root/radiance/ray/doc/man/man1/protate.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 3 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH PROTATE 1 10/27/98 RADIANCE
3 .SH NAME
4 protate - rotate a RADIANCE picture.
5 .SH SYNOPSIS
6 .B protate
7 [
8 .B \-c
9 ][
10 .B \-r
11 ]
12 .B input
13 [
14 .B output
15 ]
16 .SH DESCRIPTION
17 .I Protate
18 rotates a RADIANCE picture 90 degrees.
19 This is useful for output on hardcopy devices with aspect ratios opposite
20 to the input picture.
21 By default, the image is rotated clockwise.
22 The
23 .I \-r
24 option may be used to rotate the image counter-clockwise instead.
25 .PP
26 The
27 .I \-c
28 option indicates that the action is to correct an improper original
29 image orientation, thus the recorded scanline ordering should not
30 be changed.
31 .SH NOTES
32 To rotate an image 180 degrees, use
33 .I pflip(1)
34 with both the
35 .I -h
36 and
37 .I -v
38 options.
39 .SH AUTHOR
40 Greg Ward
41 .SH "SEE ALSO"
42 getinfo(1), pcompos(1), pfilt(1), pflip(1), psign(1), rpict(1)
