root/radiance/ray/doc/man/man1/psort.1
Revision: 1.3
Committed: Wed Feb 16 05:40:06 2005 UTC (19 years, 4 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R8
1 .\" RCSid "$Id: psort.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH PSORT 1 6/24/98 RADIANCE
3 .SH NAME
4 psort - sort primitives in metafile as requested
5 .SH SYNOPSIS
6 .B psort
7 [
8 .B +/\-x
9 ][
10 .B +/\-y
11 ][
12 .B +/\-X
13 ][
14 .B +/\-Y
15 ]
16 file ..
17 .SH DESCRIPTION
18 .I Psort
19 reads each metafile
20 .I file
21 in sequence and sorts primitives between globals according to
22 the option specification.
23 Lower case options mean the corresponding minimum, upper case
24 indicates the maximum value.
25 A '+' before the option means sort in order of increasing
26 values, '-' means decreasing.
27 The order the options appear on the command line is the order
28 in which the extrema are examined.
29 For example, the options
30 .I \-Y +x
31 would mean "sort on decreasing ymax, then increasing xmin values".
32 .PP
33 If no input files are specified, the standard input is read.
34 .SH EXAMPLE
35 To sort the file "meta" in order of increasing xmax, then
36 decreasing ymin:
37 .IP "" .2i
38 psort +X -y meta
39 .SH FILES
40 /tmp/psXXXXa /tmp/psXXXXb
41 .SH BUGS
42 Aborting the program will sometimes leave files in /tmp.
43 .SH AUTHOR
44 Greg Ward
45 .SH "SEE ALSO"
46 metafile(5), pexpand(1)
