root/radiance/ray/doc/man/man1/psign.1
Revision: 1.3
Committed: Tue Sep 4 17:36:40 2007 UTC (17 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1, rad5R3, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: psign.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH PSIGN 1 10/9/97 RADIANCE
3     .SH NAME
4     psign - produce a RADIANCE picture from text.
5     .SH SYNOPSIS
6     .B psign
7     [
8     .B options
9     ]
10     [
11     .B text
12     ]
13     .SH DESCRIPTION
14     .I Psign
15     produces a RADIANCE picture of the given
16     .I text.
17     The output dimensions are determined by the character height, aspect
18     ratio, number of lines and line length.
19     (Also the character size if text squeezing is used.)\0
20     If no
21     .I text
22     is given, the standard input is read.
23     .TP 10n
24     .BI -cb " r g b"
25     Set the background color to
26     .I "r g b"
27     The default is white (1 1 1).
28     .TP
29     .BI -cf " r g b"
30     Set the foreground color to
31     .I "r g b"
32     The default is black (0 0 0).
33     .TP
34     .BR \-dr
35     Text reads to the right (default).
36     .TP
37     .BR \-du
38     Text reads upwards.
39     .TP
40     .BR \-dl
41     Text reads to the left (upside down).
42     .TP
43     .BR \-dd
44     Text reads downwards.
45     .TP
46     .BI -h \ cheight
47     Set the character height to
48     .I cheight.
49     The default is 32 pixels.
50     .TP
51     .BI -a \ aspect
52     Set the character aspect ratio (height/width) to
53     .I aspect.
54     The default value is 1.67.
55     .TP
56     .BI -x \ xsize
57     Set the horizontal image size to
58     .I xsize.
59     Use with
60     .I \-y
61     option (below) in place of the
62     .I \-h
63     specification to control output image size directly.
64     If the character aspect ratio
65     .I (\-a
66     option, above) is non-zero, then one of the specified x or y output
67     dimensions may be reduced to maintain this ratio.
68     If direction is right
69     .I (\-dr)
70     or left
71     .I (\-dl),
72     then it is not necessary to give the
73     .I \-y
74     option, since it can be computed from the character height
75     .I (\-h).
76     .TP
77     .BI -y \ ysize
78     Set the vertical image size to
79     .I ysize.
80     Use with the
81     .I \-x
82     option (described above).
83     If direction is up
84     .I (\-du)
85     or down
86     .I (\-dd),
87     then it is not necessary to give the
88     .I \-x
89     option, since it can be computed from the character height
90     .I (\-h).
91     .TP
92     .BI -s \ spacing
93     Set the intercharacter spacing to
94     .I spacing.
95     The magnitude of this value is multiplied by the character height over
96     the aspect ratio (ie. the character width) to compute the desired
97     distance between characters in the output.
98     The sign of the value, positive or negative, determines how this
99     ideal spacing is used in the actual placement of characters.
100     If
101     .I spacing
102     is positive, then the overall width of the line will not be affected,
103     nor will indentation of textual elements.
104     Thus, the text format will be mostly unaffected.
105     However, spacing between characters will reflect their relative size
106     for a more natural appearance.
107     If
108     .I spacing
109     is negative, characters will be squeezed together to meet the
110     spacing critereon, regardless of how it might affect the format of
111     the output.
112     The default value for
113     .I spacing
114     is zero, which is interpreted as uniformly spaced characters.
115     .TP
116     .BI -f \ fontfile
117     Load the font from
118     .I fontfile.
119     The default font is helvet.fnt
120     .SH EXAMPLE
121     To put a big "Hi!" on the terminal:
122     .IP "" .2i
123 greg 1.3 psign \-h 22 \-a 1 \-cb 0 0 0 \-cf 1 1 1 Hi\\! | ttyimage
124 greg 1.1 .SH ENVIRONMENT
125     RAYPATH path to search for font files
126     .SH AUTHOR
127     Greg Ward
128     .SH BUGS
129     The entire bitmap is stored in memory, which can be a problem for
130     large and/or high-resolution signs.
131     .SH "SEE ALSO"
132     getinfo(1), pcompos(1), pfilt(1), ttyimage(1)
