root/Development/ray/doc/man/man1/psort.1
Revision: 1.4
Committed: Tue Sep 4 17:36:40 2007 UTC (18 years, 4 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: psort.1,v 1.3 2005/02/16 05:40:06 greg Exp $"
2 greg 1.1 .TH PSORT 1 6/24/98 RADIANCE
3     .SH NAME
4     psort - sort primitives in metafile as requested
5     .SH SYNOPSIS
6     .B psort
7     [
8     .B +/\-x
9     ][
10     .B +/\-y
11     ][
12     .B +/\-X
13     ][
14     .B +/\-Y
15     ]
16     file ..
17     .SH DESCRIPTION
18     .I Psort
19     reads each metafile
20     .I file
21     in sequence and sorts primitives between globals according to
22     the option specification.
23     Lower case options mean the corresponding minimum, upper case
24     indicates the maximum value.
25     A '+' before the option means sort in order of increasing
26     values, '-' means decreasing.
27     The order the options appear on the command line is the order
28     in which the extrema are examined.
29     For example, the options
30     .I \-Y +x
31     would mean "sort on decreasing ymax, then increasing xmin values".
32     .PP
33     If no input files are specified, the standard input is read.
34     .SH EXAMPLE
35     To sort the file "meta" in order of increasing xmax, then
36     decreasing ymin:
37     .IP "" .2i
38 greg 1.4 psort +X \-y meta
39 greg 1.1 .SH FILES
40 greg 1.3 /tmp/psXXXXa /tmp/psXXXXb
41 greg 1.1 .SH BUGS
42 greg 1.3 Aborting the program will sometimes leave files in /tmp.
43 greg 1.1 .SH AUTHOR
44     Greg Ward
45     .SH "SEE ALSO"
46     metafile(5), pexpand(1)
