1 |
.\" RCSid "$Id: pmblur.1,v 1.3 2005/01/18 03:59:40 greg Exp $" |
2 |
.TH PMBLUR 1 3/3/98 RADIANCE |
3 |
.SH NAME |
4 |
pmblur - generate views for camera motion blurring |
5 |
.SH SYNOPSIS |
6 |
.B pmblur |
7 |
.B speed |
8 |
.B nsamp |
9 |
.B v0file |
10 |
.B v1file |
11 |
.SH DESCRIPTION |
12 |
.I Pmblur |
13 |
takes two viewfiles and generates |
14 |
.I nsamp |
15 |
views starting from |
16 |
.I v0file |
17 |
and moving towards |
18 |
.I v1file. |
19 |
When rendered and averaged together, these views will result in |
20 |
a picture with motion blur due to a camera changing from v0 to v1 |
21 |
in a relative time unit of 1, whose shutter is open starting at v0 for |
22 |
.I speed |
23 |
of these time units. |
24 |
Either |
25 |
.I pinterp(1) |
26 |
or |
27 |
.I rpict(1) |
28 |
may be called to do the actual work. |
29 |
(The given |
30 |
.I v0file |
31 |
must also be passed on the command line to the chosen renderer, since |
32 |
.I pmblur |
33 |
provides supplemental view specifications only.)\0 |
34 |
.PP |
35 |
For |
36 |
.I pinterp, |
37 |
feed the output of |
38 |
.I pmblur |
39 |
to the standard input of |
40 |
.I pinterp |
41 |
and apply the |
42 |
.I \-B |
43 |
option to blur views together. |
44 |
In most cases, two pictures with z-buffers at v0 and v1 will |
45 |
get a satisfactory result, though the perfectionist may wish to |
46 |
apply the |
47 |
.I \-ff |
48 |
option together with the |
49 |
.I \-fr |
50 |
option of |
51 |
.I pinterp. |
52 |
.PP |
53 |
To use |
54 |
.I pmblur |
55 |
with |
56 |
.I rpict, |
57 |
apply the |
58 |
.I \-S |
59 |
option to indicate a rendering sequence, and set the |
60 |
.I \-o |
61 |
option with a formatted file name to save multiple output |
62 |
pictures. |
63 |
When all the renderings are finished, combine them with the |
64 |
.I pcomb(1) |
65 |
program, using appropriate scalefactors to achieve an average. |
66 |
Note that using |
67 |
.I rpict |
68 |
is MUCH more expensive than using |
69 |
.I pinterp, |
70 |
and it is only recommended if the scene and application |
71 |
absolutely demand it (e.g. there is prominent refraction that |
72 |
must be modeled accurately). |
73 |
.PP |
74 |
For both |
75 |
.I pinterp |
76 |
and |
77 |
.I rpict, |
78 |
the computation time will be proportional to the number of views from |
79 |
.I pmblur. |
80 |
We have found a |
81 |
.I nsamp |
82 |
setting somewhere between 5 and 10 to be adequate for most images. |
83 |
Relatively larger values are appropriate for faster camera motion. |
84 |
.PP |
85 |
The |
86 |
.I \-pm |
87 |
option of |
88 |
.I rpict |
89 |
may be used instead or in combination to blur animated frames, with |
90 |
the added advantage of blurring reflections and refractions according |
91 |
to their proper motion. |
92 |
However, this option will result in more noise and expense than using |
93 |
.I pmblur |
94 |
with |
95 |
.I pinterp |
96 |
as a post-process. |
97 |
If both blurring methods are used, a smaller value should be given to the |
98 |
.I rpict |
99 |
.I \-pm |
100 |
option equal to the shutter speed divided by the number of pmblur views. |
101 |
This will be just enough to blur the boundaries of the ghosts |
102 |
which may appear using |
103 |
.I pmblur |
104 |
with a small number of time samples. |
105 |
.SH EXAMPLES |
106 |
To use |
107 |
.I pinterp |
108 |
to simulate motion blur between two frames of a walk-through |
109 |
animation, where the camera shutter is open for 1/4 of the |
110 |
interframe distance: |
111 |
.IP "" .2i |
112 |
pmblur .25 8 fr1023.pic fr1024.pic | pinterp \-B \-vf fr1023.pic \-x 640 \-y 480 |
113 |
fr1023.pic fr1023.zbf fr1024.pic fr1024.zbf > fr1023b.pic |
114 |
.SH AUTHOR |
115 |
Greg Ward |
116 |
.SH BUGS |
117 |
Changes in the view shift and lift vectors or the fore and aft |
118 |
clipping planes are not blurred. |
119 |
.SH "SEE ALSO" |
120 |
pcomb(1), pdfblur(1), pinterp(1), pmdblur(1), rcalc(1), rpict(1), vwright(1) |
