .I \+b
153 turns this option off, which is the default.
154 .TP
155 .BI \-p P
156 Put out only the primary
157 .I P,
158 where
159 .I P
160 is one of upper or lower case 'R', 'G' or 'B' for red, green or
161 blue, respectively.
162 This option may be used to separate the Radiance primaries into
163 three files with three separate runs of
164 .I pvalue,
165 or only one file when only one primary is needed.
166 Note that there is no space between this option and its argument.
167 .TP
168 .BR \-r
169 Perform reverse conversion.
170 Input is in the format given by the other options.
171 The x and y resolution must be specified on the command line, unless
172 the image file contains a Radiance resolution string at the
173 beginning (see
174 .I \-H
175 option above and
176 .I \-y
177 option below).
178 Specifying
179 .I \+r
180 converts from a Radiance picture to other values, which is the
181 default.
182 .TP
183 .BI -y \ res
184 Set the output y resolution to
185 .I res.
186 If
187 .I \+y
188 is specified, then the scanlines are assumed to be in
189 increasing order (ie. bottom to top).
190 The default value for this option is 0, which means
191 that the picture size and scanline order must appear
192 as the first line after the header (if any) in the
193 input file.
194 Either an upper or lower case 'Y' may be used for this option.
195 Since Radiance files always contain such a line,
196 this option has no effect for forward conversions.
197 .TP
198 .BI +x \ res
199 Set the output x resolution to
200 .I res.
201 If
202 .I \-x
203 is specified, then the scanlines are assumed to be in
204 decreasing order (ie. right to left).
205 The ordering of the
206 .I \-y
207 and
208 .I \+x
209 options determines whether the scanlines are sorted along
210 x or along y.
211 Most Radiance pictures are sorted top to bottom, then left
212 to right.
213 This corresponds to a specification of the form "-y yres +x xres".
214 Either an upper or lower case 'X' may be used for this option.
215 Like the
216 .I \-y
217 option,
218 .I \-x
219 options have no effect for forward conversions.
220 .SH EXAMPLE
221 To look at the original, unique pixels in picture:
222 .IP "" .2i
223 pvalue -o -u picture | more
224 .PP
225 To convert from a 512x400 8-bit greyscale image in bottom to top,
226 left to right scanline ordering:
227 .IP "" .2i
228 pvalue -r -db -b -h +y 400 +x 512 input.im > flipped.pic
229 .br
230 pflip -v flipped.pic > final.pic
231 .SH AUTHOR
232 Greg Ward
233 .SH BUGS
234 The
235 .I \-r
236 option does not work with the
237 .I \-u
238 option.
239 Also, input pixel locations are ignored during a reverse
240 conversion, so this information is not used in determining
241 the scanline ordering or picture size.
242 .SH "SEE ALSO"
243 getinfo(1), pcompos(1), pfilt(1), pflip(1),
244 protate(1), rpict(1), rtrace(1), rvu(1)
