root/radiance/ray/doc/man/man1/psign.1
Revision: 1.2
Committed: Tue Dec 9 15:59:06 2003 UTC (21 years, 4 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH PSIGN 1 10/9/97 RADIANCE
3 .SH NAME
4 psign - produce a RADIANCE picture from text.
5 .SH SYNOPSIS
6 .B psign
7 [
8 .B options
9 ]
10 [
11 .B text
12 ]
13 .SH DESCRIPTION
14 .I Psign
15 produces a RADIANCE picture of the given
16 .I text.
17 The output dimensions are determined by the character height, aspect
18 ratio, number of lines and line length.
19 (Also the character size if text squeezing is used.)\0
20 If no
21 .I text
22 is given, the standard input is read.
23 .TP 10n
24 .BI -cb " r g b"
25 Set the background color to
26 .I "r g b"
27 The default is white (1 1 1).
28 .TP
29 .BI -cf " r g b"
30 Set the foreground color to
31 .I "r g b"
32 The default is black (0 0 0).
33 .TP
34 .BR \-dr
35 Text reads to the right (default).
36 .TP
37 .BR \-du
38 Text reads upwards.
39 .TP
40 .BR \-dl
41 Text reads to the left (upside down).
42 .TP
43 .BR \-dd
44 Text reads downwards.
45 .TP
46 .BI -h \ cheight
47 Set the character height to
48 .I cheight.
49 The default is 32 pixels.
50 .TP
51 .BI -a \ aspect
52 Set the character aspect ratio (height/width) to
53 .I aspect.
54 The default value is 1.67.
55 .TP
56 .BI -x \ xsize
57 Set the horizontal image size to
58 .I xsize.
59 Use with
60 .I \-y
61 option (below) in place of the
62 .I \-h
63 specification to control output image size directly.
64 If the character aspect ratio
65 .I (\-a
66 option, above) is non-zero, then one of the specified x or y output
67 dimensions may be reduced to maintain this ratio.
68 If direction is right
69 .I (\-dr)
70 or left
71 .I (\-dl),
72 then it is not necessary to give the
73 .I \-y
74 option, since it can be computed from the character height
75 .I (\-h).
76 .TP
77 .BI -y \ ysize
78 Set the vertical image size to
79 .I ysize.
80 Use with the
81 .I \-x
82 option (described above).
83 If direction is up
84 .I (\-du)
85 or down
86 .I (\-dd),
87 then it is not necessary to give the
88 .I \-x
89 option, since it can be computed from the character height
90 .I (\-h).
91 .TP
92 .BI -s \ spacing
93 Set the intercharacter spacing to
94 .I spacing.
95 The magnitude of this value is multiplied by the character height over
96 the aspect ratio (ie. the character width) to compute the desired
97 distance between characters in the output.
98 The sign of the value, positive or negative, determines how this
99 ideal spacing is used in the actual placement of characters.
100 If
101 .I spacing
102 is positive, then the overall width of the line will not be affected,
103 nor will indentation of textual elements.
104 Thus, the text format will be mostly unaffected.
105 However, spacing between characters will reflect their relative size
106 for a more natural appearance.
107 If
108 .I spacing
109 is negative, characters will be squeezed together to meet the
110 spacing critereon, regardless of how it might affect the format of
111 the output.
112 The default value for
113 .I spacing
114 is zero, which is interpreted as uniformly spaced characters.
115 .TP
116 .BI -f \ fontfile
117 Load the font from
118 .I fontfile.
119 The default font is helvet.fnt
120 .SH EXAMPLE
121 To put a big "Hi!" on the terminal:
122 .IP "" .2i
123 psign -h 22 -a 1 -cb 0 0 0 -cf 1 1 1 Hi\\! | ttyimage
124 .SH ENVIRONMENT
125 RAYPATH path to search for font files
126 .SH AUTHOR
127 Greg Ward
128 .SH BUGS
129 The entire bitmap is stored in memory, which can be a problem for
130 large and/or high-resolution signs.
131 .SH "SEE ALSO"
132 getinfo(1), pcompos(1), pfilt(1), ttyimage(1)
