root/radiance/ray/doc/man/man1/pvalue.1
Revision: 1.5
Committed: Fri Oct 1 07:45:30 2004 UTC (20 years, 7 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Changes since 1.4: +5 -2 lines
# User Rev Content
1 greg 1.5 .\" RCSid "$Id: pvalue.1,v 1.4 2004/01/01 19:31:45 greg Exp $"
2 greg 1.1 .TH PVALUE 1 1/15/99 RADIANCE
3     .SH NAME
4     pvalue - convert RADIANCE picture to/from alternate formats
5     .SH SYNOPSIS
6     .B pvalue
7     [
8     .B options
9     ]
10     [
11     .B file
12     ]
13     .br
14     .B "pvalue -r"
15     [
16     .B options
17     ]
18     [
19     .B file1
20     [
21     .B "file2 file3"
22     ]
23     ]
24     .SH DESCRIPTION
25     .I Pvalue
26     converts the pixels of a RADIANCE picture to or from another format.
27     In the default mode, pixels are sent to the
28     standard output, one per line, in the following ascii format:
29
30     xpos ypos red green blue
31
32     If no
33     .I file
34     is given, the standard input is read.
35     .PP
36     The reverse conversion option
37     .I (-r)
38     may be used with a single input file or when reading from the
39     standard input, but if the second form is used with three separate
40     input files, the three primaries are presumed to be separated in
41     these files.
42     .TP 10n
43     .BR \-u
44     Print only unique values in the output, skipping runs of equal pixels.
45     Specifying
46     .I \+u
47     turns this option off, which is the default.
48     .TP
49     .BR \-o
50     Print original values, before exposure compensation.
51 greg 1.5 If the input file is in XYZE format, the Y (green) channel
52     will correspond to units of candelas/meter^2.
53     Otherwise, the RGB values should be in spectral watts/steradian/meter^2.
54 greg 1.1 Specifying
55     .I \+o
56 greg 1.5 uses final exposed values, which is the default.
57 greg 1.1 .TP
58     .BR \-h
59     Do not print header.
60     Specifying
61     .I \+h
62     causes the header to be printed, which is the default.
63     .TP
64     .BI \-H
65     Do not print the resolution string.
66     (See also the
67     .I \-r
68     option below.)
69     Specifying an input resolution for reverse conversion also turns
70     this option off.
71     Specifying
72     .I \+H
73     causes the resolution string to be printed, which is the default.
74     .TP
75     .BI \-s \ nbytes
76     Skip the specified number of bytes on the input header.
77     This option is useful for skipping unintelligible headers in
78     foreign file formats.
79     (Does not work when reading from standard input.)
80     .TP
81     .BI \-e \ exposure
82     Adjust the exposure by the amount specified.
83     If the exposure is being given as a conversion factor, use
84     .I \+e
85     instead, so an EXPOSURE line will not be recorded in the header
86     (if any).
87     .TP
88     .BI \-g \ gamma
89     Set gamma correction for conversion.
90     When converting from a RADIANCE picture to another format,
91     the inverse gamma is applied to correct for monitor response.
92     When converting to a RADIANCE picture
93     .I (\-r
94     option), the gamma is applied directly to recover the linear values.
95     By default,
96     .I gamma
97     is set to 1.0, meaning no gamma correction is performed.
98     .TP
99     .BR \-d
100     Data only,
101     do not print x and y pixel position.
102     .TP
103     .BR \-da
104     Same as
105     .I \-d.
106     .TP
107     .BR \-di
108     Print ascii integer values from 0 to 255+.
109     If
110     .I \+di
111     is given, the integer values will be preceded by
112     the x and y pixel locations.
113     .TP
114     .BR \-db
115     Output binary byte values from 0 to 255.
116     .TP
117     .BR \-dw
118     Output binary 16-bit words from 0 to 65535.
119     .TP
120     .BR \-dW
121     Output binary 16-bit words from 0 to 65535, byte-swapped.
122     .TP
123     .BR \-df
124     Output binary float values.
125     .TP
126 greg 1.2 .BR \-dF
127     Output byte-swapped binary float values.
128     .TP
129 greg 1.1 .BR \-dd
130     Output binary double values.
131 greg 1.2 .TP
132     .BR \-dD
133     Output byte-swapped binary double values.
134 greg 1.1 .TP
135     .BR \-R
136     Reverse ordering of colors so that the output is blue then green
137     then red.
138     The default ordering (specified with
139     .I \+R)
140     is red then green then blue.
141     .TP
142     .BR \-n
143     The RGB values are non-interleaved, meaning that all the red, green
144     and blue data are stored together in separate chunks.
145     Interleaving may be turned on with the
146     .I \+n
147     option, which is the default.
148     .TP
149     .BR \-b
150     Print brightness values rather than RGB.
151     Specifying
152     .I \+b
153     turns this option off, which is the default.
154     .TP
155     .BI \-p P
156     Put out only the primary
157     .I P,
158     where
159     .I P
160     is one of upper or lower case 'R', 'G' or 'B' for red, green or
161     blue, respectively.
162     This option may be used to separate the Radiance primaries into
163     three files with three separate runs of
164     .I pvalue,
165     or only one file when only one primary is needed.
166     Note that there is no space between this option and its argument.
167     .TP
168     .BR \-r
169     Perform reverse conversion.
170     Input is in the format given by the other options.
171     The x and y resolution must be specified on the command line, unless
172     the image file contains a Radiance resolution string at the
173     beginning (see
174     .I \-H
175     option above and
176     .I \-y
177     option below).
178     Specifying
179     .I \+r
180     converts from a Radiance picture to other values, which is the
181     default.
182     .TP
183     .BI -y \ res
184     Set the output y resolution to
185     .I res.
186     If
187     .I \+y
188     is specified, then the scanlines are assumed to be in
189     increasing order (ie. bottom to top).
190     The default value for this option is 0, which means
191     that the picture size and scanline order must appear
192     as the first line after the header (if any) in the
193     input file.
194     Either an upper or lower case 'Y' may be used for this option.
195     Since Radiance files always contain such a line,
196     this option has no effect for forward conversions.
197     .TP
198     .BI +x \ res
199     Set the output x resolution to
200     .I res.
201     If
202     .I \-x
203     is specified, then the scanlines are assumed to be in
204     decreasing order (ie. right to left).
205     The ordering of the
206     .I \-y
207     and
208     .I \+x
209     options determines whether the scanlines are sorted along
210     x or along y.
211     Most Radiance pictures are sorted top to bottom, then left
212     to right.
213     This corresponds to a specification of the form "-y yres +x xres".
214     Either an upper or lower case 'X' may be used for this option.
215     Like the
216     .I \-y
217     option,
218     .I \-x
219     options have no effect for forward conversions.
220     .SH EXAMPLE
221     To look at the original, unique pixels in picture:
222     .IP "" .2i
223     pvalue -o -u picture | more
224     .PP
225     To convert from a 512x400 8-bit greyscale image in bottom to top,
226     left to right scanline ordering:
227     .IP "" .2i
228     pvalue -r -db -b -h +y 400 +x 512 input.im > flipped.pic
229     .br
230     pflip -v flipped.pic > final.pic
231     .SH AUTHOR
232     Greg Ward
233     .SH BUGS
234     The
235     .I \-r
236     option does not work with the
237     .I \-u
238     option.
239     Also, input pixel locations are ignored during a reverse
240     conversion, so this information is not used in determining
241     the scanline ordering or picture size.
242     .SH "SEE ALSO"
243     getinfo(1), pcompos(1), pfilt(1), pflip(1),
244 greg 1.4 protate(1), rpict(1), rtrace(1), rvu(1)
