root/radiance/ray/doc/man/man1/pvalue.1
Revision: 1.8
Committed: Thu Dec 16 21:34:41 2010 UTC (14 years, 4 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R2P1
Changes since 1.7: +10 -2 lines
Added recording of other color spaces to pvalue -r conversion
1 .\" RCSid "$Id: pvalue.1,v 1.7 2008/11/10 19:08:17 greg Exp $"
2 .TH PVALUE 1 1/15/99 RADIANCE
3 .SH NAME
4 pvalue - convert RADIANCE picture to/from alternate formats
5 .SH SYNOPSIS
6 .B pvalue
7 [
8 .B options
9 ]
10 [
11 .B file
12 ]
13 .br
14 .B "pvalue -r"
15 [
16 .B options
17 ]
18 [
19 .B file1
20 [
21 .B "file2 file3"
22 ]
23 ]
24 .SH DESCRIPTION
25 .I Pvalue
26 converts the pixels of a RADIANCE picture to or from another format.
27 In the default mode, pixels are sent to the
28 standard output, one per line, in the following ascii format:
29
30 xpos ypos red green blue
31
32 If no
33 .I file
34 is given, the standard input is read.
35 .PP
36 The reverse conversion option
37 .I (-r)
38 may be used with a single input file or when reading from the
39 standard input, but if the second form is used with three separate
40 input files, the three primaries are presumed to be separated in
41 these files.
42 .TP 10n
43 .BR \-u
44 Print only unique values in the output, skipping runs of equal pixels.
45 Specifying
46 .I \+u
47 turns this option off, which is the default.
48 .TP
49 .BR \-o
50 Print original values, before exposure compensation.
51 If the input file is in XYZE format, the Y (green) channel
52 will correspond to units of candelas/meter^2.
53 Otherwise, the RGB values should be in spectral watts/steradian/meter^2.
54 Specifying
55 .I \+o
56 uses final exposed values, which is the default.
57 .TP
58 .BR \-h
59 Do not print header.
60 Specifying
61 .I \+h
62 causes the header to be printed, which is the default.
63 .TP
64 .BI \-H
65 Do not print the resolution string.
66 (See also the
67 .I \-r
68 option below.)
69 Specifying an input resolution for reverse conversion also turns
70 this option off.
71 Specifying
72 .I \+H
73 causes the resolution string to be printed, which is the default.
74 .TP
75 .BI \-s \ nbytes
76 Skip the specified number of bytes on the input header.
77 This option is useful for skipping unintelligible headers in
78 foreign file formats.
79 (Does not work when reading from standard input.)
80 .TP
81 .BI \-e \ exposure
82 Adjust the exposure by the amount specified.
83 If the exposure is being given as a conversion factor, use
84 .I \+e
85 instead, so an EXPOSURE line will not be recorded in the header
86 (if any).
87 .TP
88 .BI \-g \ gamma
89 Set gamma correction for conversion.
90 When converting from a RADIANCE picture to another format,
91 the inverse gamma is applied to correct for monitor response.
92 When converting to a RADIANCE picture
93 .I (\-r
94 option), the gamma is applied directly to recover the linear values.
95 By default,
96 .I gamma
97 is set to 1.0, meaning no gamma correction is performed.
98 .TP
99 .BR \-d
100 Data only,
101 do not print x and y pixel position.
102 .TP
103 .BR \-da
104 Same as
105 .I \-d.
106 .TP
107 .BR \-di
108 Print ascii integer values from 0 to 255+.
109 If
110 .I \+di
111 is given, the integer values will be preceded by
112 the x and y pixel locations.
113 .TP
114 .BR \-db
115 Output binary byte values from 0 to 255.
116 .TP
117 .BR \-dw
118 Output binary 16-bit words from 0 to 65535.
119 .TP
120 .BR \-dW
121 Output binary 16-bit words from 0 to 65535, byte-swapped.
122 .TP
123 .BR \-df
124 Output binary float values.
125 .TP
126 .BR \-dF
127 Output byte-swapped binary float values.
128 .TP
129 .BR \-dd
130 Output binary double values.
131 .TP
132 .BR \-dD
133 Output byte-swapped binary double values.
134 .TP
135 .BR \-R
136 Reverse ordering of colors so that the output is blue then green
137 then red.
138 The default ordering (specified with
139 .I \+R)
140 is red then green then blue.
141 .TP
142 .BR \-n
143 The RGB values are non-interleaved, meaning that all the red, green
144 and blue data are stored together in separate chunks.
145 Interleaving may be turned on with the
146 .I \+n
147 option, which is the default.
148 .TP
149 .BR \-b
150 Print brightness values rather than RGB.
151 Specifying
152 .I \+b
153 turns this option off, which is the default.
154 .TP
155 .BI \-p P
156 Put out only the primary
157 .I P,
158 where
159 .I P
160 is one of upper or lower case 'R', 'G' or 'B' for red, green or
161 blue, respectively.
162 This option may be used to separate the Radiance primaries into
163 three files with three separate runs of
164 .I pvalue,
165 or only one file when only one primary is needed.
166 Note that there is no space between this option and its argument.
167 .TP
168 .BR \-r
169 Perform reverse conversion.
170 Input is in the format given by the other options.
171 The x and y resolution must be specified on the command line, unless
172 the image file contains a Radiance resolution string at the
173 beginning (see
174 .I \-H
175 option above and
176 .I \-y
177 option below).
178 Specifying
179 .I \+r
180 converts from a Radiance picture to other values, which is the
181 default.
182 .TP
183 .BI \-p " xr yr xg yg xb yb xw yw"
184 On reverse conversion, RGB input uses the given set of color primaries.
185 These are written into the output header with the PRIMARIES variable.
186 .TP
187 .BR \-pXYZ
188 On reverse conversion, input is in CIE XYZ coordinates, rather than RGB.
189 The Y channel is assumed to be in candelas/meter^2.
190 .TP
191 .BI -y \ res
192 Set the output y resolution to
193 .I res.
194 If
195 .I \+y
196 is specified, then the scanlines are assumed to be in
197 increasing order (ie. bottom to top).
198 The default value for this option is 0, which means
199 that the picture size and scanline order must appear
200 as the first line after the header (if any) in the
201 input file.
202 Either an upper or lower case 'Y' may be used for this option.
203 Since Radiance files always contain such a line,
204 this option has no effect for forward conversions.
205 .TP
206 .BI +x \ res
207 Set the output x resolution to
208 .I res.
209 If
210 .I \-x
211 is specified, then the scanlines are assumed to be in
212 decreasing order (ie. right to left).
213 The ordering of the
214 .I \-y
215 and
216 .I \+x
217 options determines whether the scanlines are sorted along
218 x or along y.
219 Most Radiance pictures are sorted top to bottom, then left
220 to right.
221 This corresponds to a specification of the form "\-y yres +x xres".
222 Either an upper or lower case 'X' may be used for this option.
223 Like the
224 .I \-y
225 option,
226 .I \-x
227 options have no effect for forward conversions.
228 .SH EXAMPLE
229 To look at the original, unique pixels in picture:
230 .IP "" .2i
231 pvalue \-o \-u picture | more
232 .PP
233 To convert from a 512x400 8-bit greyscale image in bottom to top,
234 left to right scanline ordering:
235 .IP "" .2i
236 pvalue \-r \-db \-b \-h +y 400 +x 512 input.im > flipped.hdr
237 .br
238 pflip \-v flipped.hdr > final.hdr
239 .SH AUTHOR
240 Greg Ward
241 .SH BUGS
242 The
243 .I \-r
244 option does not work with the
245 .I \-u
246 option.
247 Also, input pixel locations are ignored during a reverse
248 conversion, so this information is not used in determining
249 the scanline ordering or picture size.
250 .SH "SEE ALSO"
251 getinfo(1), pcompos(1), pfilt(1), pflip(1),
252 protate(1), ra_xyze(1), rpict(1), rtrace(1), rvu(1)
