root/radiance/ray/doc/man/man1/pvalue.1
Revision: 1.10
Committed: Mon Jul 15 23:42:44 2019 UTC (6 years ago) by greg
Changes since 1.9: +1 -2 lines
Allow skipping header bytes on standard input and more logical binary mode
1 .\" RCSid "$Id: pvalue.1,v 1.9 2019/07/15 22:39:50 greg Exp $"
2 .TH PVALUE 1 1/15/99 RADIANCE
3 .SH NAME
4 pvalue - convert RADIANCE picture to/from alternate formats
5 .SH SYNOPSIS
6 .B pvalue
7 [
8 .B options
9 ]
10 [
11 .B file
12 ]
13 .br
14 .B "pvalue -r"
15 [
16 .B options
17 ]
18 [
19 .B file1
20 [
21 .B "file2 file3"
22 ]
23 ]
24 .SH DESCRIPTION
25 .I Pvalue
26 converts the pixels of a RADIANCE picture to or from another format.
27 In the default mode, pixels are sent to the
28 standard output, one per line, in the following ascii format:
29
30 xpos ypos red green blue
31
32 If no
33 .I file
34 is given, the standard input is read.
35 .PP
36 The reverse conversion option
37 .I (-r)
38 may be used with a single input file or when reading from the
39 standard input, but if the second form is used with three separate
40 input files, the three primaries are presumed to be separated in
41 these files.
42 .TP 10n
43 .BR \-u
44 Print only unique values in the output, skipping runs of equal pixels.
45 For reverse conversions, the
46 .I \-u
47 option writes uncompressed output rather than the standard run-length RGBE
48 encoding.
49 Specifying
50 .I \+u
51 turns this option off, which is the default.
52 .TP
53 .BR \-o
54 Print original values, before exposure compensation.
55 If the input file is in XYZE format, the Y (green) channel
56 will correspond to units of candelas/meter^2.
57 Otherwise, the RGB values should be in spectral watts/steradian/meter^2.
58 Specifying
59 .I \+o
60 uses final exposed values, which is the default.
61 .TP
62 .BR \-h
63 Do not print header.
64 Specifying
65 .I \+h
66 causes the header to be printed, which is the default.
67 .TP
68 .BI \-H
69 Do not print the resolution string.
70 (See also the
71 .I \-r
72 option below.)
73 Specifying an input resolution for reverse conversion also turns
74 this option off.
75 Specifying
76 .I \+H
77 causes the resolution string to be printed, which is the default.
78 .TP
79 .BI \-s \ nbytes
80 Skip the specified number of bytes on the input header.
81 This option is useful for skipping unintelligible headers in
82 foreign file formats.
83 .TP
84 .BI \-e \ exposure
85 Adjust the exposure by the amount specified.
86 If the exposure is being given as a conversion factor, use
87 .I \+e
88 instead, so an EXPOSURE line will not be recorded in the header
89 (if any).
90 .TP
91 .BI \-g \ gamma
92 Set gamma correction for conversion.
93 When converting from a RADIANCE picture to another format,
94 the inverse gamma is applied to correct for monitor response.
95 When converting to a RADIANCE picture
96 .I (\-r
97 option), the gamma is applied directly to recover the linear values.
98 By default,
99 .I gamma
100 is set to 1.0, meaning no gamma correction is performed.
101 .TP
102 .BR \-d
103 Data only,
104 do not print x and y pixel position.
105 .TP
106 .BR \-da
107 Same as
108 .I \-d.
109 .TP
110 .BR \-di
111 Print ascii integer values from 0 to 255+.
112 If
113 .I \+di
114 is given, the integer values will be preceded by
115 the x and y pixel locations.
116 .TP
117 .BR \-db
118 Output binary byte values from 0 to 255.
119 .TP
120 .BR \-dw
121 Output binary 16-bit words from 0 to 65535.
122 .TP
123 .BR \-dW
124 Output binary 16-bit words from 0 to 65535, byte-swapped.
125 .TP
126 .BR \-df
127 Output binary float values.
128 .TP
129 .BR \-dF
130 Output byte-swapped binary float values.
131 .TP
132 .BR \-dd
133 Output binary double values.
134 .TP
135 .BR \-dD
136 Output byte-swapped binary double values.
137 .TP
138 .BR \-R
139 Reverse ordering of colors so that the output is blue then green
140 then red.
141 The default ordering (specified with
142 .I \+R)
143 is red then green then blue.
144 .TP
145 .BR \-n
146 The RGB values are non-interleaved, meaning that all the red, green
147 and blue data are stored together in separate chunks.
148 Interleaving may be turned on with the
149 .I \+n
150 option, which is the default.
151 .TP
152 .BR \-b
153 Print brightness values rather than RGB.
154 Specifying
155 .I \+b
156 turns this option off, which is the default.
157 .TP
158 .BI \-p P
159 Put out only the primary
160 .I P,
161 where
162 .I P
163 is one of upper or lower case 'R', 'G' or 'B' for red, green or
164 blue, respectively.
165 This option may be used to separate the Radiance primaries into
166 three files with three separate runs of
167 .I pvalue,
168 or only one file when only one primary is needed.
169 Note that there is no space between this option and its argument.
170 .TP
171 .BR \-r
172 Perform reverse conversion.
173 Input is in the format given by the other options.
174 The x and y resolution must be specified on the command line, unless
175 the image file contains a Radiance resolution string at the
176 beginning (see
177 .I \-H
178 option above and
179 .I \-y
180 option below).
181 Specifying
182 .I \+r
183 converts from a Radiance picture to other values, which is the
184 default.
185 .TP
186 .BI \-p " xr yr xg yg xb yb xw yw"
187 On reverse conversion, RGB input uses the given set of color primaries.
188 These are written into the output header with the PRIMARIES variable.
189 .TP
190 .BR \-pXYZ
191 On reverse conversion, input is in CIE XYZ coordinates, rather than RGB.
192 The Y channel is assumed to be in candelas/meter^2.
193 .TP
194 .BI -y \ res
195 Set the output y resolution to
196 .I res.
197 If
198 .I \+y
199 is specified, then the scanlines are assumed to be in
200 increasing order (ie. bottom to top).
201 The default value for this option is 0, which means
202 that the picture size and scanline order must appear
203 as the first line after the header (if any) in the
204 input file.
205 Either an upper or lower case 'Y' may be used for this option.
206 Since Radiance files always contain such a line,
207 this option has no effect for forward conversions.
208 .TP
209 .BI +x \ res
210 Set the output x resolution to
211 .I res.
212 If
213 .I \-x
214 is specified, then the scanlines are assumed to be in
215 decreasing order (ie. right to left).
216 The ordering of the
217 .I \-y
218 and
219 .I \+x
220 options determines whether the scanlines are sorted along
221 x or along y.
222 Most Radiance pictures are sorted top to bottom, then left
223 to right.
224 This corresponds to a specification of the form "\-y yres +x xres".
225 Either an upper or lower case 'X' may be used for this option.
226 Like the
227 .I \-y
228 option,
229 .I \-x
230 options have no effect for forward conversions.
231 .SH EXAMPLE
232 To look at the original, unique pixels in picture:
233 .IP "" .2i
234 pvalue \-o \-u picture | more
235 .PP
236 To convert from a 512x400 8-bit greyscale image in bottom to top,
237 left to right scanline ordering:
238 .IP "" .2i
239 pvalue \-r \-db \-b \-h +y 400 +x 512 input.im > flipped.hdr
240 .br
241 pflip \-v flipped.hdr > final.hdr
242 .SH AUTHOR
243 Greg Ward
244 .SH BUGS
245 The
246 .I \-r
247 option does not work with the
248 .I \-u
249 option.
250 Also, input pixel locations are ignored during a reverse
251 conversion, so this information is not used in determining
252 the scanline ordering or picture size.
253 .SH "SEE ALSO"
254 getinfo(1), pcompos(1), pfilt(1), pflip(1),
255 protate(1), ra_xyze(1), rpict(1), rtrace(1), rvu(1)
