root/radiance/ray/doc/man/man1/pmdblur.1
Revision: 1.2
Committed: Tue Jan 18 20:19:56 2005 UTC (19 years, 5 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R8
Changes since 1.1: +8 -1 lines
Added example aperture calculation
1 .\" RCSid "$Id: pmdblur.1,v 1.1 2005/01/18 03:59:40 greg Exp $"
2 .TH PMDBLUR 1 1/17/05 NAME
3 pmdblur - generate views for combined camera motion and depth blurring
4 .SH SYNOPSIS
5 .B pmdblur
6 .B speed
7 .B aperture
8 .B nsamp
9 .B v0file
10 .B v1file
11 .SH DESCRIPTION
12 .I Pmdblur
13 takes two viewfiles and generates
14 .I nsamp
15 views starting from
16 .I v0file
17 and moving towards
18 .I v1file,
19 simulating an aperture of diameter
20 .I aperture
21 in world coordinate units.
22 When rendered and averaged together, these views will result in
23 a picture with motion and depth-of-field
24 blur due to a camera changing from v0 to v1
25 in a relative time unit of 1, whose shutter is open starting at v0 for
26 .I speed
27 of these time units.
28 Either
29 .I pinterp(1)
30 or
31 .I rpict(1)
32 may be called to do the actual work.
33 (The given
34 .I v0file
35 must also be passed on the command line to the chosen renderer, since
36 .I pmdblur
37 provides supplemental view specifications only.)\0
38 .PP
39 For
40 .I pinterp,
41 feed the output of
42 .I pmdblur
43 to the standard input of
44 .I pinterp
45 and apply the
46 .I \-B
47 option to blur views together.
48 In most cases, two pictures with z-buffers at v0 and v1 will
49 get a satisfactory result, though the perfectionist may wish to
50 apply the
51 .I \-ff
52 option together with the
53 .I \-fr
54 option of
55 .I pinterp.
56 .PP
57 To use
58 .I pmdblur
59 with
60 .I rpict,
61 apply the
62 .I \-S
63 option to indicate a rendering sequence, and set the
64 .I \-o
65 option with a formatted file name to save multiple output
66 pictures.
67 When all the renderings are finished, combine them with the
68 .I pcomb(1)
69 program, using appropriate scalefactors to achieve an average.
70 Note that using
71 .I rpict
72 is MUCH more expensive than using
73 .I pinterp,
74 and it is only recommended if the scene and application
75 absolutely demand it (e.g. there is prominent refraction that
76 must be modeled accurately).
77 .PP
78 For both
79 .I pinterp
80 and
81 .I rpict,
82 the computation time will be proportional to the number of views from
83 .I pmdblur.
84 We have found a
85 .I nsamp
86 setting somewhere between 7 and 15 to be adequate for most images.
87 Relatively larger values are appropriate for faster camera motion.
88 .PP
89 The
90 .I \-pm
91 and/or
92 .I \-pd
93 options of
94 .I rpict
95 may be used instead or in combination to blur animated frames, with
96 the added advantage of blurring reflections and refractions according
97 to their proper motion.
98 However, this option will result in more noise and expense than using
99 .I pmdblur
100 with
101 .I pinterp
102 as a post-process.
103 If both blurring methods are used, a smaller value should be given to the
104 .I rpict
105 .I \-pm
106 option equal to the shutter speed divided by the number of samples, and the
107 .I \-pd
108 option equal to the aperture divided by the number of samples.
109 This will be just enough to blur the boundaries of the ghosts
110 which may appear using
111 .I pmdblur
112 with a small number of time samples.
113 .PP
114 To simulate a particular camera's aperture, divide the focal length of
115 the lens by the f-number, then convert to the corresponding
116 world coordinate units.
117 For example, if you wish to simulate a 50mm lens at f/2.0 in
118 a scene modeled in meters, then you divide 50mm by 2.0 to get 25mm,
119 which corresponds to an effective aperture of 0.025 meters.
120 .SH EXAMPLES
121 To use
122 .I pinterp
123 to simulate motion blur between two frames of a walk-through
124 animation, where the camera shutter is open for 1/4 of the
125 interframe distance with an aperture of 0.1 world units:
126 .IP "" .2i
127 pmdblur .25 .1 8 fr1023.pic fr1024.pic | pinterp -B -vf fr1023.pic -x 640 -y 480
128 fr1023.pic fr1023.zbf fr1024.pic fr1024.zbf > fr1023b.pic
129 .SH AUTHOR
130 Greg Ward
131 .SH "SEE ALSO"
132 pcomb(1), pdfblur(1), pinterp(1), pmblur(1), rcalc(1), rpict(1), vwright(1)
