root/radiance/ray/doc/man/man1/pmdblur.1
Revision: 1.3
Committed: Tue Sep 4 17:36:40 2007 UTC (16 years, 9 months ago) by greg
Changes since 1.2: +4 -3 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: pmdblur.1,v 1.2 2005/01/18 20:19:56 greg Exp $"
2     .TH PMDBLUR 1 1/17/05 RADIANCE
3     .SH NAME
4 greg 1.1 pmdblur - generate views for combined camera motion and depth blurring
5     .SH SYNOPSIS
6     .B pmdblur
7     .B speed
8     .B aperture
9     .B nsamp
10     .B v0file
11     .B v1file
12     .SH DESCRIPTION
13     .I Pmdblur
14     takes two viewfiles and generates
15     .I nsamp
16     views starting from
17     .I v0file
18     and moving towards
19     .I v1file,
20     simulating an aperture of diameter
21     .I aperture
22     in world coordinate units.
23     When rendered and averaged together, these views will result in
24     a picture with motion and depth-of-field
25     blur due to a camera changing from v0 to v1
26     in a relative time unit of 1, whose shutter is open starting at v0 for
27     .I speed
28     of these time units.
29     Either
30     .I pinterp(1)
31     or
32     .I rpict(1)
33     may be called to do the actual work.
34     (The given
35     .I v0file
36     must also be passed on the command line to the chosen renderer, since
37     .I pmdblur
38     provides supplemental view specifications only.)\0
39     .PP
40     For
41     .I pinterp,
42     feed the output of
43     .I pmdblur
44     to the standard input of
45     .I pinterp
46     and apply the
47     .I \-B
48     option to blur views together.
49     In most cases, two pictures with z-buffers at v0 and v1 will
50     get a satisfactory result, though the perfectionist may wish to
51     apply the
52     .I \-ff
53     option together with the
54     .I \-fr
55     option of
56     .I pinterp.
57     .PP
58     To use
59     .I pmdblur
60     with
61     .I rpict,
62     apply the
63     .I \-S
64     option to indicate a rendering sequence, and set the
65     .I \-o
66     option with a formatted file name to save multiple output
67     pictures.
68     When all the renderings are finished, combine them with the
69     .I pcomb(1)
70     program, using appropriate scalefactors to achieve an average.
71     Note that using
72     .I rpict
73     is MUCH more expensive than using
74     .I pinterp,
75     and it is only recommended if the scene and application
76     absolutely demand it (e.g. there is prominent refraction that
77     must be modeled accurately).
78     .PP
79     For both
80     .I pinterp
81     and
82     .I rpict,
83     the computation time will be proportional to the number of views from
84     .I pmdblur.
85     We have found a
86     .I nsamp
87     setting somewhere between 7 and 15 to be adequate for most images.
88     Relatively larger values are appropriate for faster camera motion.
89     .PP
90     The
91     .I \-pm
92     and/or
93     .I \-pd
94     options of
95     .I rpict
96     may be used instead or in combination to blur animated frames, with
97     the added advantage of blurring reflections and refractions according
98     to their proper motion.
99     However, this option will result in more noise and expense than using
100     .I pmdblur
101     with
102     .I pinterp
103     as a post-process.
104     If both blurring methods are used, a smaller value should be given to the
105     .I rpict
106     .I \-pm
107     option equal to the shutter speed divided by the number of samples, and the
108     .I \-pd
109     option equal to the aperture divided by the number of samples.
110     This will be just enough to blur the boundaries of the ghosts
111     which may appear using
112     .I pmdblur
113     with a small number of time samples.
114 greg 1.2 .PP
115     To simulate a particular camera's aperture, divide the focal length of
116     the lens by the f-number, then convert to the corresponding
117     world coordinate units.
118     For example, if you wish to simulate a 50mm lens at f/2.0 in
119     a scene modeled in meters, then you divide 50mm by 2.0 to get 25mm,
120     which corresponds to an effective aperture of 0.025 meters.
121 greg 1.1 .SH EXAMPLES
122     To use
123     .I pinterp
124     to simulate motion blur between two frames of a walk-through
125     animation, where the camera shutter is open for 1/4 of the
126     interframe distance with an aperture of 0.1 world units:
127     .IP "" .2i
128 greg 1.3 pmdblur .25 .1 8 fr1023.pic fr1024.pic | pinterp \-B \-vf fr1023.pic \-x 640 \-y 480
129 greg 1.1 fr1023.pic fr1023.zbf fr1024.pic fr1024.zbf > fr1023b.pic
130     .SH AUTHOR
131     Greg Ward
132     .SH "SEE ALSO"
133     pcomb(1), pdfblur(1), pinterp(1), pmblur(1), rcalc(1), rpict(1), vwright(1)
