root/radiance/ray/doc/man/man1/pvalue.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 2 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH PVALUE 1 1/15/99 RADIANCE
3 .SH NAME
4 pvalue - convert RADIANCE picture to/from alternate formats
5 .SH SYNOPSIS
6 .B pvalue
7 [
8 .B options
9 ]
10 [
11 .B file
12 ]
13 .br
14 .B "pvalue -r"
15 [
16 .B options
17 ]
18 [
19 .B file1
20 [
21 .B "file2 file3"
22 ]
23 ]
24 .SH DESCRIPTION
25 .I Pvalue
26 converts the pixels of a RADIANCE picture to or from another format.
27 In the default mode, pixels are sent to the
28 standard output, one per line, in the following ascii format:
29
30 xpos ypos red green blue
31
32 If no
33 .I file
34 is given, the standard input is read.
35 .PP
36 The reverse conversion option
37 .I (-r)
38 may be used with a single input file or when reading from the
39 standard input, but if the second form is used with three separate
40 input files, the three primaries are presumed to be separated in
41 these files.
42 .TP 10n
43 .BR \-u
44 Print only unique values in the output, skipping runs of equal pixels.
45 Specifying
46 .I \+u
47 turns this option off, which is the default.
48 .TP
49 .BR \-o
50 Print original values, before exposure compensation.
51 Specifying
52 .I \+o
53 uses final values, which is the default.
54 .TP
55 .BR \-h
56 Do not print header.
57 Specifying
58 .I \+h
59 causes the header to be printed, which is the default.
60 .TP
61 .BI \-H
62 Do not print the resolution string.
63 (See also the
64 .I \-r
65 option below.)
66 Specifying an input resolution for reverse conversion also turns
67 this option off.
68 Specifying
69 .I \+H
70 causes the resolution string to be printed, which is the default.
71 .TP
72 .BI \-s \ nbytes
73 Skip the specified number of bytes on the input header.
74 This option is useful for skipping unintelligible headers in
75 foreign file formats.
76 (Does not work when reading from standard input.)
77 .TP
78 .BI \-e \ exposure
79 Adjust the exposure by the amount specified.
80 If the exposure is being given as a conversion factor, use
81 .I \+e
82 instead, so an EXPOSURE line will not be recorded in the header
83 (if any).
84 .TP
85 .BI \-g \ gamma
86 Set gamma correction for conversion.
87 When converting from a RADIANCE picture to another format,
88 the inverse gamma is applied to correct for monitor response.
89 When converting to a RADIANCE picture
90 .I (\-r
91 option), the gamma is applied directly to recover the linear values.
92 By default,
93 .I gamma
94 is set to 1.0, meaning no gamma correction is performed.
95 .TP
96 .BR \-d
97 Data only,
98 do not print x and y pixel position.
99 .TP
100 .BR \-da
101 Same as
102 .I \-d.
103 .TP
104 .BR \-di
105 Print ascii integer values from 0 to 255+.
106 If
107 .I \+di
108 is given, the integer values will be preceded by
109 the x and y pixel locations.
110 .TP
111 .BR \-db
112 Output binary byte values from 0 to 255.
113 .TP
114 .BR \-dw
115 Output binary 16-bit words from 0 to 65535.
116 .TP
117 .BR \-dW
118 Output binary 16-bit words from 0 to 65535, byte-swapped.
119 .TP
120 .BR \-df
121 Output binary float values.
122 .TP
123 .BR \-dd
124 Output binary double values.
125 .TP
126 .BR \-R
127 Reverse ordering of colors so that the output is blue then green
128 then red.
129 The default ordering (specified with
130 .I \+R)
131 is red then green then blue.
132 .TP
133 .BR \-n
134 The RGB values are non-interleaved, meaning that all the red, green
135 and blue data are stored together in separate chunks.
136 Interleaving may be turned on with the
137 .I \+n
138 option, which is the default.
139 .TP
140 .BR \-b
141 Print brightness values rather than RGB.
142 Specifying
143 .I \+b
144 turns this option off, which is the default.
145 .TP
146 .BI \-p P
147 Put out only the primary
148 .I P,
149 where
150 .I P
151 is one of upper or lower case 'R', 'G' or 'B' for red, green or
152 blue, respectively.
153 This option may be used to separate the Radiance primaries into
154 three files with three separate runs of
155 .I pvalue,
156 or only one file when only one primary is needed.
157 Note that there is no space between this option and its argument.
158 .TP
159 .BR \-r
160 Perform reverse conversion.
161 Input is in the format given by the other options.
162 The x and y resolution must be specified on the command line, unless
163 the image file contains a Radiance resolution string at the
164 beginning (see
165 .I \-H
166 option above and
167 .I \-y
168 option below).
169 Specifying
170 .I \+r
171 converts from a Radiance picture to other values, which is the
172 default.
173 .TP
174 .BI -y \ res
175 Set the output y resolution to
176 .I res.
177 If
178 .I \+y
179 is specified, then the scanlines are assumed to be in
180 increasing order (ie. bottom to top).
181 The default value for this option is 0, which means
182 that the picture size and scanline order must appear
183 as the first line after the header (if any) in the
184 input file.
185 Either an upper or lower case 'Y' may be used for this option.
186 Since Radiance files always contain such a line,
187 this option has no effect for forward conversions.
188 .TP
189 .BI +x \ res
190 Set the output x resolution to
191 .I res.
192 If
193 .I \-x
194 is specified, then the scanlines are assumed to be in
195 decreasing order (ie. right to left).
196 The ordering of the
197 .I \-y
198 and
199 .I \+x
200 options determines whether the scanlines are sorted along
201 x or along y.
202 Most Radiance pictures are sorted top to bottom, then left
203 to right.
204 This corresponds to a specification of the form "-y yres +x xres".
205 Either an upper or lower case 'X' may be used for this option.
206 Like the
207 .I \-y
208 option,
209 .I \-x
210 options have no effect for forward conversions.
211 .SH EXAMPLE
212 To look at the original, unique pixels in picture:
213 .IP "" .2i
214 pvalue -o -u picture | more
215 .PP
216 To convert from a 512x400 8-bit greyscale image in bottom to top,
217 left to right scanline ordering:
218 .IP "" .2i
219 pvalue -r -db -b -h +y 400 +x 512 input.im > flipped.pic
220 .br
221 pflip -v flipped.pic > final.pic
222 .SH AUTHOR
223 Greg Ward
224 .SH BUGS
225 The
226 .I \-r
227 option does not work with the
228 .I \-u
229 option.
230 Also, input pixel locations are ignored during a reverse
231 conversion, so this information is not used in determining
232 the scanline ordering or picture size.
233 .SH "SEE ALSO"
234 getinfo(1), pcompos(1), pfilt(1), pflip(1),
235 protate(1), rpict(1), rtrace(1), rview(1)
