root/Development/ray/doc/man/man1/pmblur2.1
Revision: 1.3
Committed: Thu Nov 7 23:20:28 2019 UTC (6 years, 1 month ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, HEAD
Changes since 1.2: +3 -2 lines
1 .\" RCSid "$Id: pmblur2.1,v 1.2 2012/10/05 02:07:10 greg Exp $"
2 .TH PMBLUR2 1 10/4/2012 RADIANCE
3 .SH NAME
4 pmblur2 - apply motion blur to a frame from an animation
5 .SH SYNOPSIS
6 .B pmblur2
7 .B f0,f1/n
8 .B HDRspec
9 .B ZBFspec
10 .B MVOspec
11 .SH DESCRIPTION
12 .I Pmblur2
13 Computes a square-shutter blur from frame position
14 .I f0
15 to frame position
16 .I f1
17 using the given picture, depth buffer, and motion vector offset files
18 produced by
19 .I ranimove(1).
20 These arguments should be set similarly to the
21 .I BASENAME,
22 .I ZNAME,
23 and
24 .I MNAME
25 variables in the
26 .I ranimove
27 input file, but should include the suffixes as well.
28 .PP
29 The starting and ending frame number are usually given as floating-point
30 values.
31 For example, the range "10.75,11.25" would simulate a 180-degree shutter
32 around frame 11.
33 An optional time slice count may be given to override the one that is
34 computed by default.
35 The range "5,15/30" would blur all the frames from 5 to 15 continuously
36 using 30 time slices.
37 The blurred image is always sent to stdout.
38 .SH EXAMPLES
39 To blur and downsample frame 95 with a 360-degree shutter:
40 .IP "" .2i
41 pmblur2 94.5,95.5 frame%03d.hdr frame%03d.zbf frame%03d.mvo | pfilt -1 -x /2 -y /2 > final95.hdr
42 .SH AUTHOR
43 Greg Ward
44 .SH "SEE ALSO"
45 pdfblur(1), pfilt(1), pinterp(1), pmblur(1), pmdblur(1), ranimove(1),
46 rcode_depth(1), rpict(1), rtpict(1)
