| 1 |
.\" RCSid "$Id$"
| 2 |
.TH PSIGN 1 10/9/97 RADIANCE
| 3 |
.SH NAME
| 4 |
psign - produce a RADIANCE picture from text.
| 5 |
.SH SYNOPSIS
| 6 |
.B psign
| 7 |
| 8 |
.B options
| 9 |
| 10 |
| 11 |
.B text
| 12 |
| 13 |
.SH DESCRIPTION
| 14 |
.I Psign
| 15 |
produces a RADIANCE picture of the given
| 16 |
.I text.
| 17 |
The output dimensions are determined by the character height, aspect
| 18 |
ratio, number of lines and line length.
| 19 |
(Also the character size if text squeezing is used.)\0
| 20 |
If no
| 21 |
.I text
| 22 |
is given, the standard input is read.
| 23 |
.TP 10n
| 24 |
.BI -cb " r g b"
| 25 |
Set the background color to
| 26 |
.I "r g b"
| 27 |
The default is white (1 1 1).
| 28 |
.TP
| 29 |
.BI -cf " r g b"
| 30 |
Set the foreground color to
| 31 |
.I "r g b"
| 32 |
The default is black (0 0 0).
| 33 |
.TP
| 34 |
.BR \-dr
| 35 |
Text reads to the right (default).
| 36 |
.TP
| 37 |
.BR \-du
| 38 |
Text reads upwards.
| 39 |
.TP
| 40 |
.BR \-dl
| 41 |
Text reads to the left (upside down).
| 42 |
.TP
| 43 |
.BR \-dd
| 44 |
Text reads downwards.
| 45 |
.TP
| 46 |
.BI -h \ cheight
| 47 |
Set the character height to
| 48 |
.I cheight.
| 49 |
The default is 32 pixels.
| 50 |
.TP
| 51 |
.BI -a \ aspect
| 52 |
Set the character aspect ratio (height/width) to
| 53 |
.I aspect.
| 54 |
The default value is 1.67.
| 55 |
.TP
| 56 |
.BI -x \ xsize
| 57 |
Set the horizontal image size to
| 58 |
.I xsize.
| 59 |
Use with
| 60 |
.I \-y
| 61 |
option (below) in place of the
| 62 |
.I \-h
| 63 |
specification to control output image size directly.
| 64 |
If the character aspect ratio
| 65 |
.I (\-a
| 66 |
option, above) is non-zero, then one of the specified x or y output
| 67 |
dimensions may be reduced to maintain this ratio.
| 68 |
If direction is right
| 69 |
.I (\-dr)
| 70 |
or left
| 71 |
.I (\-dl),
| 72 |
then it is not necessary to give the
| 73 |
.I \-y
| 74 |
option, since it can be computed from the character height
| 75 |
.I (\-h).
| 76 |
.TP
| 77 |
.BI -y \ ysize
| 78 |
Set the vertical image size to
| 79 |
.I ysize.
| 80 |
Use with the
| 81 |
.I \-x
| 82 |
option (described above).
| 83 |
If direction is up
| 84 |
.I (\-du)
| 85 |
or down
| 86 |
.I (\-dd),
| 87 |
| 88 |
.I \-x
| 89 |
| 90 |
.I (\-h).
| 91 |
.TP
| 92 |
.BI -s \ spacing
| 93 |
Set the intercharacter spacing to
| 94 |
.I spacing.
| 95 |
The magnitude of this value is multiplied by the character height over
| 96 |
the aspect ratio (ie. the character width) to compute the desired
| 97 |
distance between characters in the output.
| 98 |
The sign of the value, positive or negative, determines how this
| 99 |
ideal spacing is used in the actual placement of characters.
| 100 |
If
| 101 |
.I spacing
| 102 |
is positive, then the overall width of the line will not be affected,
| 103 |
nor will indentation of textual elements.
| 104 |
Thus, the text format will be mostly unaffected.
| 105 |
However, spacing between characters will reflect their relative size
| 106 |
for a more natural appearance.
| 107 |
If
| 108 |
.I spacing
| 109 |
is negative, characters will be squeezed together to meet the
| 110 |
spacing critereon, regardless of how it might affect the format of
| 111 |
the output.
| 112 |
The default value for
| 113 |
.I spacing
| 114 |
is zero, which is interpreted as uniformly spaced characters.
| 115 |
.TP
| 116 |
.BI -f \ fontfile
| 117 |
Load the font from
| 118 |
.I fontfile.
| 119 |
The default font is helvet.fnt
| 120 |
.SH EXAMPLE
| 121 |
To put a big "Hi!" on the terminal:
| 122 |
.IP "" .2i
| 123 |
psign -h 22 -a 1 -cb 0 0 0 -cf 1 1 1 Hi\\! | ttyimage
| 124 |
.SH ENVIRONMENT
| 125 |
RAYPATH path to search for font files
| 126 |
.SH AUTHOR
| 127 |
Greg Ward
| 128 |
.SH BUGS
| 129 |
The entire bitmap is stored in memory, which can be a problem for
| 130 |
large and/or high-resolution signs.
| 131 |
.SH "SEE ALSO"
| 132 |
getinfo(1), pcompos(1), pfilt(1), ttyimage(1)
